5th gen with aftermarket suspension?
Old May 25, 2002 | 11:21 PM
CIRCO's Avatar
Did you trim your rear bump stops? They don't separate from the dust covers on the 2k gxe. Do you really need the dust covers?
Old May 26, 2002 | 08:18 AM
cobymoby's Avatar
Re: 5th gen with aftermarket suspension?
Don't trim those bump stops. The bust boots aren't neccessary but I would put them on if I were you. They keep dust off of the piston which helps avoid seal wear. The dust acts like sand paper on your shock's seals, and dust boots help keep it dust and grime free.
Old May 26, 2002 | 10:21 AM
CIRCO's Avatar
Re: Re: 5th gen with aftermarket suspension?
To late I trimed the bump stops on both the rear and front. The front however still has oem dust covers. Just the rear doesn't have the dust covers. Some cars don't even come with dust covers though so it can't be all that bad. I think you need to trim the bump stops because the amount travel is reduced from stock so the bump stop will be stoping the suspension from traveling prematurely.
Old May 30, 2002 | 02:21 AM
cobymoby's Avatar
Re: Re: Re: 5th gen with aftermarket suspension?
Those bump stops are there so that your shocks will not bottom out. They are a saftey device. By triming them, you are risking your pistion coming out the other end of the shock or at least bending the piston rod which is as good as a blown shock.
Old May 30, 2002 | 07:22 AM
noflash's Avatar
Re: Re: Re: Re: 5th gen with aftermarket suspension?
Galo says trim 'em. Eibach says trim 'em. My shop says trim 'em. If you don't trim 'em you bottom out (on the BStP)all the time! I have Maxspeeds on stock GXE w/o the rears trimmed and BAM! on a bump over 40mph - and no it's not the Addco.
I am getting Toks soon. Would you be okay trimming w/ Tokicos?
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
