gc coilovers....
Old Mar 14, 2002 | 11:19 PM
a33's Avatar
a33
gc coilovers....
can anyone tell me about it...
i am about to get it, but i want to know what i have to do to the struts to make it fit...
i currently have the h&r and tokico setup
Old Mar 14, 2002 | 11:33 PM
woosh's Avatar
Re: gc coilovers....
Can you share your likes and dislikes about your current setup? Why do you want change to ground controls?
BTW I think Y2Kev has/had these.
Old Mar 14, 2002 | 11:40 PM
a33's Avatar
a33
first, i dont hink the car is low enough, for some reason, i still have 4 fingers of gap in the front, the back is ok, and in my opinion, i think the tokico's are too soft, i like the ride to be stiff, cuz i like it when the car doesnt roll to one side when i turn...
Old Mar 15, 2002 | 02:17 AM
RBa's Avatar
RBa
4 finger gap?? I'm on Eibachs and I only have 1 finger gap front, half finger rear... I thought H&Rs went lower than eibachs..
BTW.. I heard you have to shave off something to make the GCs fit.. I was thinking of getting GCs myself but still debating whether it's worth the trouble since I'm an everyday driver..
From your earlier and unfortunate visit, You must know NYC roads are the worst. I bottom out as is. Now I'm regretting lowering my car with my back injury and all...
I don't think tokicos are soft.. They are madd stiff compared to konis or kybs where you can adjust the setting.. If you want better cornering and limited sway, considering you don't have it already, add an RSB & FSTB. Adding an RSB made a big difference for me..
Just my 2 cents!!!...
Old Mar 15, 2002 | 07:45 AM
Themaxidocius's Avatar
I have GC on my 00 se
I love them and I bought the ones that use the stock struts or can be upgraded to tokico. They have gc that are specifcally made for koni's too. My max is lowered as low as the coilover goes, but there is a metal bracket inside the wheel well that won't allow it to go lower in the fornt. But if that wasn't there i would be tucking wheels big time. Right now it there is no gap right on top of the tire and there is no rub and rides good.
Old Mar 15, 2002 | 10:04 AM
srbarnes4ever's Avatar
Re: I have GC on my 00 se
Can you tell me what spring rates you used front and rear? I bought the GCs for my daily driver Ford Escort along with tokico struts and I think the ride sucks. The struts are waaay underdamped for the spring force (300# front/200# rear) so I'm going with conventional Eibach pro-kits for now until I find a good, adjustable strut to handle the load.
Old Mar 15, 2002 | 10:17 AM
max'n out's Avatar
If you really want gc, I suggest 400 to 450lb springs f&r, and agx struts so you can adjust it accodinly. You then have to have the body of the strut threded, some new mounts so forth and so on. Personally I say no, it's not a real coilover.
Old Mar 15, 2002 | 10:19 AM
a33's Avatar
a33
albert: i do have the rsb and fsb already.... and i have the h&r's and tokico, the roads in toronto are bad, but nothing compared to nyc, so i think i would go with the gc's.....
Old Mar 15, 2002 | 10:52 AM
adman's Avatar
I've always been happy with mine.
ADMAN
Old Mar 15, 2002 | 11:02 AM
jhans114's Avatar
Im interested in getting GC 2... but what are the best struts/shocks to combine so the ride isnt as harsh but will still ride on rails???Thanks
a33's Avatar
a33
i am very close to buyin it, just unsure about moddin the struts..
Old Mar 15, 2002 | 11:19 AM
Re: Re: I have GC on my 00 se
WEll you are comparing a ford escort to a maxima. Ride is so much different even stock. Just call Ground control and they have two versions based on what you are going to do with your stock struts. I have the GC coilovers for 2000 Max se that can be used with tokico or stock struts. Like i said i lowered it all the way and it ride is awesome. I had a 2000 civic with arospeed coilovers and they sucked - it was bouncin and made crunching sounds. But I would highly suggest GC for 5th gen maximas even with stock struts they are great.
Old Mar 15, 2002 | 11:45 AM
a33's Avatar
a33
what do you mean by there are two different versions???
does gc have two different versons of the coilover for the maxima??
Old Mar 15, 2002 | 02:30 PM
yes
u can either get gc coilovers for stock/or tokico upgrade -- or u can get the ones for koni strut upgrade
Old Mar 15, 2002 | 02:57 PM
jhans114's Avatar
Re: yes
To those who have GC... Do hear squeqing? How rough is the ride? I need this info in facts cause I was about to get the H&R set up with Tokico but if the GC w/ the Koni set up is drivable then thats what Im gonna get. OR also how about the Cattman Coilovers? Are they better quality than the GC? Thanks
Old Mar 15, 2002 | 10:09 PM
ecko's Avatar
my gc are pretty good even with the stock struts. but the rear rattles. and when i turn the steering wheel all the way to the right, the gc squeaks a bit, but otherwise regular turning and driving it dont squeak at all. just annoyed with the rattling. barely can tell though.
Old Mar 15, 2002 | 10:19 PM
MaxedOut2g's Avatar
sooo
so what you're saying is that if i want GC, i can only use tokico or koni struts? what if i want to use kyb-agx [for example], i wouldnt be able to use em?
atw
Old Mar 16, 2002 | 07:27 AM
jhans114's Avatar
Re: Re: sooo
Originally posted by yo_its_ok
When you order, be sure to mention what shock combo you would like to get...its all about the red perch that has different Inside Diameters, and its honestly not that great of difference.
