Need to know what sealant you guys are using to STOP CONDENSATION in clears....
Old Apr 3, 2002 | 06:58 PM
K Pazzo 6's Avatar
ok i've had clear for about a year & used GOOP to seal it so no condensation get thru, but i guess it doesnt work that good b/c a year later & there's condensation in there....I ordered new clears b/c I couldn't get the condensation out & it bother to see them like that....So I need to know what you guys are using that WORKS! Thanks
Old Apr 3, 2002 | 07:59 PM
Smokie5s01's Avatar
All I did was to cut a little duck tape and put it on the inside of the lights along the seam.....it has worked fine for me....I only did this because I got my clears at about 12 at night and I didnt feel like waiting. I planned on doing the sealent but I havent had any problems so I never did it......
Old Apr 3, 2002 | 08:02 PM
max'n out's Avatar
RTV Clear silicon.
Old Apr 3, 2002 | 08:07 PM
Maximum Velocity's Avatar
I used just regular clear silicone.
Old Apr 3, 2002 | 08:58 PM
Maxtor
Clear Mono silicone
Old Apr 4, 2002 | 01:24 AM
zgrm100's Avatar
Originally posted by Maxtor
Clear Mono silicone
i have a question. one of my front markers is loose and it wables if i touch it. i guess i loosend up the metal thingy when installing it and now its not as strong. How can i fix this?
thanks
Old Apr 4, 2002 | 04:15 AM
PCGuRu2K's Avatar
I used clear silicone on mines. But I took my time doing it and made sure I fill in the gaps.. So far so good..
Old Apr 4, 2002 | 07:14 AM
Nick Exxon's Avatar
Originally posted by max'n out
RTV Clear silicon.
Ditto for me. Works so far and there has been a lot of rain where I live for the past 30-45 days, although the car is garaged.
Buzz
Old Apr 4, 2002 | 07:20 AM
Nick Exxon's Avatar
Loose side markers
thanks
You might try buying a sheet of foam squares with an adhesive backing; you can find them at any hobby store such as Hobby Lobby. They're usually used on the backs of pictures that are hung on a wall. I put them on my rear clear markers when I originally installed them and they work well.
Buzz
Old Apr 4, 2002 | 08:56 AM
Larrio's Avatar
The Definitive AE Master
I used aquarium tank sealant. I got rid of the loose shifting by tearing off the padding on the stock lights and placing them onto the new clear ones
Old Apr 4, 2002 | 12:34 PM
Solution to the condensation problem
http://forums.maxima.org/showthread....3&pagenumber=4
You have to scroll down some.
Old Apr 4, 2002 | 02:49 PM
K Pazzo 6's Avatar
RTV Clear silicon.
Where can I found or buy this at? Home depot-- b/c I remember going to ace hardware here in chicago-- and they were like whats that?
Thanks for the info so far.....
Old Apr 4, 2002 | 07:08 PM
K Pazzo 6's Avatar
bump
Old Apr 4, 2002 | 07:31 PM
Green_2's Avatar
Bury your clears with condensation in a bag of white rice. It works...The moisture should be outa there in a day or so.
Old Apr 4, 2002 | 07:34 PM
max'n out's Avatar
Wal Mart
Old Apr 5, 2002 | 03:56 AM
PCGuRu2K's Avatar
You serious, that actually works? What happens, the grains suck out the moisture?
Old Apr 5, 2002 | 06:02 AM
Bulldawg's Avatar
Did you ever wonder why sometimes a little diners you will see white rice in the salt shaker. The rices take the moisture out of the air to keeps the salt from sticking together and preventing it from coming out of the shaker. Rice is extremely good a sucking up moisture.
really works try it!!
peace
Old Apr 5, 2002 | 08:44 AM
warrlocked's Avatar
I will try the sealant when I get mine. I just got in on the Group Deal that is going on. Right now we are at $45.95 per set...and that includes insurance and S/H. What did some of you pay?
Old Apr 5, 2002 | 03:57 PM
Green_2's Avatar
Hehe...yep. Just like what Bulldawg said, white rice sucks up a lot of moisture. My dad had a watch that had condensation in it before. The moisture was gone in a day when he dumped it in rice.
See...a little "rice" can be quite useful sometime
Old Apr 5, 2002 | 06:56 PM
foodmanry's Avatar
Da Roller Coaster!
You can place the side markers in an oven as well. It has to be on the lowest setting of course and you may have to watch it. When I initially installed my side markers they were getting condensation and I stuck them in the oven for about and hour and a half on "warm" which was about 120 or 130. And yes the silicone sealant (aka caulking)is the way to go. I put that on the seams of my side markers and since then no problems. You can get it at any hardware store and even auto parts stores.
Old May 5, 2002 | 05:54 AM
griffy2k2max's Avatar
Re: Need to know what sealant you guys are using to STOP CONDENSATION in clears....
Clear Silicon here too, got a tube from Home Depot, Mine had condensation, believe it or not I dried them by first taking the bulb out and shaking the excess water out then holding them one at a time over my halogen living room lamp for 20 min apiece the reflectors help "cook" the moisture out, I did each one off and on for 3-5 min,cooling in between so I wouldn't melt them, then repeated the process, laugh if you want but it worked then I sealed them and no more condensation.
Cotozic
Jun 28, 2017 08:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Quickgtp
Aug 27, 2015 02:13 PM
maxipower
Aug 21, 2015 11:10 AM
kirkhilles
Aug 8, 2015 10:53 AM
