I got a JL AUDIO 12W3 & 500/1 Question help!!
Old May 13, 2002 | 11:23 PM
majatoi's Avatar
Hey guys,
I got a 2000 Maxima GXE, I just bought and got installed 2 jl audio 12w3's and a 500/1 jl audio amp, and the problem was they said that the stock deck didn't have enough to be pumping the subs. What is the deal with this, the subs sound ****ty at the moment, he said they are booming at 25% capacity? He recommended one of two things, a really good... I don't remember, i think its a LOC like a low power pusher or something like that, or a new deck. He recommended me to simply get a new deck, because that LOC device would cost me 100$. But if I go with a new deck do I got to change out all my speakers too? I remember from a post that if you change out the maxima deck, we got to change out all the inner speakers as well? (remember I do got a GXE) The guy told me I didn't have a bose system, that it was something else, so if this is true then that rule don't apply to me right? Someone please help, I am really confused, and all my stuff isn't hitting no where near as hard as it should be? HELP!
Old May 13, 2002 | 11:44 PM
xtantmaxima's Avatar
Sounds like BS to me, especially from the datasheet at jl's website.
http://www.jlaudio.com/amps/pdfs/500_1.pdf (read under Switchable Input Range). I bet they are just trying to milk more money out of you. Also, the answer is no to regarding having to replace all the speakers in your car.
Old May 14, 2002 | 12:26 AM
jykishan's Avatar
i have the same setup, jl 500/1 amp and two w3 12inch subs, with the bose deck, sounds great, only thing is the music doesnt turn up that loud, i might get a new deck.
Old May 14, 2002 | 04:41 AM
majatoi's Avatar
Phatkap do you got a special LOC (low output converter) ? That is what he told me I need in order for it to work properly in my car? Do you think I should get the LOC or get a new deck? :/
MJ
cause right now with the sucky *** LOC they put in, it sounds like ****, don't bump worth anything
Thanks for all your help!
Old May 14, 2002 | 05:37 AM
asu174's Avatar
Clay Aiken has fancy genitals
MJ
Sounds like you have a voltage problem. How did you wire your amp to your deck? Did you use a line output converter or high level inputs? Or did you just hack into the Bose wiring?
With the 5th gen, from my knowledge, you do not have to replace the speakers...4th gen is a different story.
Old May 14, 2002 | 09:11 AM
majatoi's Avatar
oh its a line output converter not a low output converter, he said if I get a better line output converter that it would be fine, so?
and someone earlier said i don't got to change out all the speakers but now you are saying i do! HELP! hehe..
MJ
Old May 14, 2002 | 09:13 AM
majatoi's Avatar
oops disregard that part about the not changing or changing of the speakers, lol.... just need to know to get a line output converter (new one - 100$) or a new deck? What would make it sound right or a lot better.
Old May 14, 2002 | 07:28 PM
jykishan's Avatar
MJ
sorry man i dont know jacksh!t about car audio, i have friends help me on that, try audio forum
Old May 14, 2002 | 08:25 PM
maximadave's Avatar
detailerdaveb@gmail.com
Get a new deck. Cleaner signal with no distortion. Look into lines of Alpine and Eclipse.
Dave
Old May 15, 2002 | 02:46 AM
majatoi's Avatar
Dave
Went and bought a alpine deck solved all the issues, the system bumps like a mofugga, now I got to get the dynamat in, cause my trunk rumbles! :P Thanks for all the help guys!
Fbana41
Aug 29, 2016 12:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
