Manual Transmission Fluid
Old May 11, 2002 | 04:05 PM
JohnNixon's Avatar
Does anyone have a recommendation for what brand/type of transmission fluid to use for the manual 2k.
I've heard of using Redline MT90, but I can't seem to find it around here.
Would Dexron III be ok?
Old May 11, 2002 | 04:28 PM
GregP's Avatar
You can order MT-90 from Stillen (they will probably rip you) or Courtesy Nissan, to name a few. I buy mine locally at S-K Speed for about $9.00 a quart. Stuff's expensive, but worth it.
Old May 11, 2002 | 04:53 PM
john2002max
Would you happen to know what Courtesy charges per quart, and how many guarts are required for the oil change. My tranny is a little notchy going into 3rd and 4th, I've heard this oil helps alot. Thanks!
Old May 11, 2002 | 05:03 PM
bsetiawan's Avatar
Redline Products
www.myoilshop.com
Enter dealer code #675421 for 10% off.
Courtesy of IceY2K1.
Old May 11, 2002 | 05:04 PM
nddst's Avatar
2-3 Qts
You will not need mroe than 2 or 3 qts. I used just over 2 (depends how long you let it drain). Made a big difference on my car!!
Old May 11, 2002 | 05:12 PM
Deven2kStickMax's Avatar
Re: 2-3 Qts
Talking about tranny fluid for 5 speed. when is a good time to change the tranny fluid? i just got 10K + miles on my car and my x car had over 45k + miles and i never changed my 5 speed tranny fluid.
Old May 11, 2002 | 06:42 PM
iwannabmw's Avatar
Re: Re: 2-3 Qts
My 97 has 69K and it's been changed 3 times already. The last time was because I replaced my clutch though. For you, now would be a good time to change it to a nice high quality synthetic. Unless your car is used in very severe service, there is no drain interval specified by Nissan.
Old May 11, 2002 | 06:47 PM
Re: Re: Re: 2-3 Qts
cool. i have to check my manual again, but i would defenitely need better oil liek syn... i heard you get smoother shifts..with them
Old May 12, 2002 | 09:28 AM
iwannabmw's Avatar
Re: Re: Re: Re: 2-3 Qts
You get smoother shifts all the time, but it's especially noticeable when the weather gets really cold. Your transmission's operating temperature will also be reduced and you will get slight better fuel mileage as well. Just make sure what ever brand you order is a GL4 lube, not GL5. GL4 can be a little tough to find in local stores. Synthetics are definitely worth the money in my book, though I'm probably a little biased
Old May 12, 2002 | 11:28 AM
jnovember's Avatar
Re: 2-3 Qts
I believe the 2K and 2K1 5-spds require 4.5 quarts. (Mine required 4.5 quarts.) I've seen posts that say the 2K2 6-spd requires 2 or 3 qts.
Old May 12, 2002 | 12:25 PM
iwannabmw's Avatar
Re: Re: 2-3 Qts
He has the 2K2, which requires that you buy 3 quarts to ensure you have enough.
The 5 speed drivers should have 5 quarts on hand to ensure they have enough.
Old May 12, 2002 | 04:53 PM
JohnNixon's Avatar
Originally posted by bsetiawan
Redline Products
www.myoilshop.com
Thanks a lot IceY2K1, great tip!
Old May 12, 2002 | 04:55 PM
JohnNixon's Avatar
5thGenMaximas has a nice write up on how to change the fluid in the 5 spd.
http://www.5thgenmaximas.com/trannymt90.html
Old May 12, 2002 | 05:29 PM
thanks a lot guys. i will start looking for a good brand tranny oil soon and keep them on hand.
Mar 12, 2020 12:06 AM
James92SE
Oct 8, 2015 04:57 PM
Socalstillen
Sep 20, 2015 11:46 PM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
