stillen strut bar
Old Jun 5, 2002 | 06:31 PM
SkLz325's Avatar
stillen strut bar
hey guys...i just recently bought a stillen strut bar direct from stillen. the bar came but there are some obstructions that keep me from installing it. i am very unhappy with the finish. the best way i can describe is it is that there is an extra slab of metal on one of the tower mounts. has anyone else had this problem? if so...how can it easily be fixed?
thank you for your anticipated help.
-steve
Old Jun 5, 2002 | 06:37 PM
xChungHsienx's Avatar
Re: stillen strut bar
-steve
I have the exact same problem, so far no one has told me how to get around this. I am temped to cut the strut ring becuase its only a small piece that has to be removed, but i wonder if this will cause the strut bar to operate improperly. Need help also. Thanks
Chung-Hsien
Old Jun 5, 2002 | 06:39 PM
y2kse's Avatar
Call Stillen and find out WTF is up! You guys spent WAY too much money on your FSTBs to be encountering problems of the kind you're describing. And NO modifications of any kind should be required to install a Stillen FSTB if you got the correct one for your model year.
Old Jun 5, 2002 | 06:43 PM
2K1HoMax
-steve
the only probelm ive had with stillen so far is that when i first got the FSTB the holes were drilled in the wring places, u should have seen the look on my face, just send it back and tell them its the wrong peice and that it just wont fit. nothin else i can think of.
Old Jun 5, 2002 | 09:28 PM
help
anyone know who i should contact at stillen and the number? I'd like to talk to someone, if there are any at stillen, that i can count on to take care of the problem, not just jerk me around. Thanks
Chung-Hsien
Old Jun 5, 2002 | 09:48 PM
2K1HoMax
Re: help
Chung-Hsien
if im not mistaken its 714-540-5566, use whatever extention # u want though. all the same
Old Jun 6, 2002 | 04:08 PM
CO2kmax
is your front strut straight or does it go up and over the engine? It should go up and over. Also talk to Kenny #185
Old Jun 6, 2002 | 05:03 PM
Hey thanks for the #'s. It curves up and over the engine block. I'll try and get back to you guys. Thanks again
Chung-Hsien
Old Jun 6, 2002 | 06:27 PM
irvine78's Avatar
Re: Re: stillen strut bar
it's not the holes...they probably sent urs with two identical plates instead of sending one for the right and left. i had the same problem with this...luckly, i only live 10 minutes from Stillen.
Old Jun 7, 2002 | 06:23 PM
2K1HoMax
Re: Re: Re: stillen strut bar
yeah ur lucky i had to wait like a month from the time of delivery to finally get it installed. it wasnt 2 identical plates, trust me. i tried them both evey which way possible, even upside down to be sure
(and no i wasnt gonna install it like that). they were totally machined wrong, the holes were like 1/4" to 3/4" off and all weird. had to send it back. took them a weel to figure out whats wrong with it (go figure, thats stillen 4 you)so it took a while to get mine in. now that i have it in i want the coil-overs and the rsb, but i dont want to get a rsb til i finish my exhaust to it wont get in the way, one less thing to mess with.
Old Jun 7, 2002 | 07:00 PM
y2kse's Avatar
And how much does a Stillen FSTB cost?
Old Jun 7, 2002 | 07:04 PM
2K1HoMax
Re: Re: Re: Re: stillen strut bar
usually i think it cost about....$195, but thats just resale price. not my price. but even at my cost, stillen fstb cost more then other yeah i know, we all know. its a little too late for that now.
Old Jun 7, 2002 | 08:25 PM
00MaxSE's Avatar
Pointy Elbows
Mine went it fine. It's just that the top of the bar hits up against the heat shield and so it pinches off my driver's side windshield washer hose. My driver's side nozzle wouldn't spray. I had to clip off some of the heat shield under the hood and move the hose around a little bit. Guess and check kind of thing. But even when my nozzle DOES spray, it's not like the one on the passenger's side. (So there is still SOME pinching off of the hose.) They really need to design these things better. By the way, I didn't pay the $195 either. I got a "special" price. Kenny is a good guy to deal with.
Later.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