As for question about Cattman Coilovers, are nothing like the GCs.
CCs are a fully developed system.(somewhat) Incorporate adjustable height, and camber control via a upper camber plate.
GCs retain height adjustability, but that's it, the shocks are up to you, as well as opting for a camber plate or bolt.
When you compare any true Coilover set vs a coilover kit. There is no comparison.
I agree that the Cattman is a full coilover system but my question was does it squeek or rattle and how is the ride. I dont mind spending the extra money to get the CC but if the make the same noises and they also rattle then Ill go with GC. Thanks
Old Mar 16, 2002 | 10:40 AM
max'n out's Avatar
Re: Re: Re: sooo
The cc ones for the pre 2k's are supposed to be great from what Ive read from others on here. I can tell you for the 2k, the ride is great, you can adjust the firmness, camber, and height. On mine there are some minor rear noises. I think at this point its only from the metel to metel contact.
Old Mar 16, 2002 | 10:19 PM
MILANO
Re: Re: yes
I had Ground Controls and Tokico Blues on my 2K2. They would rattle and squeak like crazy. Couldn't stand them. Although on occasion I would use a high pressure washer to get the sand out of the spring, then spray some lube up in there and it would go away, for awhile than return again. Looked sweet, sounded like a cheap setup, and it was $700 shipped from Stillen to CT.
Old Mar 17, 2002 | 07:42 AM
woosh's Avatar
Non-squeaky setup???
So,
It seems alot of ppl have pleasing performance setups + squeaks. Is there anyone with a setup that is just firmer/better than stock and no squeaks? Or has anyone found a long term cure for the squeaks?
Old Mar 17, 2002 | 02:28 PM
woosh's Avatar
Re: Re: Non-squeaky setup???
Eibachs, KYB AGXs, custom upper strut mounts, FSTB, RSB, and RSTB.
AWESOME~~!
Hey Hogan,
Is it the custom upper strut mounts, that eliminates the squeaks?
Cause I think I've seen someone on here mention they have the Eibach and KYB AGX's setup and it squeaks.
If so, how much work/dollars are we talking for the custom strut mount work and like you said earlier how hard is this to maintain if something goes wrong?
pfsssh
woosh!
Old Mar 19, 2002 | 10:30 PM
Trunksu's Avatar
Re: Re: sooo
oops, I didn't know we were suppose to mention the shock combo when ordering the GCs. I already got my GCs and I was aiming with Tokicos, do you think it's possible I got the wrong GC? And what's with all this squeking I'm hearing about? Is it because of the GC or the shocks, or the combo? (i'm starting to hear the squeking when i make a full turn such as a u-turn). Is the rattling THAT loud? I'm starting to get paranoid :P
Old Mar 21, 2002 | 12:48 PM
max'n out's Avatar
Re: Re: Re: Re: Re: sooo
Jayson, Confused used some rubber gaskets and we put them on the top hat and on the perch, once in a while hear a squeak, but the metal banging has stopped, unless it was on the lift and we bring it back down and the springs don't settle right away.
I remember the first time I lowered the car off the lift and it made a loud banging noise, I thought I broke something, and Confused was laughing cause my face turned pale white, and he said the springs just settled in....
kewl, but will the rubber last? What type is it and what was it orignaly ment for, or did you get it custom made? I don't think the metel perch is the problem, most coilovers are like that(metel to metel on the perch). I think the problem may be the top hat doesn't really have a way for the spring to lock into (if you will) kinda like a dipple to settle into, but just an idea. Did you feel any adverse afects of the rubber?
Old Mar 21, 2002 | 02:17 PM
SuPedUpCiViCGrL's Avatar
I have gc coil overs and they squeek like crazy. but then again I own a civic.
Old Mar 22, 2002 | 02:40 PM
max'n out's Avatar
Re: Re: Re: Re: Re: Re: Re: sooo
LoL...it was a rubber sheet, and made it fairly tight, it eventually wears out and falls off. Trying to make some polyurethane coil covers, so it wil reduce the clanging sound.
I know GC used to have Polyurethane upper cushions before, I don't remember if they still offer it, but doesn't hurt to ask.
Rubber quieted things for a whole day, the next day the sounds were back.
Dizam, I knew they woun't last long, but wooooo one day is a little shocking. I contacted severel companys about some poly joints but got blown off, so who knows, but i din't ask gc. I looked at the rears today on the lift, and noticed (now I havn't seen the car in months) but noticed an odd amount of paint coming off of the uper mount. Now of course there gonna chip a little where the spring sits, but to me it looked like it was bouncing around the mount a little. So maybe having a recessed section where the spring could "lock" into might help. Maybe that should be the upgrade Brian should look into for gen3.
MAXIMA_STYLE
112
Nov 5, 2013 01:00 PM
SSJRICH
Apr 23, 2013 03:44 PM
po8pimp
Sep 14, 2007 03:33 PM
evil_spork
Jun 9, 2006 08:45 PM
evil_spork
Jun 9, 2006 04:04 PM
