KYB AGX Availability
Old Apr 26, 2002 | 08:38 AM
maxman00's Avatar
Sorry for beating another topic to the ground, but does anyone have a definitive answer on when AGX's will be available for 5th geners???
Old Apr 26, 2002 | 08:47 AM
Now use the 4th gens AGX, and shave the top of the strut mount, when you are doing the suspension you will understand. Its been done and it will work.
Old Apr 26, 2002 | 08:52 AM
maxman00's Avatar
thanks for the info! If I have to wait too long, I will modify them. I am not in a rush, so I would prefer to wait. Have you done this?
Old Apr 26, 2002 | 09:07 AM
[maxi-overdose]'s Avatar
Re: KYB AGX Availability
cattman has the modified 4th gen AGX to 5th gen....u have to get the parts from 4th gen to make it compatible. 450 for the shocks, 50 for the parts.
kinda expensive
Old Apr 26, 2002 | 09:28 AM
I've done the modifying.
$345 shipped for the AGXs + 5/minutes per strut mount on the grinder.
Old Apr 26, 2002 | 09:32 AM
that's a good deal....did u have to modify the shock too?
Old Apr 26, 2002 | 09:37 AM
No, just upper strut mount had to be modified. Could always use 4th gen upper mount.
BTW watch your ABS lines on 5th gen if you do the install.
Old Apr 26, 2002 | 09:47 AM
alright...thx for the info
I will sure bug u around when I get mine installed....
Old Apr 26, 2002 | 10:21 AM
No problem at all.
-bug away.
Old Apr 26, 2002 | 11:13 AM
Stealth Max's Avatar
Can I get a ride in the modified AGX Maxima?
Old Apr 26, 2002 | 11:18 AM
Ride in Golden Glory's car...even at 2" down, I'm still lower than him.
Old Apr 26, 2002 | 11:50 PM
maxman00's Avatar
Looks like modification is the only choice The following is a reply from someone at KYB.
At this time there are no plans to manufacture the AGX's for the 5th Gen Maxima.
Possibly in 1 to 2 years.
Troy Horn
KYB America LLC
Phone (630)620-5555
Fax (630)620-8133
troy@kyb.com
maxima-junky
Oct 7, 2015 06:13 PM
soybeanz
Sep 25, 2015 10:46 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
