302.8 lb-ft TORQUE & 284.3 HORSEPOWER.
Old May 5, 2002 | 05:48 PM
My 4DSC
Old May 5, 2002 | 05:50 PM
My 4DSC
dyno OFF nitrous- All Motor
not bad.
Old May 5, 2002 | 05:51 PM
My 4DSC
oh yea...
i still need tuning.
Old May 5, 2002 | 06:09 PM
Dan4614's Avatar
Nice!
Old May 5, 2002 | 06:11 PM
Dan4614's Avatar
What exactly are you running?
Old May 5, 2002 | 06:31 PM
Greg's2kGLE's Avatar
Adam I am soo jealous!!!! That is awesome! What RPM did you start spraying at? What are your other mods (besides juice)? Go to the track
Old May 5, 2002 | 06:56 PM
Ironlord's Avatar
285 horsepower? that's it?
and you call yourself a maxima enthusiast....
j/k, looks nice...
Old May 5, 2002 | 07:26 PM
MaDxKiLLa's Avatar
wow isnt that more then kev
Old May 5, 2002 | 07:31 PM
AznWontonboy's Avatar
kev doesnt use juice...
Yet.
Old May 5, 2002 | 07:46 PM
Nismo87SE's Avatar
Man your car runs very lean in the midrange with the n2o. Is this nitrous kit a wet or direct port setup? Your car should be able to pull around 106-108mph traps on the bottle.
Old May 5, 2002 | 07:58 PM
2K2_6spd's Avatar
Yeah, you have a nasty lean spot at about 4k, I would find out what's causing that before you make a window in your piston. You ideally want to be in the 12.1 af range throughout the pull. 14.1 is stoich, and stoich is WAY too lean for a power adder. Remember, it's the fuel that makes the power, the nitrous only allows you to burn the extra fuel. Don't learn the hard way about a/f ratios. Just my .02
Old May 5, 2002 | 08:01 PM
BigDogJonx's Avatar
Adam,
I noticed that you had it tuned in a Baltimore area, are you from there? Just wondering since I live in the Silver Spring MD area.
Dixit
Old May 5, 2002 | 08:59 PM
My 4DSC
j/k, looks nice...
"Maxima Brainwashed"...get it right.
Old May 5, 2002 | 09:02 PM
My 4DSC
they were having trouble with the wideband O2 sensor, it originally told me i was running 15:1 all motor...so i'm going to another dyno soon to tune...
Old May 5, 2002 | 09:05 PM
My 4DSC
Originally posted by BigDogJonx
Adam,
Dixit
no, it was a mobile dyno from MD, at the NHRA Spring Nat'ls in E-town, NJ.
Old May 5, 2002 | 09:08 PM
My 4DSC
started spraying at about 3300rpm...
other mods:
stock y-pipe
stock plugs
hiflow cat, 2.5" catback, Remus muffler.
ghetto K&N cone filter intake.
walbro 255lph intank fuel pump.
paxton fuel pressure regulator.
centerforce dual friction clutch.
thats about the only things worth mentioning.
Old May 5, 2002 | 09:10 PM
jhans114's Avatar
So how big a nitrous shot are you running?? And is it a wet/dry kit???
Old May 5, 2002 | 09:16 PM
My 4DSC
dry...100 shot...
Old May 5, 2002 | 09:20 PM
jhans114's Avatar
Originally posted by My 4DSC
dry...100 shot...
Im getting my nitrous installed on either Mond. or Tues but Im only going to put a 35-45 shot wet kit. So what gear did you spray? Also how do you have the set up, WOT, purge switch,??
Old May 5, 2002 | 09:24 PM
My 4DSC
3rd gear...WOT switch...
Old May 5, 2002 | 09:30 PM
jhans114's Avatar
Have you taken your car to the track yet?? Looks like you should be in the 13's with that set up..
Old May 5, 2002 | 09:34 PM
annimax's Avatar
Impressive!
Old May 5, 2002 | 11:25 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Oooooo...... torque!
Nice numbers Adam!
Old May 10, 2002 | 03:52 PM
My 4DSC
Nice numbers Adam!
thanks...
be back on sunday from florida...
will be going to the track again soon to get some real numbers...
Old May 10, 2002 | 05:03 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Looks more like a 6...
As in 264.3HP, but who the hell really cares with 302.8 lb-ft TORQUE!!!!!!!!!
Man Adam, sure wish you'd do a "How To" install a 100-shot.
I can't wait for those 100-shot track times.
Old May 12, 2002 | 09:15 AM
My 4DSC
Re: Looks more like a 6...
it's an "8" i assure you.
all NOS kits come with directions.
Old May 12, 2002 | 10:02 AM
IceY2K1's Avatar
Re: Re: Looks more like a 6...
Adam, quit holding out. I mean directions for installing the Fuel Pump, FPR, etc.. and what tools, parts, etc.. is necessary.
I doubt the NOS directions are that complete.
What's next once you get everything tuned? 125-shot? How high can the #5124 kit theoretically support?
Old May 12, 2002 | 10:23 AM
Fast Walker's Avatar
Does the dvd play as u drive or only when parked?
Adam,
Dixit
Old May 12, 2002 | 01:04 PM
Burton069's Avatar
How come you only have a stock y-pipe?
Old May 12, 2002 | 02:39 PM
MAX2000JP's Avatar
Re: Re: Re: Looks more like a 6...
Fuel Pump install should be the same as a 4th gen. It is real simple, I believe MardiGrasMax or someone has a write-up for it.
Im almost positive that a 100 shot is the highest you can safely go on a Dry kt.
Old May 12, 2002 | 04:56 PM
Versace's Avatar
whoo
Old May 12, 2002 | 06:05 PM
My 4DSC
sold my 3" y-pipe when i thought my turbo manifolds were almost done...(y-pipe is rendered useless w/ a turbo)...but it's going to be a little while longer...didn't really plan on going NOS in the mean time, but it happened... oops.
Old May 13, 2002 | 10:50 AM
Burton069's Avatar
[QUOTE]Originally posted by My 4DSC
[B]
So if you decide to get an aftermarket y-pipe, you car should be even faster? You're still coming out with the turbo?
Old May 13, 2002 | 11:00 AM
IceY2K1's Avatar
[QUOTE]Originally posted by Burton069
[B]
Yes, he should have kept the 3" Y-pipe, because NOS responds really well to a bigger exhaust. However, when you not using, 3" is probably too big and he will lose everyday torque since he has a high flow cat and catback.
Old May 13, 2002 | 06:53 PM
My 4DSC
So if you decide to get an aftermarket y-pipe, you car should be even faster? You're still coming out with the turbo? [/B]
with all these flex section issues lately, i'm kinda weary about buying an aftermarket y-pipe again, but maybe i'll get that super-duper-hi-quality "Budget" y-pipe to get me by until my turbo manifold is ready...and yes i am continuing w/ the turbo project.
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
