FRaNKEN CAR TROUBLE
Old Apr 26, 2002 | 05:32 PM
MaDxKiLLa's Avatar
FRaNKEN CAR TROUBLE
I was installing my frankencarintake and my engine does not rev. I put everything in together by taking out stock air box and put MAF into the engine and i reconnectedthe 3 hoses into the intake housing. I connected air filter and everything and clamps are on tight. I skipped a step that said put the ATS in the MAFand just put the rubber on top of it....maybe thats the problem what does ATS stand for....what could possibly be wrong...my engine keeps turning off too..help!
Old Apr 26, 2002 | 05:57 PM
MichaelAE's Avatar
Re: FRaNKEN CAR TROUBLE
Are you saying that you skipped the step of connecting the temp sensor (originally connected to the air scoop near the front of the engine)? Leaving a hole in the Frankencar piping?
Or are you saying you did not reconnect the MAF adaptor after putting everything back in the engine bay?
Old Apr 26, 2002 | 06:00 PM
MichaelAE's Avatar
In other words, was the thing circled in the below picture connected before you started your car for the first time after installation?
Or was it the temp sensor that you didn't relocate to the Frankencar piping (sorry, no photo of that)?
If it was the temp sensor, I couldn't imagine that contributing to engine failure immediately...although it would leave an opening, post filter, in the intake tubing which could potentially cause a large piece of debris to pass into the throttle body and that could be a big problem.
Old Apr 26, 2002 | 06:21 PM
CIRCO's Avatar
MichaelAE is right you need that temp sensor from the scoop near the front of the stock intake piping. Otherwise the hole that its suppose to go in will be taking in way too much air and your car will run like crapolas. If your car takes in too much air or your intake is not connected properly your car will die out over and over again. I think this is the MAF at work. Make sure you relocated that temp sensor.
Old Apr 26, 2002 | 06:24 PM
MaDxKiLLa's Avatar
okay it is in there and it is pretty tite but when i rev engine aboe 2.5 RPMS it struggles and dies out
Old Apr 26, 2002 | 06:33 PM
Colonel's Avatar
Old Fuddy Duddy
Did you
Install the MAF tube correctly? Are you throwing a CEL? are all connectors tight and snug. The MAF connector is spring loaded so you really have to make sure its tight. There is an arrow showing the air flow on the MAF...it has to be going the correct direction. Also make sure that none of the connector band screws are interfering with the throttle body.
Good luck!
Old Apr 26, 2002 | 09:12 PM
MaDxKiLLa's Avatar
lol the flow sign was pointing outwards of engine ntot inward im so dumb
Old Apr 26, 2002 | 09:13 PM
KLOOGY's Avatar
L33t BMW Drivah
Old Apr 26, 2002 | 10:38 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
glad to hear you figured it out ok, that will happend if you install it backwards. did you throw a CEL, it should go off if you disconnect BOTH battery cables for a couple hours from what i've heard. not just one.
Old Apr 26, 2002 | 10:50 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
No offense, but you should probably look into paying someone to install parts for you.
At least the complex ones.
Old Apr 26, 2002 | 10:54 PM
remember medicsonic
october 2001, when i was getting rid of my 95.
"steve my car runs for ***** lately, i think it's my maf, give me yours"
"r u serious, we're at wendy's and it's 11pm"
"yes let's do it"
"grrr ok"
"hey your flow arrow is backwards greg"
"no it's not"
"yes it is"
"omg, i'm a moron"
"yes you are"
"switch them anyway"
switch switch switch, lose bolt switch
"damn i got you rough idle, but the car runs better, and this never happened"
"SUREEE.............."
-steve
Old Apr 27, 2002 | 05:42 AM
RalphW's Avatar
I installed the intake on my 02 and runs fine. Don't know what this temp sensor is..but I dont have any open holes on my intake. Is this different than the 01 intake.
RalphW
Old Apr 27, 2002 | 06:21 AM
Dany's Avatar
RalphW
Yeah I am about to install the FrankenCar Intake too, I don't see any temp sensor in the install instructions. There is a sensor that on the MAF that needs to be reconected, that is about all I see that needs to be reconected.
Where does that temp sensor go? This is on 2002 SE.
Thanks.
Also, Steve so you suggesting unplugging both cables from battery, not just one?
Old Apr 27, 2002 | 06:35 AM
soundmike's Avatar
Very sound, Mike
I'm not 100% sure but here goes.
The 2k/2k1 midpipe has a smole penny-sized hole next to the breather pipe (that long skinny tube emanating from the midpipe). You shuld see it in the photo on this page: http://www.maximanet.org/gallery/album02/aaa
The 2k2 doesn't have this hole and i'm assuming we don't need to relocate anything.
