DOH... 2000 maxima TSB
Old Feb 27, 2002 | 08:26 AM
yongjun's Avatar
Here you go 2000 maxima guys
http://www.alldata.com/TSB/41/00416289.html
TSB Number Issue Date TSB Title 00-039A DEC 00 A/T - 1st to 2nd & 2rd to 3rd Gear Slippage
00-037A NOV 00 Steering/Suspension - Vehicle Pull Diagnosis
00-056A NOV 00 A/T - Oil Cooler Cleaning Procedure
00-090 NOV 00 Trunk Finisher - Popped Out of Place
00-088 OCT 00 Brakes - Judder/Vibration
00-085 OCT 00 EVAP Canister - Charcoal Leakage
99-077B OCT 00 A/C System - R134A Refrigerant Dye Introduction
00-077 SEP 00 Special Tools - Fuel Pressure Gauge Kit
00-073 SEP 00 Bumpers - Protector Removal at PDI
00-070 AUG 00 Engine Control Module - MIL ON, DTC P0420 Set
00-052A AUG 00 ECM - Replacement/Reprogramming Procedures
00-006A AUG 00 ECM - Reprogramming Procedures
99-063B AUG 00 Antitheft System - Key Registration Procedure
99-048D JUL 00 Battery - OE And Replacement Ratings
00-064 JUL 00 CD Changer - CD Care and Usage Guidelines
00-060 JUL 00 EVAP Vent Control Valve - DTC'S Stored in Memory
00-017A JUL 00 Tools - CONSULT-II Software Update
00-057 JUL 00 Tools - CONSULT-II Repair Procedures
00-055 JUL 00 Rear Bumper - Scratched by Trunk Lid
00-044 JUN 00 CONSULT-II - ECM Reprogramming Software
00-032 MAY 00 Tools - Air Bag Deployment Adapter
99-036A MAY 00 Keyless Entry - Remote Programming
00-042 MAY 00 Side Air Bag - Tampering/Modification Precautions
00-041 MAY 00 Engine - DTC P0505 Stored in ECM
00-033 MAR 00 Brake System - Diagnosis & Repair
00-021A MAR 00 Tools - CONSULT-II NATS Software Update
00-030 MAR 00 Strut (Right Front) - Noise
00-022 MAR 00 Consult-II Software Cards
00-027 MAR 00 Nissan Essential Tool Shipment Summary
00-026 MAR 00 A/C Refrigerant Machine (ACR4) - Maintenance
00-008 MAR 00 00-008 - 03/07/00
00-008A MAR 00 Low Idle/Stall - In Gear
99-056D FEB 00 Interior - Squeak & Rattle
00-016 FEB 00 Brakes, Front - Groan Noise
99-071 FEB 00 99-071 - 02/10/00
99-071A FEB 00 Blower Motor - Noise
00-013 FEB 00 On-Car Brake Lathe Procedure for Steering Vibration
99-055A FEB 00 Headliner - Sags At Sunroof Railing
99-078A JAN 00 TCS & SLIP - Service Lights ON
99-046A JAN 00 Door Finisher Cloth - Insert Repair
00-002 DEC 99 New Model Refinish Paint Codes
99-044B OCT 99 Battery/Starting/Charging System Tester.
99-075 OCT 99 Poor Engine Performance at Low RPM
99-067 SEP 99 Intergrated Homelink Transmitter
99-060 SEP 99 Paint Guard Film - Swell, Stains, and Spots
99-045 JUN 99 Interior Trim - Removal Tips
92-062A JUN 99 AMMCO On Car Brake Lathe Operating Guidlines
94-012A JUN 99 Brake Judder/Steering Wheel Shimmy
99-040 JUN 99 ABS Sensor - Precaution Using On Car Brake Lathe
99-038 JUN 99 PDI - Paint Protection
99-034 JUN 99 99-034 - 06/02/99
99-034A JUN 99 Year 2000 Compliance of Nissan Vehicles
99-011A MAY 99 A/C - R134A Leak Detection (Dye)
99-033 MAY 99 Child Seat - Anchor Plates
99-019 APR 99 O2 Sensor, Rear - Procedure Change
99-028 APR 99 Front Seat Belt - Slow Retraction
99-020 APR 99 Towing Guidelines for Nissan Vehicles
99-017 APR 99 Audio Speaker - Noise (Cellular Phone)
99-001 FEB 99 Strut - Leak Guideline
98-110 JAN 99 Squeak and Rattle Repair - Supplies
98-106 JAN 99 A/C System Reciever - Drier Replacement Guidlines
98-089 NOV 98 O2 Sensor Thread Repair For Exhaust Tube.
