Figured out my 2K FRONT RIGHT STRUT NOISES (I think). Now what?!
Old May 10, 2002 | 05:09 PM
Dan4614's Avatar
Ok, so I have this clunking noise comming from my front right strut everytime I turn right (especially over bumps). I was informed of the TBS about this issue, which says to add washers to the bolts on the power steering switch bracket and move the bottom rubber thing on the spring out so it hangs off.
Yesterday, I jacked my car up and looked at the bolts and nuts from below. They are really close to the mettle plate at the top of the spring. I unscrewed the bolts so they were loose and did not go any further down than the nuts, and I test drove it but the noise was still there. This lead me to believe that it is the nuts that are welded on that are causing the problem.
Today, I did an inspection of the nuts, bolts, and plate with a flashlight and a dentist mirror. The nuts/bolts are REALLY close to the plate. When I turned the wheel all the way to the right and felt the nuts/bolts, the closer nut is so close to the plate that a buisness card barely slips through. The back nut is right up against the plate, and when I looked with the mirror, I couldn't even see the edge of the nut, because the plate was in the way. So, it seems to me that the nut is up against the plate, such that when I turn right fast or over bumps, it hits or slips down, causing the clunking noise.
There are lots of people with this problem. It seems to me that the nissan service bulletin is bull****, because nissan has an impossible time fixing this with their own instructions. I wonder if the central problem is the nuts, not the bolts in most cases. I'm thinking remounting the bracket somewhere else and removing the welded nuts may be the answer to my problem.
What do you guys think???
Old May 10, 2002 | 05:35 PM
Deven2kStickMax's Avatar
Re: Figured out my 2K FRONT RIGHT STRUT NOISES (I think). Now what?!
Can you please describe all the mods you did so far that could have caused this? I had this noise and i corrected it when i installed my agx, but first tell me what you did so far.
Old May 10, 2002 | 06:19 PM
Dan4614's Avatar
Re: Re: Figured out my 2K FRONT RIGHT STRUT NOISES (I think). Now what?!
No suspension mods (I have S-03 tires). My car is a salvaged 2k gle and I did run a curb a while back, but I had everything straitened out. There was no such problem until recently. The position of nuts/bolts seems to be a fundamental 2k problem, but I probably accelerated it. I took the car to a shop and the owner drove and looked at it. I explained everything I explained above, and he said I was probably right. It will cost $250 is I want to dismantle everything to get to the nuts or whatever.
If anyone else has this problem, check those nuts and bolts. Has anyone here fixed the problem by adding washers and doing the spring thing?
Old May 10, 2002 | 07:02 PM
kpark's Avatar
I had the strange noises from the right front of my car also. I haven't heard the noise since I've gotten my Tokicos installed.
Old May 10, 2002 | 07:33 PM
Dan4614's Avatar
Apparently everyone with this problem who has replaced their stock struts/shocks has had it go away. I just noticed something on my car. The front right wheel well gap is slightly wider than the others.
In general, the suspension in most cars will settle lower on the left, due to the constant extra load of the driver. Could it be that as the stock struts/shocks/springs settle, this fundamental problem with the nut/bolt placement causes the noise? Russ had this problem, and he fixed various components with no luck, but when nissan replaced the whole unit, the noise stopped.
Also, what else might cause this noise? I'm fairly sure it's the nuts, but I don't want to only focus on one thing. Has anyone had this problem and found the noise come from somewhere else?
Old May 11, 2002 | 11:11 AM
Dan4614's Avatar
Nobody knows?
The noise is so bad, my car is no fun to drive. I want a suspension upgrade anyway, but I don't want to spend 800 plus install for tokicos and eibachs to have the same f*cking noise. Sorry this thread is so damn long but theres a lot to explain.
Old May 11, 2002 | 06:11 PM
Igor911's Avatar
I HAD THIS SAME NOISE PROBLEM AFTER NISSAN REPLACED MY TRANNY! It is something that they take off when they replace the tranny???? I dont know what nor can remember? Sorry
Matt93SE
May 24, 2019 02:58 PM
official_style
Aug 29, 2015 10:10 AM
jholley
Aug 11, 2015 09:38 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
