Whats the stock ride height with stock 17s?
Old Mar 25, 2002 | 05:34 PM
theMax's Avatar
I installed maxspeed springs and didn't measure the orginal height.
Now its 26.5" in the front and 26.6" in the rear from the ground to the top of the wheel well after lowering.
Anyone with stock SE with the 17's can measure the orginal height so I can calculate the drop?
Old Mar 25, 2002 | 06:52 PM
soundmike's Avatar
Very sound, Mike
Re: Whats the stock ride height with stock 17s?
It was dark outside so i could only measure to the point that was visible to me... from the ground to the fender line (e.g. the curved part of the fender closest to the wheel)
Front: 28"
Rear: 27 1/4"
These are rough measurements given i had to use a 12" ruler to measure this but that should be pretty accurate. Btw, all wheels are at 32psi (just verified this yesterday)
Old Mar 26, 2002 | 01:48 PM
theMax's Avatar
Re: Re: Whats the stock ride height with stock 17s?
Originally posted by soundmike
Front: 28"
Rear: 27 1/4"
Thanks! Thats a about 1.5 in the front and .75 in the rear at 30PSI for me.
I also checked the passanger side and measured 1/8" (.125")lower but I can't tell by looking at the car?
(26.4" front and 26.5" rear)
Old Mar 26, 2002 | 02:25 PM
Matthew's Avatar
Re: Re: Re: Whats the stock ride height with stock 17s?
...How do the springs ride in comparison to what your stock ride was like? Is it a lot harsher? How hard are they to install???
Old Mar 26, 2002 | 03:38 PM
Tony Fernandes's Avatar
Re: Re: Re: Re: Whats the stock ride height with stock 17s?
I just installed my springs a few weeks ago. It lowered the car 1-1/8 inch in the front and 5/8 inch in the rear.
Didn't really change the roughness of the ride at all. Handling showed a marked improvement.
Tony
Old Mar 26, 2002 | 08:14 PM
theMax's Avatar
Re: Re: Re: Re: Re: Whats the stock ride height with stock 17s?
Tony
I'd agree. The ride is real close to stock but a little stiffer over bumpy roads. Real stable at high speeds and in turns. A great improvement for under $100.
The install was relitively easy. We did to max's in 6 hours. I would reccommend a friend to help, as the hardest part was to line up the struts for reassembly.
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
jaydot901
Sep 29, 2015 01:18 PM
