OBX strut bar for 2000+ maxima
Who has one?
Like this one?
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:BN:US:1
Input?
Does it fit well?
Like this one?
Input?
Does it fit well?
Re: OBX strut bar for 2000+ maxima
Originally posted by yongjun
Who has one?
Like this one?
Input?
Does it fit well?
Who has one?
Like this one?
Input?
Does it fit well?
Who has one?
Like this one?
Input?
Does it fit well?
Who has one?
Like this one?
Input?
Does it fit well?
Re: Re: OBX strut bar for 2000+ maxima
Originally posted by Trunksu
you want mine (it's silver and never been used)? if you want it let me know, and i'll make it a good deal. most people had problems getting it so it didn't touch the hood.
Re: Re: Re: OBX strut bar for 2000+ maxima
Originally posted by Colonel
Yup...its not good. I bought one...Ended up haveing it custom welded to a proper point on the strut tower bracket so it would not hit the hood. My opinion is to find another one somewhere else.
Thanks,
Re: Re: Re: Re: OBX strut bar for 2000+ maxima
Originally posted by Tanmann9
Please post pictures or detailed instructions for how you fix the problem.
Thanks,
Thanks,
What I did, with the assistance of the bodyshop guy, is figure out that if you just sit the bar in the STB (strut tower brackets) and shut the hood, the clearance is fine. BUT, if you drill a hole in the STB at the point it needs to be, you will be interfering with the strut tower nut on the backside. I spent a LONG time looking for a new nut (cant be more than 1/4" tall) and could not find. I also could not find a thin headed screw (rivit like) to reverse feed the STB.
SOOOOO..... we ended up drilling the hole anyway, putting a piece of steel ingot (like a pin) and welding all the way around. SO far so good....I check on it weekly looking for stress fractures at the weld and have not noted any to date. And believe me I HAVE tested it....he he he.
Re: Re: Re: Re: Re: OBX strut bar for 2000+ maxima
I have pics...but forget to send them out...
Thanks,
Re: Re: Re: Re: Re: Re: OBX strut bar for 2000+ maxima
Can you post the pics or email them to me? I'd really appreciate it. If I can get a better idea of what you did to fix it, maybe I can come up with another solution.
Thanks,
Thanks,
I fixed mine too....got few problems in the beginning..
1.windshield washing fluid....driver side got stuck and nothing comes out.
solution - push the bar forward since the washer fluid tubings goes near the edge of the hood.
2.bar contact with the plastic sensor near MAF on the driver side.
solution - this bracket holds both MAF sensor and an unknow circular plastic sensor. I used the bolts and rubber adapter from the stock air box to lower the bracket. now it has a gap btwn the bar and the sensor.
I would suggest ppl do to the 2nd one at least...the bar gets very hot and it might not be good for the plastic sensor.
that seems better...I only have an inch gap btwn the bar and the sensor....I believe it was knocking on the bar before I relocate them.
Oh yeah...forgot about that...good call.... On mine I actually popped the plastic bracket for the sensor out and flipped it over so it installed on the bottom side of the metal braket...away from the bar...he he he...
hind sight sells for millions of dollars...I have to make lemonade now...
just in case u guys want to see some pics of OBX FSTB.
http://forums.maxima.org/showthread.php?threadid=115751
fits fine on mine....minor adjustment req....
did u get it from some ebayer name reddog?
It looks nice, but it doesn't fit right, so it's not worth it. Should have paid the extra for the Stillen bar.
Nope, got it from Sprinter981 or something. I probably need to adjust it, but Colonel said he tried and couldn't find a position where the bar wouldn't touch the hood. He ended up welding somewhere and moving the bar down.
i thought the Stillen strut bar is like another $100
i got it from the same guy.
kingw323
20
Oct 21, 2015 08:36 AM
kenc15
Sep 25, 2015 06:38 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
