Stopped at a light - clutch in or out?
I have heard that when you stop a light, you can save wear and tear on the clutch by shifting into neutral and letting the clutch out. Any truth to this?
I have always sat at a light in gear, with the clutch in. In my old Civic, when I sold it, the original clutch was still going strong after 6 years and a 115,000 miles. The original clutch in our Integra had 13 years and 96,000 miles (mostly local driving) when we sold it to buy our 2k2 6 spd Max, but I suspected it was going to have to be replaced soon. I really can't believe that sitting in nuetral at a light can make that big a difference.
Just curious if anyone else had heard this...willing to change my ways if there is a strong argument to do so...
Re: Stopped at a light - clutch in or out?
But on the other hand, keeping the clutch in will cause additional forces on bearings that might cause them to fail sooner.
Buddywh
Re: my money is on leaving it in nuetral/clutch out..
Originally posted by TimW
I think the clutch material will outlast the throwout bearing.
"Holding down the clutch pedal while at stop lights (which nearly everyone I’ve ever observed does) causes the throwout bearing to overheat, resulting in premature wear and failure. It also stresses the pressure plate and causes friction on the clutch disc. Therefore, shifting into neutral and letting the clutch pedal out while stopped will lengthen the life of your clutch by at least 20,000 miles, saving you money and aggravation."
Source: http://wheels.mainetoday.com/caring/000526auto.shtml
Originally posted by got rice?
pop into neutral and coast to a stop - let the brakes do the work then rest my left leg
Burning up $400 in brakes is a lot cheaper than $5,000 plus in engine/transmission/clutch repairs!
BuddyWh
Thanks for the response guys. Looks like it is time to change an old habit! I will be popping it into neutral from now on... you would think this would be written up in the owner's manual...
Originally posted by BuddyWh
Excellent point! I imagine racers can effectively use the engine's compression for braking to delay brake fade, but unless you race on a factory team... where someone else pays for the repairs... use the brakes to bring the vehicle down in speed.
BuddyWh
BuddyWh
Axel
Originally posted by MaxRU
I do believe it is...
"When the vehicle is stopped for a period of time, for example at a stop light, shift to N (Neutral) and release the clutch pedal with the foot brake applied."
Escpecially on lights I know, I coast to them in neutral. Otherwise it's neutral and p-brake.
All the while still gaining on everyone in back of me!
Surprisingly, since I have my Max, I am one of those sprint to the next light *******s. :-(
Originally posted by y2kse
Ooooh, you ARE good, MaxRU. In the 2K Owners Manual it's on Page 5-12, to wit:
tsi6001
Oct 3, 2022 10:23 PM
carlosvq30
Aug 17, 2015 11:32 AM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
