FSTB Question
Old Feb 26, 2002 | 09:40 AM
csyeo's Avatar
FSTB Question
Guys,
Just a curious question. What torque did you set when you installed the stillen FSTB? Somehow, I doing a search I seem to see different torques. Also, for some torques, I understand that there will be squeaking.
Old Feb 26, 2002 | 09:43 AM
MaximaRacer's Avatar
I believe the torque should be in the 30s. For the 4th gen the torque was 32-35. Should be similar. You would be fine anbywhere from 32-38. Squeaking? Dont know about that.
Old Feb 26, 2002 | 10:59 AM
MaxSC's Avatar
Re: FSTB Question
Originally posted by csyeo
Guys,
if its a fifth generation, and a stillen, i torqued the strut tower rings between 45 i think, and the tower brace was at 20
Old Feb 26, 2002 | 11:04 AM
Jief's Avatar
Re: FSTB Question
Guys,
Courtesy has your answer .... 35
Courtesy
Old Feb 26, 2002 | 11:35 AM
Thorzdad's Avatar
Further install question
If I may piggyback on this thread...
Has anyone used any sort of thin neoprene or similar thin gasket material between the plates and the tower during a brace install? Or is a bare, metal-to-metal install the way to go?
Jim
Old Feb 26, 2002 | 11:44 AM
MichaelAE's Avatar
Re: Further install question
Jim
Direct, metal-to-metal and I concur on the 35 ft/lbs. bolt settings.
Old Feb 27, 2002 | 07:21 AM
csyeo's Avatar
I was wondering whats the disadvantage of overtorqing?
Old Feb 27, 2002 | 07:59 AM
djmaxski's Avatar
Added stress on the bolts. As far as what it might do to bar performance, not much I guess...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