I could be wrong, but that's what i noticed from both pipes (I got the 2k/2k1 pipe by mistake, the 2k2 pipe arrived yesterday but i need to pick it up from the leasing office).
Btw, Steve. I'll mail out the other pipe later today. Thanks for the quick shipment and return shipping!
Old Apr 27, 2002 | 07:21 AM
timby01's Avatar
here's a pic of the weapon-r intake for the 02
Old Apr 27, 2002 | 07:27 AM
mattattax's Avatar
I wonder how much gains those red Xs give. hmmmm j/k ......pic didn't work Nevermind
Old Apr 27, 2002 | 07:30 AM
soundmike's Avatar
Very sound, Mike
Care to try that again?
Old Apr 27, 2002 | 07:33 AM
timby01's Avatar
the pic is working for me
Old Apr 27, 2002 | 07:37 AM
mattattax's Avatar
thx mikey
Old Apr 27, 2002 | 09:08 AM
Dany's Avatar
Weapon-r intake looks pretty good. What type of filter are they using?
I like the blue theme. And that little filter on the side too looks cool.
How much was it?
Thanks.
Old Apr 27, 2002 | 09:14 AM
timby01's Avatar
How much was it?
Thanks.
dragon intake i'm working on getting this guy to do a group deal i paid 165 which wasn't 2 bad list price was 205 the only thing was the bracket they had sent me didn't align right so i had to redrill some holes (same thing happened with my 97 weaponr intake) but wasn't a big deal
Old Apr 27, 2002 | 09:19 AM
Dany's Avatar
Where does that support bracket mounts? Is it in that pic?
Thanks.
Old Apr 27, 2002 | 09:21 AM
timby01's Avatar
Thanks.
support brackets?? didn't have to use any the bracket i was talking about was the one for the maf sensor
Old Apr 27, 2002 | 09:23 AM
Dany's Avatar
Got it, thanks.
Did you notice power increase? Any low end loss?
Old Apr 27, 2002 | 09:25 AM
timby01's Avatar
Got it, thanks.
suprisingly i didn't notice really any low end loss noticed a little bit of a gain but i love the sound on WOT
Old Apr 27, 2002 | 09:34 AM
LouE37's Avatar
Originally posted by dmbmaxima88
remember medicsonic
"yes let's do it"
"grrr ok"
"no it's not"
"yes it is"
"omg, i'm a moron"
"yes you are"
-steve
How much for just the ram air tube w/o the filter?
Old Apr 27, 2002 | 09:39 AM
MaDxKiLLa's Avatar
Your obsessd withthose smilies Well it was just a stupid mistake and i figure it out..i also didnt understand putting the ATS into the tube but then i read and thought alittle and was like duhhh u have to take thatblack piece out too! lol well nexttime i can finish this install in 30.....only hard part will be the stock airbox which is a pain in the assto take off........also when i had the tube in backwards the sound soundedhorrible.....all I could hear was air going through the filter when I revved the engine, and if revved too high engine turned off...stupid mistake shoulda seen that word that said FLOW-> lol
Anyways theintake is prettynice..i dun tiink its loud at all, people are always saying how loud it is...it sounds completely stock under 2000 RPMS and the sound isnt loud until 4000 RPMS....I think I feel some power gain but I cant tell
Old Apr 27, 2002 | 09:53 AM
Colonel's Avatar
Old Fuddy Duddy
Hey, does yours whistle at different RPMS other that W/O?
Old Apr 27, 2002 | 09:56 AM
1. tubing for a 2k-2k1 is 65 shipped
2. the pipes are different for a 2k/2k1 and a 2k2. 2k2 is slightly simpler.
3. whenever is fine mike, as long as you got your i'll just wait around, whenever. you find the $5 bill in the tube, don't want that in your engine
-steve
Old Apr 27, 2002 | 10:38 AM
MaDxKiLLa's Avatar
I cant hear the whistle that well....it sounds basically stock..you can hear it alittle but not relaly...
Old Apr 27, 2002 | 11:05 AM
soundmike's Avatar
Very sound, Mike
Steve, the $5 wasn't supposed to be in the tube? OMG! I thought that was a power adder!
Seriously, thanks for paying for return shipping man. I sent it out this morning via USPS Priority.
Old Apr 27, 2002 | 12:53 PM
KLOOGY's Avatar
L33t BMW Drivah
For some reason that picture of the weapon R is not loading .... ?
Old Apr 27, 2002 | 10:03 PM
hey it's my fault, i feel that if it's the manufacturers fault why should you have to pay extra. you are already being inconvienced because of their(my) error.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
