how to change radio
Old Mar 21, 2002 | 08:15 AM
pfototo
how to change radio
Does anybody knows how can I change my radio. I cant find any screws
Old Mar 21, 2002 | 08:26 AM
Phydeaux's Avatar
Re: how to change radio
Pull out the little tray directly in front of your shifter. You will find screws that will let you remove the assembly around your shift assembly. You should also find that you can flip up the vents directly above the radio where there might also be screws (I don't recall exact details on this). Eventually you will find that the radio and climate controls will come out as a unit by going in through the top and bottom.
Old Mar 21, 2002 | 10:01 AM
pfototo
Re: Re: how to change radio
I did but the top part , just over the ac vent is not comming out. Is there a screw or I should pull harder?
Old Mar 21, 2002 | 12:07 PM
soundmike's Avatar
Very sound, Mike
Re: Re: Re: how to change radio
Use a prying fork covered with cloth and insert it between the plastic and the dash vinyl. Slowly pry those clips off. It will take a certain amount of effort.
mikeg75
Nov 30, 2015 05:12 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
