PICS Custom Harlan Shiftlight Install!
Old Feb 19, 2002 | 11:14 AM
20thdriven's Avatar
Sacrificed the side defroster.
Alomst looks factory. This thing is well worth it and highly visible.
Install--20min
Custom pod design--3 hours
Old Feb 19, 2002 | 11:16 AM
20thdriven's Avatar
PICS
Sorry, here is the site....
http://members.cardomain.com/aedriven
Old Feb 19, 2002 | 11:27 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nice!
You should post a write up in the "How To" sticky.
How hard is it to program the light for the desired RPM? How accurate is it?
Old Feb 19, 2002 | 11:34 AM
20thdriven's Avatar
Re: Nice!
Programming is a matter of reading a spreadsheet, flipping switches, and pressing buttons. SIMPLE!!
100 RPM increments. you can change shiftpoint in SECONDS. Supposed to be more accurate than stock analogue tach. There is a "How to" already. it deals with another brand shiftlight, but wires/install is identical. (5th GEN)
Old Feb 19, 2002 | 11:37 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Nice!
Alex... its cake to install, just like your light (wire-wise). In fact thats the sticky I used to install. I placed it in the visor line, ran the wires up the A-pillar across headliner, down the mirror wire guard and it sits just above my rearview mirror attached to a modified radar detector mount. Totally outta sight from the outside unless your really look in.
Programming is even easier...100RPM increments from 500-12500. In fact if you have the spreadsheet around, you can "almost" program on the fly. Takes about 5 seconds to switch the dip-switches and press the appropriate activation button.
I did notice some deviation from when the light pops on and where the tach needle was. But I have seen on the board because the tach is mechanical interpreting a digital signal it is a tad behind and thats what is seems to show from what I did.
BTW Still did not get that doggone boot out this weekend....sorry. I just can't get organized....lol.
Old Feb 20, 2002 | 09:03 AM
IceY2K1's Avatar
Re: Re: Nice!
Thanks, but I meant post a write up on how to make the custom pod and install it in the defroster vent. I've never done that before and I'm just wondering what's involved.
I was also wondering if you have to uninstall the shift light to program it once it was in the vent? It sounds like you don't since it only takes seconds to reprogram, so I'm just wondering how it's done once it's installed.
Jon(Colonel)
Post them pics! Also, I know how the unorganized part goes. I still haven't even installed the DAMN clips for the HIDs yet! They just look like they are gettin jiggy wit it as I drive.
Old Feb 20, 2002 | 10:01 AM
20thdriven's Avatar
Harlan POD
You need
Dremel/Sandpaper/Files/Bondo/Primer/Paint
-use your factory vent as a mount, make sure you block off the vent with a towel or something.
-cut a hole in vent to thread the light through, throw some bondo one there, let dry, then start shaping it out. make sure you aim it 1st!
-make sure it's smooth before you paint.
-wire it up
DONE!
i can easily remove the POD for reprogramming
since i'm still using the factory vent piece.
Old Feb 20, 2002 | 10:28 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: Nice!
Jon(Colonel)
Coming soon...just bought a new camera and will upload this evening...
Old Feb 20, 2002 | 11:11 AM
PhantonR's Avatar
Re: Harlan POD
Is there an on/off switch? I could see my wife driving along hitting the gas and that light turning on and scaring the **** out of her and wrecking my car. Not to mention that I would want the undo attention at all times.
As for workmanship, I've seen better j/k That looks GREAT!! VENTS, I DONT NEED NO STINKIN VENTS!! How much did the light and stuff cost?
You need
-wire it up
DONE!
Old Feb 20, 2002 | 11:20 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Harlan POD
Yeah puttin in an external switch would be cake. There are 3 wires, power, ground/neutral, and RPM signal. Just interupt the power with a position switch and you would be good to go.
As for undo attention, thats why I mounted it really high. Unless it goes off at night, you wont see it from outside the car. He he he its all about the stealth game.
Old Feb 20, 2002 | 11:25 AM
PhantonR's Avatar
Re: Re: Re: Harlan POD
Amen to that brother. Thats why I chose PhantonR(supposed to be an M but I fat fingered it and was like ohwell) I went to some street races in a complex and if the cops came I could leave my car and they wouldnt suspect a thing, with it looking stock and all.
Any idea on how much this stuff costs and where I could get it?
Thanks,
Jeff
Old Feb 20, 2002 | 11:32 AM
20thdriven's Avatar
shift light prices
here's the sight:
http://harlan.sketchy.net/store/store.html
$50 for red, yellow, green
$70 for blue.
$5 shipping
$1.50 mounting bracket
i'm all about the sleeper look, send me some pics of your max's
Old Feb 20, 2002 | 11:33 AM
2M0A0X2's Avatar
y do car domain have to do their maintanence everytime i go to it?
JRod28
Dec 29, 2023 09:56 PM
95Maxi
35
Sep 2, 2015 10:37 AM
t6378tp
Aug 24, 2015 07:03 AM
Team STILLEN
Aug 10, 2015 04:29 PM
