Check out my Heat Shield for '02 Maxima
#41
Originally posted by y2kse
Well that's where you and I separate paths, Colonel. If I could figure out a way to do what this guy did for $2.99 and connect it to my stock air scoop, the story would be over!
http://www.540i6.com/heatshield.html
Talk about taking out the trash. I just LOVE ingenuity!
You know if we REALLY wanted the best...we should relocate the battery and have a larger area for the box. Not sure if that is better or worse but have more room to play with? Whatta ya think? Not that I personally have the time or patience but how does the theory sound?
Originally posted by 02MAXSE
I was planning on doing that this weekend. I'll post results as soon as I have them.
If I may so boldly ask for a couple different measures:
1) after 10 minutes or so of city driving at a light of 30 seconds to 1 minute or so, check box temp vs engine temp
2) note how quickly both cool down after driving away from the same light.
3) drive on highway for a period of time and note the differences in the temps.
4) of course let us know the outside temp as well.
Since you live in Texas...should be fairly interesting to see what happens. Thanks for the test and let us know!
#42
That's great, Steve. Two questions:
1) Will it work with any HAI or only with a Frankencar HAI?
2) If you're utilizing an enclosed design like the pic you posted recently, will it be possible to drill a hole in the front of it and connect a tube to the back of stock air scoop?
2. i am gonna drill a 2" hole and have a black tube run down underneath the car and face forward to scoop and direct air through the shield.
#43
Originally posted by dmbmaxima88
i can't guarantee that it will work if you don't have a midpipe, but it should work with any intake/midpipe combo. maybe i'll let you try it out.
#44
[B]
Way Cool. Shoot me one and I'll do that. I'll send you my address via e-mail.
Any particular reason you decided to do that rather than use the stock airbox or stock airbox/OSCAI combo? Just curious.
[B]
-steve
#45
i never thought about a stock airbox/oscai combo. this would have almost the same effect and look a little cleaner a think.
-steve
-steve
#46
I agree. Maybe you could offer that as an option to mounting a tube in the back of the heat shield.
-steve
#47
i actually meant that the other way from what i sounded. i think just the tube will look better then a tube and the stock scoop and another tube. it will clutter things up again.
-steve
-steve
#48
Ok guys I went to Radio Shack and bought a couple digital thermometers with sensors on a 9 foot wire. I mounted one inside the heat sheild right next to the cone filter and the other just outside the heat shield. Results are as follows:
The outside temp was 92 degrees.
I did some city driving for about 15 minutes and the average temp inside the shield was 98.1 degrees and outside was 126.5 degrees.
I then stopped for about 30 seconds and the temp inside the shield rose to 116.9 degrees and outside rose to 156.4 degrees.
I then got on the highway and the temps dropped pretty fast. Inside the shield they dropped to 94.6 degrees and outside dropped to 115.3.
#50
Ok guys I went to Radio Shack and bought a couple digital thermometers with sensors on a 9 foot wire. I mounted one inside the heat sheild right next to the cone filter and the other just outside the heat shield. Results are as follows . . .
#51
Now here's my twist on this
Is it possible that the sensor inside the heatshield is being cooled down because of the air circulation inside the shield? Given that it's sitting right beside the filter i have a feeling there's a lot of air movement going on around that area that's cooling the sensor down.
If that were the case, with the shield off and the sensor still in the same location wouldn't it still give the same reading given there's some air circulation to help cool things down a bit?
#52
#53
Good work, 02MAXSE. Looks like your heat shield is accomplishing what you hoped it would!
#54
Originally posted by Neal728
I think just putting a heat shield to the left of the HAI, and connecting a hose to the stock air dam that you could hover near the filter would do a good job on its own. any more I think may be nitpicking.
#55
I would not be so inclined to do this...remember...moisture. Always a concern. I would make sure there were enough "bends" in the tube to keep the moisture out. I have looked at a lot of CAI lately...Most are in "covered" areas or have bends in the tube to attempt to keep water out. So far I really like what I see in 02MAXSE application.
I don't see that as an issue in 02MAXSE's application.
#56
Quoted Message:
Yeah, about the moisture, if that was a problem then wouldn't moisture go from the air dam into the stock intake? I think a tube from the air dam into that general area could only help right? If someone thinks directing air like that would harm my HAI let me know. Otherwise I think I'll combine the OSCAI and air dam and put a tube from that outlet toward my K&N later this week. I think that airflow could only help @ low speeds.
#57
How much hp are you guys projecting by making a heatshield?? Personally I dont see a heatshield worth the time. I dont see more than 1 hp gained. IMO a heatshield will only work when the car is idling. When the car is moving, fresh ambient air will enter the engine. If you are gonna design any kind of heatshield/cold air box do a design similar to this http://www.turnermotorsports.com/ima...ai_e46_lg.jpg.
#58
This will get you there:
http://www.turnermotorsports.com/ima...cai_e46_lg.jpg
I think the example you gave is about what Steve has in mind. But we'll have to wait and see . . .
#59
The link doesn't work, MAX2000JP. It's the last period after .jpg that messed you up. Sometimes you have edit your post to fix a URL.
#60
They air pricey though!! I am willing to bet that it would cost somewhere around 100 bucks for a system like that.
Here is another example:
http://www.grandprixstore.com/Mercha...001/tepcak.jpg
#61
Sorry about that...That design would be the only kind i would consider buying. It hooks up to the stock scope to provide fresh air.
-steve
#62
the problem with that is if you look at our stock air scoops they don't get air flow, they are blocked by the hood. they scavenge for air from teh suction created by the stock intake, i don't think they are effective in moving air when they are just siting there.
-steve
-steve
#63
Why not rev the engine a few times to suck the hot air out just before launch? I can't imagine this can make a difference, or as mentioned before, just wrap the tube in insulation if you are that convinced that it makes a difference.
#64
Quoted Message:
http://www.turnermotorsports.com/im..._cai_e46_lg.jpg
http://www.grandprixstore.com/Merch...0001/tepcak.jpg
Is it just me or does this look like a trashcan and a vacuum tube? Hey if a trashcan would hold up, I'm thinkin I may take a trashcan, punch out the hole, and attach that to the air dam. Hmm. Good, bad, ideas?
#65
Nothing is gonna really be effective when the car is sitting motionless, except a PR CAI. The stock intake scope should move plenty of air to the filter box. Look at how the intake gets air on that 330i. It is restrictive like our Maximas, but Dinan and Jim Conforti believe that it works well enough.
I think you're on the right track, Neal728. There is simply NO REASON not to use the stock air scoop to provide an additional source of cold air to the intake. If you can figure out how to do that with a heat shield made out of a trashcan, more power to you!
#66
Well I'm off to Home Depot to pick up a wet/dry vac hose and a trashcan. We'll see how it goes. For now I may just try the hose by itself, see if I notice a difference. What we need is this:
Dyno stock, NO mods
Dyno with Berk
Dyno with Berkencar, or full Frankencar
Dyno with above plus Frankencar's heatshield
Dyno with trashcan/hose
Dyno with just a hose
LOL I need to just buy a dyno setup :-)
Dyno stock, NO mods
Dyno with Berk
