Damn it! Stripped a god damn bolt.
Old May 17, 2002 | 02:23 AM
melteye's Avatar
Ok... I was about 5 minutes away from completion of the removal of the entire Right-Front suspension when I saw this one lone bolt connecting the Lower-Control Arm to the bottom of the thing the wheel connects to (hehe?)...
I tried an 18 and it was too small... Tried a 19 and it fit, I turned with all my strength and WHAM... It strips the entire bolt into a nice circle.
I can't get the ****ing thing off... I need to get the god damn thing off... Please help me.
Old May 17, 2002 | 02:29 AM
JDwyer2821's Avatar
Re: Damn it! Stripped a god damn bolt.
This was on a 2K2, **** I thought it was easy to get bolts off newer maxima. I have broken and stripped so many bolts on my max, so I know how ****ed you feel
Old May 17, 2002 | 02:38 AM
CIRCO's Avatar
Use a vice grip it will get it off since you have no other choice
Old May 17, 2002 | 02:40 AM
melteye's Avatar
I can't get it out from underneath my car to get it into a vice... And the bolt is so tight that it cannot be removed with a vice grip
Old May 17, 2002 | 03:17 AM
CIRCO's Avatar
No way! Where is it located again? You might have to heat then! Did you try spraying it with those lossening sprays! When you are taking it off tapp don't fricken try an muscle the damn thing.
Old May 17, 2002 | 03:19 AM
Hobert's Avatar
You will probably have to end up drilling it out.
Old May 17, 2002 | 04:39 AM
ZIPPIN's Avatar
Mauja He Mauja
one word "dremel"...cut it off
Old May 17, 2002 | 07:31 AM
doublea's Avatar
Go to your local shop and buy a bolt extractor, first you will have drill a hole in the bolt and the use a the extractor to unscrew it, I've did this many time in my life and worked out for me, I would suggest that you use a lot of WD40 it will help.
Cheers
AA
Old May 17, 2002 | 07:38 AM
Sandman2K's Avatar
Or... use a grinding wheel from the Dremel, cut a big notch in the top of the bolt, and use a ratchet with a screwdriver-head to wrench it loose.
Old May 17, 2002 | 07:42 AM
emax02's Avatar
Heat lube and a pipe wrench.
Old May 17, 2002 | 09:59 AM
melteye's Avatar
If I **** up then I ruin a very expensive part of my car... There is very very limited access to turning the bolt... I suck with dremel...
Where should I buy bolt loosener (Home Depot? etc?).
Whats an easy-out and is it simple to use (where do i get one)
Old May 17, 2002 | 10:27 AM
NuJerseyDrive's Avatar
This happened to me when working on the FSTB. I went to Sears and picked up an extractor. If there's a Sears nearby, check them out.
Old May 17, 2002 | 12:32 PM
melteye's Avatar
I ended up taking a grinder to it... Took 10 minutes straight.
Old May 17, 2002 | 12:47 PM
AudioMan's Avatar
Did you get the bolt off?
Old May 17, 2002 | 12:51 PM
melteye's Avatar
Yep Turns out the damage to my car isn't that bad... I am very very happy. Nissan quoted me $3468 and it turns out only about $200-$300 is actually damaged.
http://www.melteye.com/Damage.JPG
Old May 17, 2002 | 01:11 PM
melteye's Avatar
I am very impressed with the strength of the maxima. And the mechanics may be very very overpriced and quoted me a ****load of money but they were still nice and didn't mind when I took the car and said I would do it myself. They actually gave me suggestions and shook my hand.
Old May 17, 2002 | 01:18 PM
AudioMan's Avatar
Are you doing the repairs yourself and that is why you were taking the suspension off? It is so much cheaper if you know how to do it vs. paying the steeler.
Old May 17, 2002 | 01:28 PM
HKSturboKid's Avatar
On my old daytona like 12 yrs ago. I was changing the thermostat and the bold on the housing is so tight. So I put the socket on the nut and then the wrench on it and freaking stand on top of my engine and just stomp on it.
Guess what......the freaking nut came off.....not screw off but came off completely and the antifreeze squirt all over. I end up have it tow to my local repair shop and drive the rest of the screw out.
Old May 17, 2002 | 01:32 PM
melteye's Avatar
I already took everything apart and am waiting for the Lower Control Arm I'm having Dave overnight to me.
Yes I am doing repairs myself.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
rbarnes
Dec 31, 2015 06:29 PM
RealityCheck
Oct 2, 2015 06:34 PM
bumpypickle
Sep 19, 2015 01:07 AM
