Need Low-Cost Exhaust
Old Mar 28, 2002 | 07:29 PM
suds1's Avatar
I'm looking for away to mod my exhaust without spending $500 on an exaust system.
I don't want the exhaust to be any louder (a little will be fine) and I don't want to do anything that will require me to fix any oxygen sensors. At first I thought about using a larger diameter pipe but the guy at the exhaust place said that the change in back-pressure might mess up the sensors.
I am thinking of going to the exhaust shop in my town and doing this:
1. Do away with the resonator (What the heck does that thing do anyway?
2. Replacing the stock muffler with a more "free-flowing" one.
3. Replacing the stock SE oval tip with some sort of dual-style tips.
I know this will not help much in the performance department, but it will give it a more unique look and maybe sound than the stock exhaust (and shouldn't cost but about $150)
Suggestions?
Old Mar 28, 2002 | 07:33 PM
cobymoby's Avatar
If you want 5-7 horses, or .2 sec off your 1/4 mile, you can go with my intake for $59.60 and free shipping.
In April the price goes up to $74.50 plus shippping.
Old Mar 28, 2002 | 07:40 PM
20 MAXIMA 02's Avatar
Cheap/low cost/NO HP/ALL LOOKS NO GAIN = AROSPEED
why not just save up ur money for an HKS exhaust?
Old Mar 28, 2002 | 08:02 PM
y2kse's Avatar
Re: Need Low-Cost Exhaust
Suggestions?
Actually, you're on the right track. I've tried just about every exhaust combination known to man on my Maxima. If I had it to do all over again, I'd start the way you'd start. Just remove the resonator and see what you think.
If you want a little more sound, audition a few straight-through mufflers. You should be able to pick up a Dynomax or Magnaflow for a fraction of the cost of an HKS.
And tips are simply a matter of esoterics. Install what appeals to you.
None of this will do much to increase performance. If you want to do that, chuck all of these suggestions and just install a Y-pipe. And by the way, your mechanic doesn't know what he's talking about. Increasing your exhaust pipe diameter and reducing backpressure will not affect your O2 sensors. It will, however, affect the velocity at which gases escape the exhaust system. I would NOT increase your pipe diameter to more than 2.5" unless you plan to install a supercharger.
Old Mar 28, 2002 | 08:05 PM
suds1's Avatar
Not a matter of not having the money, just not wanting to spend the money. I'd hate to spend $500 on an exhaust and end up hating it.
Old Mar 28, 2002 | 08:08 PM
suds1's Avatar
Re: Re: Need Low-Cost Exhaust
None of this will do much to increase performance. If you want to do that, chuck all of these suggestions and just install a Y-pipe. And by the way, your mechanic doesn't know what he's talking about. Exhaust pipe diameter and backpressure will not affect your O2 sensors.
Thanks man. I was kinda skeptical too, when he told me that about the sensors. I think he was just lazy and wanted to get rid of me!
Old Mar 28, 2002 | 08:11 PM
y2kse's Avatar
Re: Re: Re: Need Low-Cost Exhaust
He's not much of a salesperson. I'd have sold you a custom-built 2.5" mandrel-bent exhaust system complete with a new resonator and a straight-through muffler for about $350.00. And you'd have walked out smiling!
Old Mar 29, 2002 | 06:04 PM
02MaXiMa_GLE's Avatar
Re: Re: Re: Re: Need Low-Cost Exhaust
I'll take two! One for each side!
G
Old Mar 29, 2002 | 11:25 PM
Y2KMaxGXE-R's Avatar
what a dilemma...You can get away with just replacing the tips, for 30 bucks you can get anything you want. Most ppl here on the .org would suggest a y-pipe as their fav. exhaust mod, which will run you a total of about 300 with install. I think that by changing your muffler you will loose HP. The stock muffler creates the backpressure, and I doubt free-flowing muffler can duplicate that. Its not worth it.
Someone correct me if I'm wrong.
Old Mar 30, 2002 | 07:10 AM
y2kse's Avatar
BACKPRESSURE = TORQUE?
