I think I found the source of my wind noise, the back seal of my sunroof isn't sealing well. I took it through the touchless carwash this morning and watched the water drip through onto the channel inside
. Anyone else having this problem? I'm bringing it into the Dealer tomorrow...Be afraid, Be very afraid....
Pangburn, no problem, so far (car is only a couple of weeks old). I thought that I had read that Nissan had the best sunroofs installed. I hope they can fix it for you. I, too, would hate to take it to the dealer...but in this case, you really don't have a choice. This is definite warranty work. Good luck and let us know what happened.
My 89 eventually developed a leak problem (ruined the whole trip panel around the window). A service mechanic that I trust said that the sunroofs are not designed to be watertight. They are intended to slow the water down. There are drain lines leading from behind the sunroof that go down the back quaterpanel columns, through the trunk and out. Now obviously if you are hearing wind noise the problem is more significant but I just wanted to let you know what I was told about this issue.
15 mins at the dealer... its two pieces of trim that pop off and 4 bolts. great care should be taken so they dont misalign it (sideways or front to back) and bind the motor, but it should be easy for them. yes, you may still get *some* water, but there shouldnt be open gaps. Our PF had that, easy fix.
