Secrets to using touch-up paint
Old May 16, 2002 | 07:35 AM
MaximaTrojan's Avatar
Does anyone know how to use touch-up paint so it'll look halfway decent when it dries? there's no dent, but maybe a 3/4" x 3/4" area of paint got stripped off the back bumper.
Old May 16, 2002 | 07:44 AM
SVTTODAMAX's Avatar
Put it in a good Hobby airbrush with a thin nozzle. Take your time and give the spot several light coats. I did this with my old car and it worked out pretty good.
Old May 16, 2002 | 07:47 AM
Colonel's Avatar
Old Fuddy Duddy
Good idea! Question though, can you dump what comes in those stupid brush on bottles into the airbrush can "as-is" or will you have to thin it to keep from clogging the nozzel?
Old May 16, 2002 | 07:52 AM
SVTTODAMAX's Avatar
Test it on a piece of plastic first plastic allows you to see how thin a paint is because thin paint on plastic will bead I didn't thin out the paint when I did it the ford paint was already pretty thin. The nissan touch up paint is pretty thin as well. But different bottles can have different viscosity. Also before you spray get a piece of cardboard and test the tip to make sure it is flowing properly before spraying onto your vehicle you don't want it to spit paint onto other surfaces of the car.
Old May 16, 2002 | 10:28 AM
ahh, very good idea
ahh, very good idea. i don't have a airbrush, though. my artist friend might have one. are those airbrushes little things i can buy at a store or do i have to buy a compressor and stuff?
Old May 16, 2002 | 10:39 AM
drudawg888's Avatar
i have several paint touchup spots (bought from nissan) on my car and it looks like my car has chicken pox (very noticeable) from certain angles. anyone have ideas to blend in these already-dried touchup spots?? much appreciated!
Old May 16, 2002 | 11:28 AM
SoloMaxima
Re: Secrets to using touch-up paint
try langka...www.langka.com
Old May 16, 2002 | 12:14 PM
Tanman's Avatar
I've been told you can use very fine sand paper, wet it with soapy water, then sand down the spots. I've been too chicken to try this on my car, but maybe it works.
Old May 16, 2002 | 01:12 PM
drudawg888's Avatar
Re: Re: Secrets to using touch-up paint
i've heard of langka.. so this stuff works perfectly?? no problems?
Old May 16, 2002 | 01:13 PM
drudawg888's Avatar
hmm.. sounds interesting.. i might give it a try but has anyone else tried this?
Old May 16, 2002 | 08:18 PM
redfly17's Avatar
langka seems like a fluke to me... wathc thier videos and you'll see what i mean... the screen is soooo small you can't even see if the product is even working or not... make it bigger lose resolution either way i can't see anything~! someone buy it and tell me if it works... otherwise its like that G20 scratch remover crap... completely useless. they've patented a non-functional white cream
Old May 16, 2002 | 08:28 PM
GimmeTorq's Avatar
Langka actually does what the manufacturer claims (gets rid of the "blob") BUT it reduces the glossy appearance of the touch-up paint. The end result is no paint "blob" but a flat (matte) finish to it (only affects the touchup paint, does not harms the original paint). To me, it looks better than the stone chip, but it is by no means unnoticeable.
Old May 16, 2002 | 08:34 PM
MarcusJY's Avatar
Pep Boys sells this plastikote stuff called "paint leveler", it works pretty good similar to langka.
Check for details on touchup paint pointers.
http://autopia-carport.com/forums/sh...?threadid=8592
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
