Redline Transmission Fluid (ARrrrrgggggggggg)
Old Apr 24, 2002 | 06:08 AM
Bulldawg's Avatar
O.K.
I replaced my transmission fluid with Redline MT-90. The instructions on www.greghome.com were very easy to follow, Thanks. I have had the fluid in for about 2 1/2 weeks. At first, everthing was smooth(no notches between gears),it was great. It even allowed me to get the car into first while still rolling. Recently(the past two days), I have noticed that the transmission is going back to its old ways, the notches have returned, I can no longer put it into 1st while rolling. It almost seems as if it has gotten worse, sometimes I really have to tug on the the stick to get it into 2nd and 4th.
Has anyone else had this problem?
What is causing it?
BTW I have a 2k2 6spd
Old Apr 24, 2002 | 06:13 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Redline Transmission Fluid (ARrrrrgggggggggg)
Originally posted by Bulldawg
O.K.
What is causing it?
First thing I would check is make sure the fluid level is still where it should be. Might have "settled". I would also dip my finger in there to smell to see if that might reveal in info also.
Old Apr 24, 2002 | 07:11 AM
sepitrol's Avatar
O.K.
What is causing it?
I noticed the same thing with my car... (2000 5spd though) I've checked for leaks multiple times and haven't found any. It seems to me that I have just got "used" to it now. My wife drove the other day and noticed that it shifted smoother. This was after it had been in 2 weeks and I felt the same way you did.
Sep
Old Apr 24, 2002 | 07:38 AM
Bulldawg's Avatar
Did you do what colonel suggested?
I haven't done it yet just curious if you did, and if so what you found?
Old Apr 24, 2002 | 07:43 AM
sepitrol's Avatar
No, I haven't. You can try that if you think you didn't get enough fluid in there. Mine took a little over 4.6 quarts and then a small
amount dribbled out, so I know it is full.
I'm not sure about your tranny though, I think the 2002 6-speed takes right at 3 quarts?
He is right, the fluid should be right under the fill hole.
Hope that helps.
Old Apr 24, 2002 | 08:03 AM
Bulldawg's Avatar
Mine took a little over 2 1/2 quarts, which I think is about what every one else was getting. But I will check to make sure the level is right under the fill hole.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
