Gonna Dyno Saturday
Old Feb 21, 2002 | 11:44 AM
MAX2000JP's Avatar
Gonna Dyno Saturday
I am gonna dyno my car this Saturday. I have never done it before and I am dealing with a reputable shop. Is there anything I should do before the dyno to get my car preped. Also what gear should they get the results from. I will post the numbers and charts when I get them. What are good numbers for a 5 speed with JWT and Cattman Y?? I am hoping for around 200 fwhp, is this about right?
Old Feb 21, 2002 | 12:00 PM
20 MAXIMA 02's Avatar
Re: Gonna Dyno Saturday
i'd say ur a good 10-15 hp shy of the 200 mark
Old Feb 21, 2002 | 12:26 PM
djmaxski's Avatar
I thought 2k/2k1 5 spds put down about 185 -190 fwhp stock... And then adding an intake and y pipe was good for another 15 -20 fwhp. I think that 200 sounds reasonable based on what others have said some time ago.
Old Feb 21, 2002 | 01:00 PM
DenMax's Avatar
Hmmmm
around 200 is reasonable for a 5th gen. and the mods you have. Good luck and let us know hot it turns out.
Old Feb 21, 2002 | 02:29 PM
Max_Gator's Avatar
Re: Hmmmm
Run it in 3rd gear.
You should get around low 200s whp. Normally, there is a spike of 3-5 hp at redline when the limiter is hit. The shop should "smooth" that spike out automatically. The 2ks we've done have put down low 190s stock.
Make sure you get results in electronic format so you can post them easily.
Good luck!
Old Feb 21, 2002 | 04:02 PM
MAX2000JP's Avatar
Re: Re: Hmmmm
Originally posted by Max_Gator
Run it in 3rd gear.
Good luck!
Thanks for the info. Ill let them know about the spike before I dyno. I will post a plot for you guys on Sunday.
Old Feb 21, 2002 | 09:56 PM
emax02's Avatar
Re: Re: Hmmmm
Run it in 3rd gear.
Good luck!
No, 4th gear is THE gear to dyno in! Everyone dynoes in 4th gear(except auto's).
If you don't believe me do a search!
3rd gear will put down more HP because the transmission multiply's the power because of the gear ratio is off. The key is to dyno the car as close to 1.0 ratio, 4th gear is that gear.
Old Feb 22, 2002 | 03:49 AM
Max_Gator's Avatar
Re: Re: Re: Hmmmm
That's probably true for the 6speed. If I recall correctly on the 5speeds, a true 1.0 gear ratio is somewhere between 3rd and 4th (i.e. 4th is a bit of an overdrive gear).
Think most 5spds dyno'd in 3rd but if search says otherwise, I'm wrong. I dyno'd in 3rd and always have for comparison purposes.
Either way, if you are having the problem I am, it will show up in either gear.
Old Feb 22, 2002 | 04:01 AM
PCGuRu2K's Avatar
Re: Re: Re: Hmmmm
So what gear should a Automagic dyno at??
Old Feb 22, 2002 | 04:35 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: Re: Hmmmm
3rd gear
Old Feb 22, 2002 | 04:44 AM
maxgsxr1
Re: Re: Hmmmm
Run it in 3rd gear.
Good luck!
what should a auto 2k1 have for horsepower with my mods????
Old Feb 22, 2002 | 06:42 AM
Stereodude's Avatar
3rd gear in a 5 speed is 1.274 4th is .954. I'd say .954 is closer to 1 than 1.274.
Stereodude
Old Feb 22, 2002 | 06:55 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: Re: Re: Re: Re: Hmmmm
Originally posted by UMD_MaxSE
3rd gear
This Sunday.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
londonflu
40
Sep 25, 2015 09:11 AM
homeofbacon
Sep 23, 2015 07:17 PM
Violator
Sep 9, 2015 10:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
