HELP! Check engine light came on....
I don't understand why it would have. I was on a back road driving around and for once I wasn't speeding or anything. So out of no where it came on, didn't flash, blink or anything. Its been on since and I've turned on and off the car a few times. What should I do? The only engine types of mods I have is a JWT intake. Thanks for any help.
Re: HELP! Check engine light came on....
Don't you have a SC too? I thought you had one.
Re: Re: HELP! Check engine light came on....
Check the engine and make sure it's still there...
ADMAN [/QUOTE]
Woo hoo it's still there!
Thanks for the help. I guess I'll end up doing that. Do you know why it would have gone off? I don't want to reset it if there really is a good reason of why it came on.
There are a few parts missing that I need to order one of these days... but HOPEFULLY I'll be installing it this summer.... knock on wood.
ADMAN [/QUOTE]
Originally posted by y2kse
Seriously . . . reset your ECU.
Re: Re: Re: HELP! Check engine light came on....
If the light came on that means something, at one time or another, failed. If you reset the pcm and it comes back on, take it in. if you lived closer i'd let you use my scanner.
cya
ryan
cya
ryan
Re: Re: Re: Re: HELP! Check engine light came on....
Nope. Sometimes the ECU has a mind of its own. I'd reset it and see if that fixes the problem. If it doesn't, make sure your JWT popcharger is properly installed (i.e., no air leaks, MAF tube O-ring properly installed, etc.) and reset the ECU again. If that doesn't clear the SES light, go to your dealer and have them pull the error code with their Consult II.
The wierd thing is that I've driven the car since the light came on, and I've probably driven almost 100 miles. Then all of a sudden tonight, the light didn't come on when I turned the car on. What the heck is going on? Should I still be concerned? Or does the ECU really have a mind of its own sometimes. Thanks for all the help so far everyone.
Originally posted by PCGuRu2K
If I were you I would just take it to the dealer or a shop to have them run the SCanner on it and pull the code.. How's the car run? Any idle problems with idling, engine?
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
