spinning out
Old Apr 3, 2002 | 05:04 PM
maximillus's Avatar
spinning out
i have a 2k2 se and i was trying to make mah tires spin out so i can make all dat smoke and ****....how do i do it wit an auto?
Old Apr 3, 2002 | 05:14 PM
maximillus's Avatar
i mean burning out...haha forgot wat it was called. i was juss wondering how to burnout wit a 2k2 max aut
Old Apr 3, 2002 | 05:24 PM
remykins's Avatar
Romp on the gas!!!
Old Apr 3, 2002 | 05:33 PM
suds1's Avatar
Re: spinning out
Trust me, you really don't want to have to replace your tires any sooner than you have to. They are not cheap!
Old Apr 3, 2002 | 05:47 PM
KLOOGY's Avatar
L33t BMW Drivah
I am having the opposite problem... I have an AUTO, and when I GUN it , it spins like CR@P !! Are you sure there's not something wrong with your car ??
Old Apr 3, 2002 | 06:30 PM
Padsy's Avatar
Boost.....
Kloogy....your car's just a HOSS!!
Old Apr 3, 2002 | 06:33 PM
maximillus's Avatar
da tire do spin out when i floor it but i was juss wondering how to burnout
Old Apr 3, 2002 | 06:35 PM
My 4DSC
pull up your e-brake and mash the throttle.
Old Apr 3, 2002 | 07:47 PM
djPlayboy's Avatar
pull ebreak and nutral drop it....lmao
Old Apr 3, 2002 | 10:55 PM
KLOOGY's Avatar
L33t BMW Drivah
Put it in Neutral..rev it to 6000 and while still accelerating, put it in DRIVE !! ...Just tell Nissan, " Youre not sure how it happened ?
Old Apr 4, 2002 | 07:19 AM
maximillus's Avatar
if i pull the ebrake and put it from neutral to drive....would dat screw up my car or no?
Old Apr 4, 2002 | 07:23 AM
DenMax's Avatar
hehehaa
Yes neutral drops are counter productive. Pull up the e-brake and floor it. Burn out your overpriced tires and get new ones!! Happy smoking.
Old Apr 4, 2002 | 07:39 AM
soundmike's Avatar
Very sound, Mike
Okay, after reading this i know something's wrong with my car.
If i pull up the e-brake all the way up and floor it the car just moves forward (albeit slowly).
But if i just mash it w/o pulling the brakes up the wheels spin like crazy.
Weird.
Old Apr 4, 2002 | 07:51 AM
DenMax's Avatar
Hmmmm
Weird.
Maybe not. Mine is a 5 spd so it's easier to brake the tires loose initially. My e-brake will not stop my car either from a stop, the car will still creep along while spinning. Front engine/front drive cars have this problem.
Old Apr 4, 2002 | 07:54 AM
soundmike's Avatar
Very sound, Mike
Re: Hmmmm
Hmm. Must've been the weather that day. It was pretty warm and the roads were quite sticky. I couldn't even break loose as easily.
I'll try it by brake torquing and holding the ebrakes. See how that works.
Old Apr 4, 2002 | 08:11 AM
Bulldawg's Avatar
Re: Re: Hmmmm
this is for "maximillus"
if you want to burnout in an automatic here is what you do
-come to a complete stop
-pull e-brake all the way up
-press foot brake all the way down with your left foot
-rev the car to about 2500 or 3000( right before the car starts to move)
-then let off the brake with your left foot while slamming on the gas
This will be about the best burnout you can get with an automatic, without destroying your car. you will get pull forward a little bit.
Another trick to making the tires talk with an automatic is accelerate extremely hard out of a driveway,stop sign, anything that you are starting from a complete stop and then turning 90 degrees. Hammer the gas the cut the wheel sharply. But beware of torque steer, in other words don't do it in traffic.
WARNING-Accelerating extremly hard while in a turn will cause you transmission to fail over time. The spline gear that comes from the differential to the tranny will get worn around the connecting rod.
These shreds of metal will then fall into the tranny and eat up the rest of your gears.
My best piece of advise is to go and play Grand Turismo, you can burn out all you want there and cause no damage. Or if you have friend with a manual, go burnout in his car. The burnout that you will get from the automatic is not worth the damage that it will cause. I used to do them on my '95 max and it was a blast, but i ended up rebuilding the tranny twice!! I now have 2k2 6speed and it is much easier to do a burn out and less harmful to the car.
peace
Old Apr 4, 2002 | 12:10 PM
GuZo's Avatar
I have a 2k2 Max, Auto , only 800 miles on it, If I am just stopped and floor it, my tires will completely smoke out, i've only done it a couple of times, i don't like attention, but it is pretty cool seeing an automatic spinning out like a stick.
Old Apr 4, 2002 | 01:26 PM
Burton069's Avatar
go in reverse as fast as you then drop it into drive, hammer gas, and watch the smoke (of course that will really **** up your car)
Old Apr 4, 2002 | 01:48 PM
suds1's Avatar
Why would you want to pay $30K for a car and then do something like this that is obviously going to damage your tires, transmission and probably your engine?
I thought the thrill in these cars was the fact they are fast and fun to drive (in a foward motion).
