Disabling AUTO feature on stalk?
Man am I sick of searching and reading threads. I've gone through most all of my results and nothing is coming through. Did anybody figure out whether there is a wire to cut which will just permanently disable the AUTO feature?
I am also willing to experiment with rewiring the stalk so that the AUTO feature will be the fourth setting on the stalk instead of the second, but somebody with an ESM will have to make some suggestions.
Originally posted by mdeal
I am assuming you are referring to auto headlights. If so, you can simply use "off" and "on" and not use the auto selection.
1. Off
2. Parking/Running lights
3. On
4. Auto
I can't tell you how many times the Headlight stalk mod has ran through my head. What were the Nissan engineers thinking?
The only way around this that I have figured (without actually modding the stalk) is when the car is off, you have to turn the parking lights on before turning the ignition key. Then start the car.
I'd love to have a stalk mod...that sounds funny.
The Stalk Mod
Your solution is great, but I don't want the parking/running lights on when I'm driving during the day. Particularly with clear side markers...the car looks better with all lights off during the day. However, good idea in lieu of "The Stalk Mod."
Re: The Stalk Mod
Originally posted by MichaelAE
I think Nissan engineer's were thinking that the intuitive thing would be to have headlights on when the switch is turned "all the way" on. I agree if that was their motivation, as it is the way most driver's are accustomed to turning their lights on. For example, I can rent any car in the world and, pretty much, assume that you turn the thing all the way to make the lights come on...know what I mean.
-AUTO
-OFF
-PARKING
-HEADLIGHTS
That way, if you choose the "AUTO" option, you know you're choosing it and you can leave it.
I also agree that all lights off during the day is good. I guess what I meant was: when it is dark, with the ignition in the "OFF" position, the "AUTO" feature does not engage the HID's. When the stalk is in the "PARKING" light mode and the ignition is off, the parking lights are on. You can then start your car without "flashing" the HID's.
Re: Re: The Stalk Mod
OK, I see what you're saying. I have thought that the stalk should go:
-AUTO
-OFF
-PARKING
-HEADLIGHTS
-AUTO
-OFF
-PARKING
-HEADLIGHTS
-AUTO
-OFF
-PARKING
-HEADLIGHTS
-AUTO
-OFF
-PARKING
-HEADLIGHTS
Re: Re: Re: The Stalk Mod
That is how the auto headlights were layed out on my 2k1 Jeep Grand Cherokee. I wish Nissan would have thought of this.
i would like it like this also. i dont have HIDs. but i dont use the auto lights feature... and... whenever i turn my lights off it always flashes and i look like a complete idiot who cannot even turn my lights off right. [/QUOTE]
Switch AUTO and OFF, essentially
Somebody chiming in while looking at the ESM would be helpful.
Yeah, I don't know why our stalk is set up the way it is. My friend has had 2 grand cherokees, a 99 laredo and a 2002 limited, and both of them, the stalks were set up like this:
auto
off
parking
headlights
which is the most logical in my opinion. Oh well.
auto
off
parking
headlights
Re: Bump...
This thread is staying at the top if it kills me.
It's VERY easy to eliminate the AUTO feature, although I have NOT done this yet.
If you would like me to tell you how, email me, and tonight I'll look it up in the FSM and let you know what wire you need to cut at the SECU. I don't want to tell a bunch of people and then have them screw something up and then blame me, because with Nissans' SECU you don't know what side-effects there are until you try it.
There are 3-wires at the SECU(Power, Ground, Sensor Input). Cutting the "sensor input" wire SHOULD disable/bypass the AUTO sensor, but if not, you'll need to reconnect the wire and try one of the others.
One of these YEARS I'll get off my lazy **** and do it, but so far everytime I've been in the mood to mod something, I forget or get side tracked on another project.
i dont' get it.. why dont' you just leave it in the off position?? start the engine then put it in the auto position, if it's dark enough itll light up, if it's not then it won't. and if you want it to turn on then switch it to the full on position, and right before you want to shut teh car off switch it to the parking light mode and use that as your off position. the lights turn off automatically after you shut the car down adn open the door.
Re: Re: Bump...
Originally posted by IceY2K1
Michael,
Michael,
Re: Re: Re: Bump...
The first thing I really want to do is look at the switch itself and see if there is a way to change the position of each item on the stalk.
It's much easier to eliminate AUTO, but don't let me keep you from trying.
if you want the auto to be on full time, all you got to do is paint that photosensor on your dash black or what ever color you like so the light doesn't penetrate it. if you want to make it look nicer, lift the thing up with a panel puller and paint the inside so it still looks stock.
Re: ...
We want the EXACT opposite, no AUTO.
Re: Re: Re: Re: Bump...
Doubt it. The combination switch looks pretty intimidating. Unless, you take it apart and resolder all the jumpers, I don't think your going to end up with the results you want.
Of course not.Long time since I earned my EE, but you'd think I could figure it out.
I might have a day that I venture into the dark realm of the steering column stalk.
Re: Re: Re: Re: Re: Bump...
Of course not.
Long time since I earned my EE, but you'd think I could figure it out. I might have a day that I venture into the dark realm of the steering column stalk.
Of course not.
The EASIEST solution to get the best of both worlds is to just add a switch to the "sensor input" wire.
That way you can enable/disable the AUTO sensor.
Re: Re: Re: Re: Re: Re: Bump...
Even though your an EE, you don't want to mess with it. You'd most likely break it and be buying a new one.
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
