Cold Air Intake is in
Old Mar 12, 2002 | 04:49 PM
Rafed White's Avatar
I had received my CAI about 2 months ago and i finilly had the time to work on placing it in. It was hell. The pipe was not sitting in and i was getting very ****ed. but then i made the hole bigger intill it finnaly fit. It sounds good, and i don't know if it is any faster. It feels like it but i have to time it to make sure. But one thing is for sure, if ur getting one do not cut were indicated by the tamplet cut about 2 inches twardes the front of the car.
Old Mar 12, 2002 | 07:21 PM
BigDogJonx's Avatar
Re: Cold Air Intake is in
Yeah I had this same problem, Now the pipe sits slightly at an angle. I need to get it back out and make the hole larger. But that is going to be hard considering how much I may have to shave.
Dixit
Old Mar 12, 2002 | 07:22 PM
Dario's Avatar
ditto on that guys i had to enlarge the hole as well
Old Mar 12, 2002 | 07:25 PM
BigDogJonx's Avatar
I give this thread 35mins before "someone" from Frankencar comes in here to "promote" their supposedly "cold air" intake.
Bet on it.
Dixit
Old Mar 12, 2002 | 07:26 PM
Dario's Avatar
Bet on it.
Dixit
Old Mar 12, 2002 | 11:37 PM
bernie2000se's Avatar
I also had to make the whole bigger, when I called them they said I had the 99 template,,, hello now you tell me after i have a fricking hole the size of a bowling ball(not literally it feels that big). You should call them, and tell them of the mistake, and see what they tell you. Bernie
Old Mar 14, 2002 | 08:31 AM
MyownNismo's Avatar
Future Camaro SS owner
Where did you all get it from I got mine directly from place racing and I have a 2000 template. If you guys installed it did you all have the wrong template or am I going to have to same problem.
Old Mar 14, 2002 | 10:11 AM
BigDogJonx's Avatar
Some people have been saying that the 2000 maxima template is wrong. I am am starting to believe it, cause I made the hole according to the template and it still dont fit "perfect" I think I am going to have to make it even larger.
Dixit
Old Mar 14, 2002 | 10:18 AM
MyownNismo's Avatar
Dixit
was yours a 2000 template.
Old Mar 14, 2002 | 10:34 AM
BigDogJonx's Avatar
Yeah it said 2000 MAXIMA on the template. The battery bolts matched up. Just the hole is incorrect.
Dixit
Old Mar 14, 2002 | 11:06 AM
MyownNismo's Avatar
Dixit
Which direction does it need to go.
Old Mar 14, 2002 | 04:20 PM
To make the pipe fit i made a hole about 2 inches twards the front of the car. Try this and good luck.
Old Mar 14, 2002 | 06:08 PM
BigDogJonx's Avatar
2inches is alot. Did the pipe clear everything just fine? I think I "enlarged" mine about 1/2" more toward the wheel well. Basically so we dont have any confusion, more toward the rear of the car if you were looking straight at the engine from the front of the car. I dont think making the hole closer to the front of the bumper is going to make it fit. Just then it get too close to the battery and to a point where the battery is not going to fit nor the battery plate.
Dixit
Old Mar 14, 2002 | 10:11 PM
Dixit
Maybe i was not clear. The pipe didt't fit because it was gitting the fender. By moving it twards the front, it the filter was sitting clear from whats around it. If not 2 In it was one and a half. But it is sitting perfect now. When i get my camera im gona post the pics if u want.
Old Mar 14, 2002 | 10:30 PM
For mine, if your looking from in front of the engine(standing) my hole had to go back(up towards the windshield) about 1.5 inch, and the white box that held the wires would not fit so we taped them up really well, under the black box(fuse), my hole now is about 4-5 inches round, because of the fit, not being correct,,ahhhhhhhhhhhhhhhhhhhhhhhhh I was so mad
Old Mar 14, 2002 | 10:43 PM
MyownNismo's Avatar
Your hole should only need to be 3 1/4.
Old Mar 15, 2002 | 07:36 AM
BigDogJonx's Avatar
I agree but that only applies IF AND IF the hole was drilled in the right location. If not, then you hole will be oblonged and larger than normal.
Dixit
Old Mar 15, 2002 | 08:04 AM
victor's Avatar
Bet on it.
Dixit
lmao. whenever i see a intake post, i always think the same thing.
Old Mar 15, 2002 | 10:08 AM
MyownNismo's Avatar
Well I am looking to put mine on today what are some pointers.
Old Mar 15, 2002 | 10:18 AM
BigDogJonx's Avatar
Well defetely remove the battery and all that good stuff. I would say put the template down and then drill the hole 1" closer to the rear of the car. So just shift it a bit. Cause I used the correct template and it still did not fit correctly
Dixit
Old Mar 15, 2002 | 10:43 AM
MyownNismo's Avatar
Dixit
I was following pioneers install and he had no problem. Did you put the coupler all the way on the MAF sensor like this.
Old Mar 15, 2002 | 11:00 AM
BigDogJonx's Avatar
That is the only place you can put the MAF sensor. But you notice how far his hole is from the screw hole just on the left of the pipe? Look at the pipe where the pipe going into the hole. Then look directly left about i say 2" (no actually 2" on the picture, inside the picture. You see how far that screw hole is, just make yours similar to that before drilling.
Dixit
Old Mar 15, 2002 | 11:07 AM
MyownNismo's Avatar
Dixit
Well I guess I will have to find out, If I have to make hole bigger or not.
Old Mar 15, 2002 | 11:14 AM
BigDogJonx's Avatar
http://bigdogjonx.gixxer.com/performance/intake.jpg
That is my picture. Same thing.
Dixit
Old Mar 15, 2002 | 11:33 AM
MyownNismo's Avatar
Dixit
yep. I guess I will have to see for myself when I put it in.
Old Mar 15, 2002 | 03:43 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Bet on it.
Dixit
i actually wasn't going to post anything, but all i will say is that i never claimed it was a supposed cold air intake. but it's cheaper and much easier to install. that is all i will say on this subject.
Old Mar 15, 2002 | 05:02 PM
MyownNismo's Avatar
How hard is it to remove the MAF sensor from the other piece that ataches to the trottle body.
Old Mar 15, 2002 | 05:04 PM
and drill 3 different holes till it barely fits through your fender. all i'm saying is that people r having issues with the fitment of the PR. that's all, FACT=People are having fitment probs. that's all.
-steve
Old Mar 15, 2002 | 05:28 PM
MyownNismo's Avatar
-steve
I don't care I have a PRCAI and I want to know how hard is it to take off the sensor from the piece that connects to the trottle body.
Old Mar 15, 2002 | 05:45 PM
OH YOU mean the ATS sensor, very easy. no one that i know of has had a problem with it. and it's prety much the same deal as a PR.
Old Mar 15, 2002 | 08:50 PM
MyownNismo's Avatar
No the Mass air sensor.
Old Mar 15, 2002 | 10:24 PM
takes maybe 15 minutes to take out the stock airbox and install a frankencar.
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
Sep 27, 2015 08:37 AM
