Addco rear sway bar from custommaxima
Old Mar 20, 2002 | 07:30 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Does anyone know if I get the addco bar from Greg if it comes with the urethane bushings like the one on cattmans site talks about. The site says it has bushings but doesnt specify which ones. If you have know or have ordered a bar from him, just let me know which bushings it comes with. Thanks in advance.
Old Mar 20, 2002 | 07:38 PM
Jeff92se's Avatar
I'm needing a caw
All addco swaybars come w/ urethane bushings.
Old Mar 20, 2002 | 07:41 PM
MaxedOut2g's Avatar
Re: Addco rear sway bar from custommaxima
hey, i dont think you read it too carefully, but its all good
Adding a rear anti-sway bar is a crucial step in upgrading your suspension. This bar makes the rear of the Maxima more rigid, therefore eliminatng body swaying around corners. Most people notice a drastic increase in control at high speeds. Easy to install, adjustable, and comes standard with ADDCO's urethane bushings. Available in two finishes: gold zinc-chromate plating, and black powdercoated.
also, if i go w/ this RSB, i could save like over $100 compared to Stillen, is it better to pay the xtra 100 or stick w/ addco cuz i know it has had sum problems
atw
Old Mar 20, 2002 | 07:43 PM
sloppymax's Avatar
WOW-- i really need to study/work less.
Old Mar 20, 2002 | 08:02 PM
bernie2000se's Avatar
If you know someone who has installed them, they come out right(ADDCO) there is a little trick to them, the bushings need to come closer togther than the instructions say, that will eliminate just about every problem.
I know it took 2 times before we finally got it down, with no more noises.
Old Mar 20, 2002 | 08:57 PM
MaxedOut2g's Avatar
ADDCO it is..wooohoooo!...getting a lil avaricious, but possible to find sumwhere for less than 115?
atw
Old Mar 21, 2002 | 12:12 PM
sloppymax's Avatar
bernie2000se
thanks for the heads up on the install.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