An old hot-rodder's tall tale: Engines need some backpressure to work properly and make torque. That is not true. What engines need is low backpressure, but high exhaust stream velocity. A fast-moving but free-flowing gas column in the exhaust helps create a rarefaction or a negative pressure wave behind the exhaust valve as it opens. This vacuum helps scavenge the cylinder of exhaust gas faster and more thoroughly with less pumping losses. An exhaust pipe that is too big in diameter has low backpressure but lower velocity. The low velocity reduces the effectiveness of this scavenging effect, which has the greatest impact on low-end torque.
The above is excerpted from the following article which appeared in the November 2001 issue of Sport Compact Car:
http://www.magnaflow.com/05magazine/05sportc.htm
Keep in mind that the stock catback in our Maximas is well engineered and relatively free flowing. Based on tests conducted by Sport Compact Car on a custom catback for a 2000 Nissan Maxima . . . a non-production catback designed by HKS specifically for the tests . . . A COMPLETE CATBACK EXHAUST SYSTEM FROM ANY MANUFACTURER SHOULD NOT BE EXPECTED TO PROVIDE MUCH MORE THAN ABOUT A 5HP INCREASE. Most custom catbacks cost in the $500.00+ range. Contrast that to a Y-pipe which costs around $350.00 to $400.00 and yields a 10 to 12 hp increase, and it becomes clear where the performance-minded individual should spend their money initially.
BTW, here's a case in point regarding pipe diameter. Some time ago, a forum member with unlimited access to a muffler shop installed a 2.5" custom catback in his Maxima. After the installation, he noticed that he lost some low-end torque and some elapsed time in the quarter mile. He replaced the 2.5" catback with a 2.25" catback and regained his low-end torque and his elapsed time.
I also noticed a slight loss of low-end torque when I installed my 2.5" catback system. I regained it when I installed my Cattman Y-pipe. It appears that the Y-pipe increased exhaust velocity sufficiently to take advantage of the larger diameter pipe.
Old Mar 30, 2002 | 07:18 AM
Trev_Daddy's Avatar
I was thinking about mufflers as well-A dual exhaust solution..So I would need 2 fairly cheaper mufflers...How loud are the Dynamax or Magnaflow? I don't want real loud..Just slightly louder than stock at idle. WOT is a different story I was wondering if anyone had tried the Flowmaster Delta Flow 40 series or a Borla turbo exhaust on their Maxima's.....
Any help would be appreciated!
Trevor
Old Mar 30, 2002 | 08:16 AM
y2kse's Avatar
Originally posted by yo_its_ok
I've gone through enough set ups and done enough set ups . . .
I second yo's remarks. I've got a stock rear section and muffler on my 2K SE with a Cattman Y-pipe, 2.5" mandrel-bent exhaust piping, and a 26" Magnaflow resonator. The exhaust sound is perfect for me . . . anywhere from a gentle "purr" at lower rpms to a nasty "growl" at higher rpms. And I don't feel like an upset stomach this morning, so I'm not about to tell you how much money I spent before I finally ended up with this configuration.
Old Mar 30, 2002 | 08:22 AM
I've gone through enough set ups and done enough set ups.
-Peace
have you dynoed your car w/different exhaust upgrades? Can you gain anything (or at least not loose) by only replacing a muffler?
Old Mar 30, 2002 | 08:27 AM
y2kse's Avatar
You won't lose anything by replacing the muffler. And the only thing you will gain is more sound from your exhaust. Keep in mind that the stock 5th Gen muffler is VERY expensive and VERY well engineered. The original design is from a Skyline!
Old Mar 30, 2002 | 08:54 AM
y2kse's Avatar
You'll feel a slight loss in low end and lots of noise, especially below 2500rpm w/ light acceleration.
My first exhaust mod was to swap out the stock muffler for a Magnaflow. I experienced very little additional noise. In fact, I kept modifying my exhaust setup because I wasn't satisfied with the amount of sound I got from just the muffler swap. But the sound increased with every additional modification. And when I finally installed my Y-pipe, all HELL broke loose. That's why I ended up going back to a stock rear section.
