Fastbrakes kit -take a look at the
Wilwood bits ands pieces that will be available.
From Brian Hasty:
"I will be using the Superlite series of calipers. The Superlite IIA cast caliper will be the base caliper, with the Billet Superlite available as well as the Billet Superlite 6 piston. Rotors will probably be the 12.2" directional vane design. Options such as HD rotors and drilled or slotted rotors will be avialable."
http://www.wilwood.com/products.asp
If da budget can swing it I'll probably go with the Billet Superlight IVs and some minimal cross-drilling. Figure 8 lbs reduction in unsprung weight based on the fact that stock calipers weigh approx 12 lbs each, the Wilwood calipers 6 lbs and stock rotors weigh 13 lbs, the 2 piece 12.2" rotors 11 lbs
From Brian Hasty:
04-16-2020 05:15 AM
Kyle Lee Cleveland
09-28-2015 07:58 AM
Pied
09-26-2015 03:29 PM
