frakencar --> Check engine light
Has anyone had their check engine light come on after installing a frankencar intake on their 2k2 max?
I checked everything, its looks installed correctly and reset the ecu by disconnecting the battery for 20 min. and theres still a check engine light on. I compared the intake to the frankencar website and they look exactly the same.
Re: frakencar --> Check engine light
This has most often been the result of reconnecting the battery and starting the car before reconnecting the MAF adaptor which will dump and error code and cause the CEL to come on regardless of what intake you have purchased.
quick question. when installing the franken car, should you rotate the MAF sensor 90 degrees so that the wire harness that plugs into the top of the MAF doesnt get smashed by the hood? Will doing so change the way the car runs? just wonderin
Originally posted by DrVolkl
Yikes. Maybe I'll wait for Injen...
Most of the people on this board are experiencing problems with the FC intake because they did not follow the directions to the letter. I have seen
1) Installing MAF backwards
2) Not including the rubber grommet in the MAF tube assembly
3) Not installing all tubes correctly
4) Not doing the correct sequence of electrical disconnecting and reconnecting
It does not matter the manufacturer...Berk, FrankenCar,Injen,Stillen... whomever...if you dont follow instructions you will be hurtin. Read ALL of the directions before hand and understand them thoroughly before you do something. Spped is not the issue here....proper install and operation is.
What is "2) Not including the rubber grommet in the MAF tube assembly" this step??
I am doing my install of FrankenCar intake soon.
Originally posted by Colonel
Nope, will not make any difference as I have done the same thing with no problems or CEL.
Originally posted by soundmike
There's also the case of inverting the direction of the MAF piece which not only throws out an error code but also reportedly keeps shutting down your engine.
thats what I did
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