I mean, I don't know how some of you guys can run a Y-pipe and a Greddy EVO catback at the same time and conduct a conversation when you're driving down the freeway. It's like cruising around inside a hair dryer with the setting on low.
Old Mar 30, 2002 | 09:00 AM
suds1's Avatar
So if I just ad a Y-Pipe and leave everything else stock, I should just expect a slight increase in exhaust noise (like a growling sound) and a slight increase in power? If so, then I think that is what I need.
Old Mar 30, 2002 | 09:01 AM
y2kse's Avatar
Roger that!
Old May 22, 2002 | 11:42 AM
ms.thicknes's Avatar
Y2KSE...master of all thigs rubber --opinion please
Roger that!
thank GOD for that damn search link.....when this thread was popular I wasn't thinking about my exhaust set up....but now I am
unlike Suds1 who wants to increase the sound which will result in a decrease in power by adding a y-pipe
I want to increase the sound and make NO gains or losses to HP.
I like the idea of removing the resonator and welding on some dressy tips. I don't race (and passing other cars on the regular does not count as racing!!!) so an expensice exhaust setup is not what I am looking for....
I was going to replace the stock muffler...but the one that I want is out of dang stock for the next two months (damn you Arex for making me want it in the first place).
sooooooo Mr. Y2KSE....will removing the resonator give me the throaty growl that i so desire???
I don't wanna sound like a whinny honda...and I say that because everytime I hear that loud pitched whine...it's a dang honda
I want her to growl like the maxima/woman she is
opions please!!!!!
Old May 22, 2002 | 12:02 PM
y2kse's Avatar
Re: Y2KSE...master of all thigs rubber --opinion please
In a word, yes. Start by removing your resonator. Then run with that for awhile. It you want a more aggressive sound, change your muffler. But if you EVER intend to install a Y-pipe, keep your OEM rear section. Just trust me on that.
Old May 22, 2002 | 12:29 PM
suds1's Avatar
opions please!!!!!
If you will search again, you will find that what I actually ended up doing is what you are planning on doing. Removed resonator and welded on chrome tips. Search for "Want more sound from stock exhaust?". I have pics, cost, etc. of the setup on my car.
Old May 22, 2002 | 12:42 PM
y2kse's Avatar
Re: Re: Y2KSE...master of all thigs rubber --opinion please
Thanks, suds1.
Here's the link to suds1's thread:
http://forums.maxima.org/showthread.php?threadid=110075
Old May 22, 2002 | 01:02 PM
Re: Re: Re: Y2KSE...master of all thigs rubber --opinion please
Thanks, suds1.
sniff sniff sniff....I love you guys!!!
Old May 22, 2002 | 01:05 PM
y2kse's Avatar
Re: Re: Re: Re: Y2KSE...master of all thigs rubber --opinion please
Thanks, thicknes. We're beginning to grow rather fond of you as well.
Old May 22, 2002 | 03:38 PM
Norm02SE's Avatar
Ok guys.I ordered a R/T Cat and plan to have it installed and have a straight pipe run from it to my stock 2k2 rear section with no resonator.Do you think I will gain anything as far as HP with this set up or will it be all sound.I also have a Frankencar intake as well.Thanks for any advice and I will let yall know how it goes when its complete.
Old May 22, 2002 | 05:22 PM
JohnNixon's Avatar
I'm wondering where I can get a y-pipe w/installation for around $300 bucks. The only two alternatives I've found are the Stillen at $350 and the Cattman at $375 - parts only.
Any suggestions I don't know about?
Old May 22, 2002 | 06:29 PM
y2kse's Avatar
Pretty much all sound. You may gain a few HP, but nothing to write home about.
Old May 22, 2002 | 08:00 PM
MaDxKiLLa's Avatar
does anybody have a sound clip of ypipe with stock exhaust?
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
