Eibach vs. H&R throughts?
Old Mar 21, 2002 | 08:59 AM
kpark's Avatar
I've searched the boards but to no avail. I was thinking about getting H&R springs for my SE. I don't want a harsher ride. Everyone seems to think that H&R are softer than Eibachs. But are these people with SE's or GLE/GXE's? The guy at my local performance shop seems to think that Eibachs are the best choice. If I get Eibachs, will the ride be a lot more harsh than my stock SE setup? I kinda want the BMW feel with a good combination of ride comfort and handling. He says Eibachs will do that. I'm so confused.
Old Mar 21, 2002 | 09:05 AM
N1sMO's Avatar
Re: Eibach vs. H&R throughts?
I had H&Rs on my 4th gen and I have Eibachs on my 5th. I like the Eibachs better, it's not harsh like people have said. But I will say H&Rs are softer, but that's not always good. And as far as the BMW feel comment goes, I guess he's the expert but I'll add that the ride does seem more European Hate that stock floaty suspension.
Old Mar 21, 2002 | 09:42 AM
maxman00's Avatar
Re: Re: Eibach vs. H&R throughts?
what did you go with for struts? My bro has eibachs on his 4t gen, and you feel everything and the steering wheel jolts a little on good bumps. Is this normal?
Old Mar 21, 2002 | 09:48 AM
Galo's Avatar
Maxima Pilot
Having installed Eibachs and Tokicos (long)
on my '01 SE a few weeks ago I can tell you the ride is indeed a tab firmer -but its a nice firm...not harsh in any way, just well-damped firmer -but that's more a result of the shocks than the springs.
Having sold a Bimmer (540 six-speed) in my home country before relocating to the US and buying my Max here I can tell you some philosophical differences in suspension setups between European and Japanese manufacturers you can compensate (improve) somewhat with the Eibach/Tokico (or Koni) combo but not with the springs alone.
Typically, Euro cars have soft springs and tight shocks -particularly tight on rebound...when the shock is extending/recovering after a jounce. Japanese performance cars tend to be more heavily sprung but softer damped, that's why they ride harsh but still 'float' a bit sometimes. On a BMW E39 (5-series) the front suspension is mounted on a subframe so..that's another reason why the 5-series are so 'buttery' in ride.
For ride as well as handling, the ideal setup which would more closely approximate a BMW-like ride would be same rate springs as OEM (or just a tad stiffer) and then good shocks such as Tokicos or Konis -particularly the Konis.
Sadly, all lowering springs are stiffer than the OEM spring; some more than others. But, since neither Eibach nor H&R will give actual spring rate data (lbs/inch of compression) we're stuck with subjective impressions & the various opinions u see on this forum.
Bottom line: going to either Eibachs or H&Rs WILL stiffen your ride from the current setup -particularly since you dont drive an SE now. But, this stiffness will be mitigated somewhat by changing shocks...just a matter of how much $$$ you wanna spend
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
morteljc
Oct 19, 2015 10:47 AM
95Maxi
35
Sep 2, 2015 10:37 AM
official_style
Aug 29, 2015 10:10 AM