Old Apr 4, 2002 | 02:21 PM
ssp34's Avatar
I agree... don't you remember your vows? "To cherish thy vehicle, till 200,000 miles do you part? (Or you hit the lotto and get some insanely overpriced sports car...)"
You will totally f-up your car by trying to burn out on a FWD car... I wouldn't recommend it... at least not on a 5th gen.. its basically brand new... forward motion.. forward motion..
Old Apr 4, 2002 | 03:13 PM
lcf's Avatar
lcf
heh, its not safe, but if you want to spin out... put on some really worn out tires. (like mine! wanna buy'em?!) yeah, im saving up for some nice tires and my nitto450s are really worn out. when i give it a lot of gas on a slight turn, my friends tell me they can see smoke!!!!!!!!! hahahaha. i need new tires! bah...
Old Apr 4, 2002 | 03:18 PM
Greg's2kGLE's Avatar
Pour bleach on the pavement. Make two puddles (one for each wheel), roll in them, and floor it. Smokin' (I have never done this, but I hear bleach works)
Old Apr 4, 2002 | 04:34 PM
Ironlord's Avatar
Well, being young i like burnouts as well, but not too many on my poor max. but, i find my car doesn't do them for crap. only way i get consistent spin is on wet roads. on my old car (94 grand prix), i did some videos for a class, and put liquid detergent (dawn or something similar) all over your tires and they light up like nobody's business. a lot better than bleach on your paint too. plus you leave PERMANENT marks on the road. trust me on this. anyway, i wonder if my max is underpower from the factory? 88 mph is my highest trap speed in quarter and no burnouts?
Old Apr 4, 2002 | 05:00 PM
soundmike's Avatar
Very sound, Mike
Ya. That works. That's how Steve (dmbmaxima88) did it on his 2k2. Search on the board for a video he posted a while back.
Old Apr 4, 2002 | 05:05 PM
djPlayboy's Avatar
the last time i played burn out i was at hub city drag way in mississippi a few months ago and a guy in a mustang cobra came up to race and he just started laughing and told me i couldnt bark my tires, i jsut told him to wait till we stage... he did his lil burn out a lil smoke and he was like beat that... i laughed and started smoking em down next thing i know theres smoke everywhere i couldnt even see his car 6 feet from me. after that he wouldnt even race me...
Old Apr 4, 2002 | 05:08 PM
djPlayboy's Avatar
oh and those were the stock toyo tires on the car and yeah i had to replace em but when i got home that evening my new tires from tirerack.com came in
Old Apr 4, 2002 | 07:41 PM
suds1's Avatar
Hey lcf, I noticed you also have NT450's. Man we have almost the exact same car! How have your tires held up? Mine are loud as crap. I can't wait to get rid of them.
Old Apr 4, 2002 | 09:08 PM
KLOOGY's Avatar
L33t BMW Drivah
After owning 2 cars with More than 350 Hp , and both sticks.. I found burnouts to be my ENEMY , not something I wanted. Thats I was happy when BFG made Drag Radials.. even though I broke many motor mounts.... I am not looking to make my Maxx smoke it's tires... Even though I have done it 2 times..and boy can they smoke.. for an auto !
Old Apr 4, 2002 | 09:31 PM
20th maxstyle's Avatar
My AE auto has the ability to turn of the Traction control, make sure that is off if it is possible in yours. DON'T EVER NUETRAL DROP. ARE YOU GUYS INSANE? This is why I had to replace my trans after one year. I would shift when a light would turn green, and go to nuetral when i would slow down. Don't do it.
Old Apr 4, 2002 | 09:38 PM
lcf's Avatar
lcf
they were loud as hel (sounded like i was driving a lifted 4x4 wtf?!)!! but as soon as the treads disappeared... they got quiet haha!! theyre practically bald right now!!!
i wanna get new wheels and tires. move up to the 18" but cant afford it at the moment. im getting a set of the clears for it soon with the group deal going on right now on the org... and maybe the maxspeeds i want to drop it a little! thats it for now, phew. mod fever, heh.
btw, nice car. what interior u gots? leather? cloth?
Old Apr 4, 2002 | 10:29 PM
KLOOGY's Avatar
L33t BMW Drivah
Yes of course you are turning off your tration control....As far as neutral drops.. I was making a light JOKE. Anyone who has half a brain know NOT to do that. Of course, if you are suffering from **** inversion, then read the post !
Old Apr 4, 2002 | 11:03 PM
CometMAX's Avatar
Sounds more like a receipe to transmisson soup to me...
Old Apr 5, 2002 | 05:00 PM
suds1's Avatar
I've got frost leather with soon to be AE pedals if they ever come in. I definently like leather better than cloth, but I have to say these are the crappiest leather seats I have ever seen. They are hard as rock and my driver's seat is already cracking by my left hip.
Old Apr 5, 2002 | 05:22 PM
lcf's Avatar
lcf
i hear you, they are not very comfortable.
definitely not as comfortable as my fathers q45.
alahjahwan09
18
Sep 21, 2015 09:12 PM
97_GXE
Sep 15, 2015 06:47 AM
sc10692
Aug 9, 2015 09:37 AM
RealityCheck
Aug 5, 2015 06:18 AM
Synki
Jan 8, 2001 06:13 AM
