2k2 front splash guard install
Re: 2k2 front splash guard install
Originally posted by sardarg89
is it an easy DIY?
is it an easy DIY?
If ya want I can snap a pic and show ya.
I agree, it's an easy install but I'm having problems with the screw that fits from the bottom (the two exposed at the wheel well are ok). For some reason, it doesn't tighten up; it stays loose and I'm worried with vibration, it will evetually fall off. It seems the threads at gone at the metal/nylon fitting at the side skirt. I've been trying to get a longer screw to see if it helps but I have had no luck.
Did you guys had a similar problem? If so, did you guys do anything to fix it? Any suggestions on how to fix this (replace the screw with a different specs one)?
Team STILLEN
Aug 10, 2015 04:29 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
