292 @ less than 9psi of boost, plus custom intercooler plus big brake kit review
Old Jun 16, 2002 | 08:00 PM
max'n out's Avatar
Well, I’ve been promising it for a while now, and after some problems and delays I have the story.
For those that don’t know, I now have a custom front mount air to air intercooler, custom exhaust, 3.25 pulley, Apexi super afc, plugs, 8:1 fmu stuff like that is all now in. O yeah it's a 2000.
Anyway, after a few problems and delays it is all-together now, everything looks great, the exhaust is one of the best I’ve heard. Very factory sports car like, cars like the vette, m3, Porsche’s; cars like that that’s what I sounds like.
However I regret to say that the intercooler is dropping 3 psi of boost…very sad indeed…Yes I know it’s a lot, the reason has not yet been found, so please no comments on it’s drop,we all know it sucks, but if you have suggestions on things to check feel free to post that. If the reason can’t be found, it may be time to go with the 2.87 pulley, or maybe just time to get the 2.87 anyway.
The car was tested for boost, by bypassing the intercooler and the car made just a little shy of 9 psi of boost on the 3.25 pulley and made 292 hp…Hence the attention grabbing title, But again sadly on the intercooler with boost drop down to 6psi it only made about 260ish(auto). And the afc neeeded to be of course cranked way down. The funny thing is the car rips into other cars, I had a few sports cars run ins, things like the s2000, Camero, old school pumped up mustangs, and a rough mustang, I whipped up on all but the roush, that one was fun.
And for those that doubt the stuff I did to the tranny, don’t, that thing is sick. No lag, no wheel spin. Screw a five speed.
Also the boost, volt, and a/f gauge are all digital, and custom mounted in where the clock( really rebuilt) was inside tinted plexi, it looks really kewl, much more clean than a pillar style, I got some shots of it, look for that soon.
I also know some guys where looking for my impressions on the Stillen big brake 2 piece roter kit, 4 piston calipers, and lines, etc. Here is my review, it’s great….really great…stops on a dime from every speed, only problem is that if you tap the brakes a little to much you stop a little to soon unexpectedly at first. They take a while to adapt to, but once you do, it’s a lot of fun…Is it worth the cash? Well you have to decide, they are priced at about what all kits like that are, but they are great.
I took pics of everything this weekend, I gotta wait for um to come back, then my friend, and teammate is going to make the site up, when it’s done I’ll come back and update everything, and you everyone know.
If you have questions of comments feel free to post.
I also figure I'll take this chance to up date the mod listFor those that want the list of updated mods here it is…Or for those that don't here it is any way
.....Engine-
Vortech V2-SQ Supercharger
3.25 pulley
Custom Intercooler and Powder coated Pipes
Greddy Type- S Compressor Bypass Valve
Custom Exhaust w/ high flow cat & Resonator
Apex-I Super AFC
NGK spark Plugs- 2 steps Colder
Vortech 8:1 FMU
Aluminum Idler & Tensioner pulleys
.....Wheels & Tires
19”X 8.5” Volk Racing AV3
Yokohama AVS Sport 245-35-19
..........Brakes...Front
........4 piston calipers
......13” Drilled and slotted Rotors
......Stainless Steel Brake lines
.......Pads
.............Rear
.........Drilled Rotors
..........S.S. Brake lines
...........Pads
......Suspension
Cattman Coilovers – Generation 2
Stillen Front Strut tower Bar
Stillen Rear Sway Bar
.........Transmission-
Upgraded and blueprinted transaxle for extreme duty application, which includes durability upgrades, balancing of internal components, and valve body modification.
Custom axle
Custom Transaxle housing
Heavy-duty differential
Torrington bearing set
Teflon Bushing kit
Kolene direct steel
Ceramic direct clutchs
Kevlar Bands
Billet clutch drum (high Drum)
Race sleeves
Tapered roller bearings
Ring and Pinion Gear set
Case harden torque converter input hub and fluid balanced the converter
Hardened input shaft
A Custom form of Posi- traction
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
...........Audio
Amps- (3) Zapco C2k 2.0
Processors- (3) Zapco Eq 30 – Sl- Equalizers
.............Zapco Slx-4- Crossover
.............Zapco Da2-sl - D/A converter
.............Zapco Vfm-Sl –Balanced line transmitter
.............Zapco Psi- Power supply
Head unit- Nakamichi Mb100- 6 disk in dash changer
Speakers/Subs- Mb Quart QSD 6.5 components
...............Mb Quart 10“ Premium
Power- SVR Battery
.......Alumapro’s “The Cap” 15 Farad capacitor
........Miscellaneous-
Viper alarm
Zapco Symbilink Cables
Dakota Digital Gauges
Front and rear Clear side markers
Old Jun 16, 2002 | 08:05 PM
2000 SE's Avatar
Re: 292 @ less than 9psi of boost, plus custom intercooler plus big brake kit review
.....Engine-
3.25 pulley
Apex-I Super AFC
Vortech 8:1 FMU
.....Wheels & Tires
.......Pads
.............Rear
...........Pads
......Suspension
Custom axle
Teflon Bushing kit
Kolene direct steel
Kevlar Bands
Race sleeves
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
...........Audio
Power- SVR Battery
Viper alarm
nice sig, I almost need DSL or a cable to download it.
Old Jun 16, 2002 | 08:22 PM
BioMaxDDS's Avatar
.....Engine-
3.25 pulley
Apex-I Super AFC
Vortech 8:1 FMU
.....Wheels & Tires
.......Pads
.............Rear
...........Pads
......Suspension
Custom axle
Teflon Bushing kit
Kolene direct steel
Kevlar Bands
Race sleeves
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
...........Audio
Power- SVR Battery
Viper alarm
speechless
Old Jun 16, 2002 | 09:32 PM
02MaximizedVQ's Avatar
Boost leak
Ok on the issue of losing 3 psi of boost...with a large intercooler sometimes the pressure drop can reach 3 psi. Your intercooler may just be too big for your application. Most front mounts for Ecilpses
have a 2 psi pressure drop. Secondly, on my Eclipse GSX, I had a Greddy blow off valve, (I bought it used) and it was leaking 4 psi of boost. Take it apart and make sure the rubber ring in it isn't torn. I'm assuming its brand new so it should't be a problem, but it might. You probably already did this but double check all of your hose clamps and if you're not using T-bolt clamps, well they are 100% reliable.
Jesse
Old Jun 16, 2002 | 10:03 PM
max'n out's Avatar
Re: Boost leak
Jesse
Funny you say that like that The intercooler is very large, and I was kinda thinking the same thing, and it also started out as a custom intercooler for an eclipse, then moded to work on mine. It's not the bov I tried that first, pulled it out and put a plug in for no chance there.
Old Jun 17, 2002 | 04:23 AM
Deac's Avatar
Re: Re: Boost leak
I must be lucky because I have a 3.25 also and a custom intercooler nd I'm not loosing any boost really. I can hit 9psi consistently in 2nd & 3rd gear.
Deac
Old Jun 17, 2002 | 05:48 AM
MardiGrasMax's Avatar
So aye you going to scan the dyno plots and post them or what?
Old Jun 17, 2002 | 06:14 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
Maxboy23
Sep 4, 2015 06:04 PM
A32goldylocks
Sep 2, 2015 06:39 AM
