Quote:
Originally posted by soundmike
I want to follow in your steps
jeez, thats a lotta power. Yo Kevin... you change your name to m3 killa.Originally posted by soundmike
One day, i will reach 200HP, one day.
roger
roger
50 shot of nitrous will get you over that goal. Originally posted by radpp16
roger
Quote:
Originally posted by MardiGrasMax
So at what rpm does the WI kick in from the 3psi?
WI should have kicked in by about 2500 rpm.Originally posted by MardiGrasMax
Quote:
Originally posted by IceY2K1
Any idea what the dip at ~4500 RPMS is from?
Thanks. We dinked around with the fuel via the AFC at 5000, so that was probably the problem.Originally posted by IceY2K1
Quote:
Kev, does your AFC adjust fuel every 1000 RPMs? I know your limited to 8-points or whatever, but couldn't you hook up 2-AFC and have each 500 RPM increment adjustable? Originally posted by Y2KevSE
Would you need that precise of adjustment? Just wondering.
I have the points at 1000, 2000, 3000, 4000, 5000, 5500, 6000, and 6500. 8 points is more than enough to tune the fuel (see a/f curve).Originally posted by IceY2K1
Hooking two AFC's up is an interesting idea, but I believe the Fields Hyper SFC has more points so get that if you need more adjustability.
Assuming a 25% power loss. Not bad, not bad. Don't blow up that tranny! I suppose if you ever decide to take it to the track it will be interesting to see your results.
Quote:
WHOLLY SHAT!! I woke up this morning and thought the sun was rising from the west.......but now I know it was Kev FIRING UP HIS MAX!!!Originally posted by MichaelAE
Looks like a nuclear explostion........
