CAI cause rich A/F mixture????
Old Feb 20, 2002 | 11:19 PM
MaxTuner's Avatar
Could the CAI be the culprit that causes rich A/F mixture in our engines? that possibily leads to Cat failure(meltdown)???
Old Feb 21, 2002 | 04:53 AM
PCGuRu2K's Avatar
Re: CAI cause rich A/F mixture????
Well when I had my Cai I was running lean on both Bank1 & Bank2 O2 sensors... I was running a stock cat. Since then I've switched to a PR Cai Upper Tube/JWT combo with the addition of a RT Cat...
Old Feb 21, 2002 | 08:56 AM
Keh mon's Avatar
Re: Re: CAI cause rich A/F mixture????
Did the switch change your lean condition?
Old Feb 21, 2002 | 10:48 AM
PCGuRu2K's Avatar
Re: Re: Re: CAI cause rich A/F mixture????
Yes it did.. Since then I've switched over it's been running normal..
Old Feb 21, 2002 | 10:54 AM
MaxTuner's Avatar
Re: Re: Re: Re: CAI cause rich A/F mixture????
So you didn't change any O2 sensors rite?
Old Feb 21, 2002 | 11:54 AM
BigDogJonx's Avatar
PCGuru
How did you know it was running lean? Did you check it with the OBDII or did you take it to the dealer?
Only reason I ask is because I just bought me a PRCAI and will be installing it this weekend. BTW, I dont have a Cat, got a straight pipe and also got a Cattmany SS Ypipe.
Dixit
Old Feb 21, 2002 | 02:11 PM
PCGuRu2K's Avatar
Originally posted by BigDogJonx
PCGuru
Dixit
I knew I was running lean because I took it to a shop and they used a scanner tool to diag my ecu error code.. Nope, I didn't replace and O2's...
Old Feb 21, 2002 | 06:45 PM
Dario's Avatar
i have the CAI and an A/F ratio gauge, im never running lean and run rich on WOT
Old Feb 21, 2002 | 08:47 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Cat failure == Y-pipe...
I know I'm going to get FLAMED for this one, but what the hell.
It's the Y-pipe. If you remove the precats you allow the heat build up/cooling effect to move downstream to the main cat, which causes it to overheat and thus fail.
This is NOT a 100% guarantee, but it does happen.
I plan on going with Dixit's straight pipe BEFORE I get my Y-pipe installed, therefore eliminating the chance of having to replace that EXPENSIVE pos.
Flame away!
Old Feb 22, 2002 | 07:01 AM
TellschMax02's Avatar
Re: Cat failure == Y-pipe...
Flame away!
Wouldn't getting a high-flow cat help to fix this?
Old Feb 22, 2002 | 07:30 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
... but you were at idle when they ran they pulled the code, right? Or did they take your car to redline with the scan tool still connected?
Old Feb 22, 2002 | 08:09 AM
IceY2K1's Avatar
Re: Re: Cat failure == Y-pipe...
The RT high-flow cats SEEM able to handle it, but WHY spend $200+ vs. $50-70 on something that's NOT going to make you pass an emissions test anyways.
I don't understand why people think adding a RT cat is worth the money.
I argue that until you have at least a Y-pipe and catback FIRST you won't gain ENOUGH from an aftermarket cat to justify the cost and that the minimal gain is NOT noticeable. Peple have reported noticeable gains, but it's argueable that it's in their head. I too have added mods and the car feels faster, when actually it's that your just paying more attention, driving harder than normal, or it's just the added sound effects. Once you add a SC/turbo/NOS, you can see some noticeable/measureable gains.
Again, why not just spend $70 on a straight pipe to replace the cat vs. $200+ for a RT Cat? Performance wise there would be minimal difference, if not better performance from the straight pipe.
Old Feb 22, 2002 | 10:51 AM
MaxTuner's Avatar
Re: Re: Re: Cat failure == Y-pipe...
Wouldn't straight pipe trigger SEL on cars that have sensor behind the main Cat(Fed Emission)????
How do you solve this?
Old Feb 22, 2002 | 11:08 AM
IceY2K1's Avatar
Re: Re: Re: Re: Cat failure == Y-pipe...
I don't think so. Nobody has done a Y-pipe and straight pipe?
If it does trigger a MIL(SEL), then it is possible to trick the rear 02 sensor(s). You just have to make it read a difference, either by putting a shield around it or possibly by adding a resistor to the wires. Not sure, but it can easily be done.
The rear 02 sensor(s) are ONLY used for monitoring cat or upstream 02 sensor failures by measuring a LARGE difference, so there isn't any ECU calculations to worry about messing up.
I'll look into it a little more. Maybe that's why people pay out for the RT cat. If so, that's a VERY expensive solution to a simple problem. Hmmmmmmmmm.
Sep 27, 2015 08:37 AM
msellas
Sep 23, 2015 09:16 PM
A32goldylocks
Sep 16, 2015 01:33 PM
ballerchris510
Sep 10, 2015 09:35 PM
AT978
Sep 6, 2015 10:31 PM
