Pacesetter STS question please anwser..
Old Apr 22, 2002 | 07:29 PM
ThisMax2NV
I have a pacesetter STS from custom maxima.com. I had it installed and it dosent feel right. It feels sticky when I shift and is not as smooth as I thought. Does anyone else have this problem or situation? If so how did you fix the problem. Any comments opinions and suggestions are welcome. Thanks.
Old Apr 22, 2002 | 09:08 PM
Coldboot-SE's Avatar
Pacesetter STS
ThisMax2NV,
I just got done with the install myself, I think one reason that it feels tighter, less smooth, is at the pivot point you now have what look like Oilite bushings rather than some teflon-like flange faces.
Other reasons for a less effortless shift is the loss of mechanical advantage ( change of fulcrum point ) and the added length increases the tension on the retaining spring.
all and all you'll get use to the more concise pattern, I know it was a concern for my wife when she first drove it after the conversion, but now we both like the sportscar feel.
dave
Old Apr 22, 2002 | 09:35 PM
ThisMax2NV
Re: Pacesetter STS
Originally posted by Coldboot-SE
ThisMax2NV,
dave
So your saying that its susposed to feel this way and that it will be like this forever. Ok. Well I just changed my shift **** it was a RAZO shift **** from japan and weighed almost as much 2 cans of soda this is no lie. I bought it for 85$ and now that I changed it to a lighter shifter it feels different. Also is there another way of shortening the shifter? I was thinking about cutting it and then threading it again. Is this a good idea or not. Is the shifter hollow? Thanks for the reply.
Old Apr 22, 2002 | 09:53 PM
Pacesetter STS
ThisMax2NV,
I'm pretty sure the tighter notchier feel is common, and sure others will weigh in on this topic considering how many just installed this mod. I know it's not binding and there's no issue with the heat sheild as I've cut away all the intrusions.
As far as shift lever height, I can see nothing wrong with taking off an inch or more, but you can't go back. the STS is solid steel and like yourself, I too have a aftermarket **** which is secured in place with 3 set screws and not even using the top treads provided.
you might try grabbing the lever under your shift-****, when shifting, to feel if the reduced height will effect the shifting effort.
hope this helps
dave
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
