How to bypass the rev limiter
Old Feb 25, 2002 | 01:56 PM
bert's Avatar
Do 90MPH in 3rd, push in clutch, put in 2nd, release clutch.
Only did it 1 second, caught it right away. **** my pants! everything still running fine.
Old Feb 25, 2002 | 05:27 PM
My 4DSC
some people just shouldnt own a stick
Old Feb 25, 2002 | 05:38 PM
PIONEER's Avatar
by Pass rev Limiter. Man U lucky the Axle didn't snap off or the Motor didn't come through the hood... Good God
Old Feb 25, 2002 | 06:21 PM
bert's Avatar
I caught it right away, I am sure that I started catching it as the revs came up, instead of down.
I was expecting my temp to go up, my oil pressure to go down and my pistons to go WAY up!
Anyone want a slightly used 2K white SE?
Old Feb 25, 2002 | 06:25 PM
Sprint's Avatar
damn canadians..
bert.. how come i havn't seen you on the list? did you ever get that sorted out?
Old Feb 25, 2002 | 06:40 PM
bert's Avatar
What is this list thing? If it's any more complicated than a clutch and a stick, I can't handle it.
tomz17's Avatar
Re: How to bypass the rev limiter
Good tip... anyone want to add this to the FAQ?
-Tom Z.
Old Feb 25, 2002 | 08:18 PM
FastCougar's Avatar
Re: Re: How to bypass the rev limiter
Makes perfect sense if you think about it ... I did the same thing once and made sure all my upshifts where clean and consise ... downshifted to 3rd instead of upshifting to 5th ... did so at 115mph!!! Again, I only did it for a mere fraction of a second. This was almost 2 years ago and here is what I have deducted as the reason for it happening.
First, it's a built in safety feature for the engine so that if it does happen and you catch it in time, the limiter isn't there to run the mixture lean (hard limiter = cuts gas and timing, soft limiter = cuts timing) ... lean mixture + 7K RPMS = instantly toasted engine. Second, this is a by-product of the way the limiter works in the first place. If you work your way up the RPM range and the engine management knows the engine RPM, it can decide where to cut off the gas and retard the timing. The ECU could just as easily be set up to cut fuel/timing at anything above xxxx RPMs, but it's designed to only cut increasing RPMs ... seams that when you shift, either things are reset or more likely, it sees that it's x gear and it knows that it's limit is xxxx and you are doing yyyy and something must be wrong, so don't cut the gas/timing.
Old Feb 25, 2002 | 08:47 PM
Keh mon's Avatar
-Tom Z.
haha nice sig. "are belong to us"
Old Feb 25, 2002 | 10:26 PM
imccasli's Avatar
Re: Re: Re: How to bypass the rev limiter
i had to ask what that meant the first time....damn newbie questions
Old Feb 26, 2002 | 02:20 AM
Sprint's Avatar
Maxima Mailing list you use to be on
Old Feb 26, 2002 | 03:33 AM
Norm Peterson's Avatar
Fast,
The rev limiter only stops the engine from over-revving due to the engine's own operation. It can do absolutely nothing to prevent the engine from turning xxxx or even 1xxxx rpm if it is driven up there by the combination of road speed and engagement of the wrong gear. Actually it almost certainly did activate and bert just didn't notice it due to the sudden deceleration and the "OH $#!t" nature of the moment.
Norm
Old Feb 26, 2002 | 04:06 AM
a33's Avatar
a33
My 4DSC: why you dissing him????
he is just sharing his experiences.....
its not like you knew how to drive stick well from day one.....
Old Feb 26, 2002 | 05:10 AM
zeitgeist57's Avatar
Hey tomz17
If the speedo in your sig is going damn near 160mph, why is the automatic gear selector panel thingy just to the right indicating that the Max is still in PARK
Old Feb 26, 2002 | 06:39 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
they got some kind of software where you can run the speedometer up without turning on the car. my roommates got a pic of his 4th gen doing the same thing. i was trying to figure out how someone would be able to take a steady shot at that speed, but now i know.
Old Feb 26, 2002 | 06:58 AM
njmaxseltd's Avatar
It's called Photoshop.
Old Feb 26, 2002 | 11:40 AM
Dan4614's Avatar
I drive an automatic, but I know that cant be good for your car. Get an apexi rsm. it will override your speed and rev limiters!
Old Feb 26, 2002 | 03:12 PM
tomz17's Avatar
Re: Hey tomz17
Heh... it's photoshopped... (unless you have some clever way to take a picture that good while GOING THAT FAST!) trust me, you're not the first person to point out the fact that it's in park... (+ some of the shadows, and the needle stop are off by a bit, but not enough to make it look bad)
-Tom Z.
05' MaximaMan
Oct 8, 2017 06:36 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
jwright36
Sep 8, 2015 11:45 AM