98-060 JUL 98 Body Repair - Guidlines for Rust & Corrosion
98-063 JUL 98 New A/C Leak Detector
98-041 MAY 98 All Hose Lubricant Applications
98-005 FEB 98 New A/C Connections O-Rings
97-060 AUG 97 Bumper Refinishing Technique
97-017 MAR 97 Air Bag Harness Replacement
97-012 FEB 97 Wheel Balancer Adapter Kit - Use
96-050 JUL 96 Consult (Scanner) - Exchange Program
96-032 APR 96 Engine Cranks, But Won't Start Or Is Hard To Start
96-031 APR 96 Service Manual Comment Forms
95-114 DEC 95 Clutch Operating Cylinder - Service Information
95-068 JUL 95 Air Conditioning, R134a - Charge Amount/Lubricant Chart
PI95-006 MAR 95 Brake Noises
95-015 MAR 95 Air Conditioning - Installation Procedures
94-009 MAR 94 Battery Charging/Replacement Procedure
94-015 FEB 94 Paint - Contamination Identification and Repair
94-011 FEB 94 Starting & Charging System General Diagnosis
93-109 JUL 93 Paint Finish - Maintanance/Storage Recommendations.
93-112 JUL 93 Seat Belt Extenders
93-017 JAN 93 Cassette Tape Player - Maintenance
92-001 JAN 92 Changes to A/C Systems as Result of R-134A Refrigerant
91-096 DEC 91 ABS, Self Check - Noise
91-046 MAY 91 Consult Lithium Battery Replacement
90-090 OCT 90 Angular Tightening
90-044 MAY 90 Cassette Tape Player Maintenance
89-131 AUG 89 Silicone And PBC Greases
88-015 FEB 88 Cautions for Aftermarket Rust Proofing
87-172 NOV 87 Automatic Transmission - Cleaning Components.
87-103 JUN 87 Disc Brake Noise Information.
87-064 APR 87 Plastic Lens - Isopropyl Alcohol Caution
Old Feb 27, 2002 | 08:31 AM
maximadave's Avatar
detailerdaveb@gmail.com
Thank you
Old Feb 27, 2002 | 08:35 AM
Bags's Avatar
VG Ridah's Biatch Hoe
I have a question
How can the dates for the TSB's be 1987 to 1998?
I am just curious thanks
Old Feb 27, 2002 | 08:38 AM
yongjun's Avatar
Re: I have a question
This is for SE model cars
1997
http://www.alldata.com/TSB/41/97416257.html
1998
http://www.alldata.com/TSB/41/98416289.html
Old Feb 27, 2002 | 08:44 AM
Bags's Avatar
Re: Re: I have a question
1997
1998
Ok maybe I did not ask correctly.
On the 2000 TSB list there are TSB's that are dated back to 1987.
are those for a 2000 maxima?
Old Feb 27, 2002 | 08:46 AM
yongjun's Avatar
Re: Re: Re: I have a question
I dunno.
Good question
Old Feb 27, 2002 | 08:48 AM
Bags's Avatar
Re: Re: Re: Re: I have a question
I dunno.
Good question
thanks for the honest answer.
Old Feb 27, 2002 | 12:27 PM
theMax's Avatar
Re: Re: Re: Re: Re: I have a question
not all TSBs are to fix problems. They are also used to standardize shop practices and get information out.
For example the 1987 one
I bet says don't use alcohol to clean plastic lenses. This will be on all cars that have plastic lens. It doesn't mean there is a problem with your lens.
halfpol
Oct 17, 2022 12:16 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
