pretty loud bang shifting from R to D
Old May 14, 2002 | 09:35 AM
dennisuello's Avatar
2000 GLE, with auto, 48k miles. the other day i noticed that when I shift from R to D relatively fast there's a distinct bang coming from tranny. i never noticed this before and i don't think i changed the way i shift.
if i do it slowly from R to N, then from N to D, everything is normal.
i have a long trip coming up in two weeks and didn't want to drive if this might be a problem.
anyone had this happen? any ideas?
i will probably take it to the dealer to check out, just wanted to see if anyone knows anything here, as i will not be able to visit the stealership till the end of the week.
Old May 14, 2002 | 09:46 AM
[maxi-overdose]'s Avatar
48k....have u done an auto-tranny flush? Double check the tranny fluid level?
Old May 14, 2002 | 09:46 PM
per previous owner 30k mile service was done at 35k, we got the car at 38k. i assume they checked all that stuff.
Old May 14, 2002 | 10:14 PM
KLOOGY's Avatar
L33t BMW Drivah
If it was a RWD, it would be U - Joints.. noot sure about FWD ..
Old May 14, 2002 | 10:41 PM
BigDogJonx's Avatar
ok lets start with the basics.......... Do you have any mods on the car?
The reason I ask this is because I had my FSTB that was rubbing against the top of my engine bracket. Then the hole for the intake pipe was not cut correctly which caused alot of banging to happen everytime i shifted in my auto tranny cause when you shift from just R to D, the engine shifts fairly a good amount, and so the the intake pipe and it was banging in the hole.
If none of the above, then check the tranny fluid and see if it smells burnt or what not. Maybe time for a tranny filter change.
Dixit
costcowholesale's Avatar
I guess u're netural dropping the transmission thats why you get that bang, can you feel it? or is it just noise? if you can feel a forward jerk with the car when you put it into D u're neutral dropping it. Try stopping completely & wait for rpm to go back to ~800rpm before shifting quickly back to drive.
Old May 15, 2002 | 06:00 AM
I am completely stopped when this is happening. i'm asking, because, i don't think it was happening before and just started doing it.
i guess, i don't really trust dealership to find the exact problem and correctly fix it.
oh, yeah, there's no mods on the car. (except for new tires and just changing engine oil last weekend)
Old May 15, 2002 | 06:02 AM
njmaxseltd's Avatar
Motor mounts?
Old May 15, 2002 | 06:08 AM
where are all the rest of motor mounts, i can only see the two up front and on passenger side fenderwell.
i popped the hood open and shifted while looking at the engine, it does move quite a lot front to back.
Old May 15, 2002 | 09:37 AM
have u checked the tranny fluid urself? if it is low and smelled like burning sugar, there;s something wrong with the tranny.
Old May 15, 2002 | 10:05 AM
The fluid level is good and it doesn't smell like burnt sugar, but it sure is stinky
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
