2002 clutch bleed procedure?
Old May 29, 2002 | 09:56 AM
KTM's Avatar
KTM
Does anyone have the procedure for bleeding the clutch on the 2002? I don't know where the bleed valve(s) are located. Is there more than one valve, and do they need to be bleed in a certain order? I have a mity vac bleeder, so hoping this will go pretty quickly, any help appreciated, thanks.
Old May 29, 2002 | 11:54 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: 2002 clutch bleed procedure?
Auuuugh, what do you mean bleed the clutch?
You just drain the old fluid and refill till it starts to pour out the drain hole while level.
Check Russ's website for pics:
http://www.5thgenmaximas.com/trannymt90.html
Old May 29, 2002 | 01:14 PM
KTM's Avatar
KTM
Re: Re: 2002 clutch bleed procedure?
Hydraulic clutch, not the transmission...
Similar procedure to bleeding brakes, except I need to know where the bleeder valve(s) are.
Old May 29, 2002 | 02:23 PM
IceY2K1's Avatar
Re: Re: Re: 2002 clutch bleed procedure?
Explain please.
Is this specific to the 2K2 or does the 2K-2K1 also have this?
I have a 2001 ESM, so I can try and look it up if a 2K1 has this.
Old May 29, 2002 | 03:40 PM
CIRCO's Avatar
Re: Re: Re: Re: 2002 clutch bleed procedure?
Explain please.
This is on our cars too IceY2K1. I don't see any reason to bleed the clutch on a 2K2 so early! As a suggestion you could search the general forum or 4th gen those guys have a write up on there somewhere.
Old May 29, 2002 | 03:46 PM
Y2K2Driver's Avatar
Hope this help
http://mywebpages.comcast.net/mpillmeier/cl_05.jpg
http://mywebpages.comcast.net/mpillmeier/cl_07.jpg
Old May 29, 2002 | 04:36 PM
KTM's Avatar
KTM
THAT'S IT! Thanks Much
The reason I'm going to bleed it is because the clutch operation varies so much, sometimes there's half a pedal stroke of free play, and it doesn't engage until its right near the floor. Other times it engages at the very top of the pedal.
Old May 29, 2002 | 06:09 PM
Padsy's Avatar
Boost.....
Hummm
I think mine does that too....please let me know how it works out for ya.
Thx.
Old May 30, 2002 | 12:03 PM
CIRCO's Avatar
Re: Hummm
Thx.
Why don't you take it to the dealer for a 2k2 ?
Old May 30, 2002 | 12:13 PM
Padsy's Avatar
Boost.....
Re: Re: Hummm
Huh?? I do have a 2K2......?????
Old May 30, 2002 | 12:22 PM
CIRCO's Avatar
Re: Re: Re: Hummm
Sorry maybe I wasn't clear....I meant if you are having problems with your clutch not feeling right take it to the dealer while you can. If you can put up with the BS they put out.
Old May 30, 2002 | 12:23 PM
Padsy's Avatar
Boost.....
Re: Re: Re: Re: Hummm
Gotcha!!
I am going to call 800-nissan1.
Old May 30, 2002 | 12:54 PM
Colonel's Avatar
Old Fuddy Duddy
Explain please.
You are kidding right? I hope...?
Old May 30, 2002 | 01:14 PM
IceY2K1's Avatar
Re: Re: Re: Re: Re: 2002 clutch bleed procedure?
No, what do you think I'm kidding about?
The 6-speed is different than the 5-speed(electronic shift cable vs. linkage), so I thought there might be something different with the clutch. I'm NO expert on transmission or clutch design.
Enlighten me O'wise one.
BTW, how's that FSTB working out? I told you to hold off!
Old May 30, 2002 | 01:50 PM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: Re: Re: Re: 2002 clutch bleed procedure?
Smartass.....Thats the shift mechanism (gear selection/transmission), not the clutch mechanism (pressure plate/flywheel). Clutch still uses the fluid for engagement/disengagement. There is an upper and lower bled fitting.
Got it finished. Yeah...not one of my best purchases. But eh? Whatta ya gonna do? Although I must admit I could tell the differences in the handling (As I really like to toss the car into corners..next might be the Warpspeed SFC's. If I can get the wife to go for them before the house...). Might get a $tealin one used somewhere if it fits properly. Mine does now but looks kinda ghetto. I still have to clean up the welds better.
Old May 30, 2002 | 01:56 PM
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Re: 2002 clutch bleed procedure?
Actually it's smartALEX.
Yeah, I've been looking for a used $tealin FSTB for awhile. For the damn $80 more I'd spend new/used I should have just bought it a long time ago.
What feels different in the handling? Explain?
Old May 30, 2002 | 02:01 PM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: Re: Re: Re: Re: Re: 2002 clutch bleed procedure?
Originally posted by smartALEX
...What feels different in the handling? Explain?
I have a specific exit I take that is basically a 270 turnaround and has a small sweeper with a tight pinch in it. I push the car until if "feels" sloppy (kinda floaty) in the rear or I pick up some plow. I have never been able to squeal the tires (Toyo Proxes) pushing it. Avg speed around 50-55.
Today (whether it be a confidence thing or not) I tore through at about 63-66 (needle was wavering and I was trying to watch what I was doing). The car felt a bit less twitchy to steering input so the rear felt more planted (less floaty).
That does not mean I planted the rear by installing a FSTB, just that it does not seem as twitchy to steering input so the back seemed more calm....It seemed.
Old May 30, 2002 | 10:08 PM
ThurzNite's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: 2002 clutch bleed procedure?
get a rsb...you'll love it.
Jae
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Marc2theMax
Sep 28, 2015 08:13 AM
