more tire research.....weight
Old Jun 24, 2002 | 01:27 AM
leungjc78's Avatar
I know it's been talked about.....
but anyone know some of the lightest tires around?
I know about Pirelli P7000, and the Toyo (ts-1?...
but any other?? Does the weight even matter? should i even care?
Check out survey in tirerack...and the best high-perform all season is er......Potenza?????? Isn't that the stock tires? cause I REALLY don't like them.
So suggestions anyone? or should i get, as the survey suggested under ultra high perform all-season..
#1 Michelin pilot sports
#2 Sumitomo HTR+
#3 BFGoodrich g-force
...............god forbid
Old Jun 24, 2002 | 02:44 AM
Tony Fernandes's Avatar
Re: more tire research.....weight
It is the Potenza RE950s that got good reviews, not the stock RE92s that come on our cars. The 950s are phenomenal. I can't say anything bad about them at all.
Tony
Old Jun 24, 2002 | 04:39 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
#2 Sumitomo HTR+
i have G-force TA KD's and they are HEAVY, 27lbs as 245/40/18 HEAVY HEAVY HEAVY TIRES
Old Jun 24, 2002 | 07:51 PM
leungjc78's Avatar
Re: Re: more tire research.....weight
Tony
Ahh...that makes more sense!
but...just wondering...are all potenza heavy tires?
Old Jun 25, 2002 | 12:33 AM
Re: Re: Re: more tire research.....weight
Tony
Old Jun 25, 2002 | 09:02 AM
emax02's Avatar
My Kumho Supras weigh about 25-26 lb's. They are 245/40/18's.
Old Jun 25, 2002 | 10:00 AM
not that much less then mine,. i don't feel so bad.
Old Jun 25, 2002 | 07:05 PM
leungjc78's Avatar
even more confusing............
never thought the tire/wheels combo can be so freaking difficult.
hours after hours on the net....it's telling me something different all the time.
So...first off, 18" allseason tires is harder to find, I'm in a small canadian town.go figure. NO nitto in canada..even after good reviews.
someone tells me 18inch wheels=less power..wtf?
I assume if i can get the rims+tires the same weight as 17", nothing changes? BUT..another say.....18" rims are heavier (of course) but the tires as well because low profile needs stronger material/bonds to get better strength.
ok...can some one support this??
So now what? don't change the rims and only the tires? gee...maybe now i can afford the michelin pilot sports...and it's hands down the best...agree?
Phew!
Old Jun 25, 2002 | 07:34 PM
soundmike's Avatar
Very sound, Mike
let me help you ease your confusion
OEM 17" Maxima rims = Heavy (roughly 26lbs.)
18" depending on brand will range from 15lbs. to 30+ (chrome, etc)
Now, say you get an 18" that's also 26lbs., having this rim alone will make your car slightly slower than a similarly weighted OEM rim primarily due to the bigger size (rotational force/inertia (?))
If you get 18's that are lighter then you help balance out the factors.
As far as lower profile tires, it is true. If you get lower profile of bigger sizes it will tend to weight just a tad bit heavier as it needs more rubber in the sidewalls to help carry the load. But not more so. And unlike rims, the difference between weights won't be as much and varied.
Old Jun 26, 2002 | 03:17 AM
Re: even more confusing............
Phew!
Yep!!! You said it!!! I spent hours and hours on the net trying to decide which wheels/tires I wanted. Someone once said that 17" wheels is a good compromise between looks, ride, & performance. After spending that much time surfing and researching I came to the same conclustion!! My personal best advice is to get the lightest, best looking 17" wheels you can buy and then buy the best handling tires you can find...I didn't worry about tire weight. Also, by getting 17" wheels it will open up many different brands and sizes of tires for you to choose from.
Tony
Old Jun 26, 2002 | 02:06 PM
leungjc78's Avatar
Re: Re: even more confusing............
Tony
Yeah.....i think i'll stick with 17 inch..
finding all-season tires that size is near impossible...not to say $$$!!!!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
