Is a camber kit required with the H&R's?
Originally posted by Dario
the only reason you would need a camber kit is if you went with the coilovers
You can use coilovers and drop it 1-1.5" and not need the camber correction kit.
In a word, no. The Maxes have positive
camber as a stock OEM setting..that causes the tires to wear on the outside edge more than the inside edge, dropping the car slightlu with either Eibachs or H&Rs creates a more neutral camber setting for the front tires.
Indeed, the camber setting goes slightly negative-which is good for overall handling and tire wear since the slightly negative camber offsets the correct toe-in...bottom line you'll get much BETTER tire wear after dropping the car slightly.
i didnt know they were making the adjustables now im going to wait a little longer thanks for the info
Here is teh page it mentions it on...
http://www.tokicogasshocks.com/new.asp
i still have my stock setup had the springs since about 15000 and i now have close to 49000
Re: In a word, no. The Maxes have positive
Originally posted by Galo
I'll have to measure this since I don't have a shop manual for mine yet. Note that it might be possible for SE's to have a slightly different spec than GLE's as part of the slightly greater emphasis on 'sport'.
With a MacPherson/Chapman strut type of suspension wheel camber goes negative in pure bump (like when you get on the brakes) but not in roll. Chassis roll in a corner puts the outside wheel in positive camber. Many strut-suspended cars actually have a small negative static camber setting as OE.
Norm
04-16-2020 05:15 AM
Pied
09-26-2015 03:29 PM
