car starting problem
Old Jun 17, 2002 | 04:54 PM
aldren's Avatar
i was using search to find an answer but couldn't find a similar problem.. so here's my problem
went to start my car today (2000 gxe auto). i turned the key and it made a _slight_ noise and went dead. i thought it was the battery so i changed it, but still no go.. All the electronics don't work (even remote entry), and no sounds either (not even that annoying beeping sound when your door is open and the key is in). the only thing that works is a dim lcd light in the dash.
i got no idea what to do, going to clean battery connections right now to see if that's it. alternator? any suggestions?
thanks!
Old Jun 17, 2002 | 04:59 PM
xChungHsienx's Avatar
Re: car starting problem
thanks!
hate to say it, but i guess you should contact the dealer if you can't find out what the problem is. haha hope they don't screw you like i've been hearing stories about.
Chung-Hsien
Old Jun 17, 2002 | 05:12 PM
JimmyH's Avatar
I had a similiar problem, only when I was having starting problems, everything was fine once the engine started.
I would turn the key, and the engine would crank for about 1-2 secs, make an aweful grinding/crunching noise, then start cranking again for 10-15 secs before finally starting.
Since I was out of warranty, I took it to a mechanic and had a new (genuine Nissan) starter put in. Problem solved.
Until about 4 months later, when it started doing the exact same thing. So I took it back to the mechanic, and he put a new starter in (so he claimed) under warranty.
Now the car was even harder to start. It would continue to make aweful noises as it was cranking.
So I got smart and took it to the dealer. They had it over a week, installed a new ECU, checked all the electrical connections, compared voltage readings with another 2000 Maxima off the lot. They finally, in talking with Nissan Tech, found that the problem was corrosion between the engine and transaxle causing intermittent ground faults. So they pulled the engine, cleaned the corrosion, and the car has started without a hickup since.
If you are completely without power, there could be a complete loss of continutity between the engine and trans. I dont know the specifics, but I believe the current flows from the battery, to the starter, to the alternator and through the engine to the transaxle and back to the battery.
Something to investigate anyway.
By the way, the bill came to over $1200. Of which they charged me about $200, and the rest to the powertrain warranty.
Old Jun 17, 2002 | 05:38 PM
aldren's Avatar
thanks everyone
Thanks everyone who replied, i really apreciate it.
i got the problem fixed after cleaning the connection of the battery a couple of times and reconnecting
i guess i overstressed about nothing. probably a car dumbass like me should check under the hood more often
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
Gsantos79
Aug 8, 2015 07:41 AM
