Addco RSB question
Old Apr 28, 2002 | 03:54 PM
noflash's Avatar
Addco RSB question
Is this correct?
Brackets go in for less body roll, out for more.
For a full transcript of this conversation go to:
http://forums.maxima.org/showthread....hreadid=115655
Old Apr 28, 2002 | 04:06 PM
Cutler's Avatar
I moved my brackets in about 5" more and it seems to have corrected it, also make sure you tighten the crap out of it.
Good Luck!!
JCR
Old Apr 28, 2002 | 07:56 PM
BuddyWh
Re: Addco RSB question
Originally posted by noflash
Is this correct?
If you slide the brackets on the transverse link towards the end of the bar, it increases roll control. If you slide the brackets on the beam to the outside, it increases roll control but you run a risk the brackets will contact the lateral link in bumps. I think the referenced thread got the two brackets mixed from the instructions.
Also, too much RSB control brings on FWD oversteer; it can be controlled some with tire pressure adjustment. The RSB controls roll well, but if you want maximum roll control and keep nasty oversteer in check you also need a heavier/thicker front sway bar.
BuddyWh
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
