Maxima won't rev past 2250???
Old Jun 27, 2002 | 09:15 PM
Shaun Ladd
Hi guys,
I am new here. This is my first problem I have had with with this Maxima and if anyone has any info, I would greatly appreciate it. My car died today while accelerating on the on ramp of the freeway. It was difficult to crank after that. It would just start then die right away. My O/D light was just flashing for a minute or so then stopped. When it finally started, it wouldn't rev past 2250. It idles fine and when you floor it it just wants to die. But as long as you are easy on the throttle it revs fine until 2250 then sputters. The SIL is on and I had an intake on but I switched back to the factory one hoping to cure the problem, but no luck. Please advise me... Oh yeah, it is a 2000 Maxima GXE auto with 44k on it.
Old Jun 27, 2002 | 09:19 PM
ToYLeT902's Avatar
JET Speed Lab
your MAF is bad. go get a new one.
Old Jun 27, 2002 | 09:21 PM
Majisto's Avatar
Odd. I'm not expert on Maximas so I can't really comment on this, but does it go into gear alright? It does not stall out when you put it into drive?
Old Jun 27, 2002 | 09:22 PM
ToYLeT902's Avatar
JET Speed Lab
I said his MAF is bad, he should get a new one
Old Jun 27, 2002 | 09:23 PM
Maximam's Avatar
YEP! MAF time!!! Welcome to the bad MAF club!
MaximaZero's Avatar
Needs non-Maxima Friends
BLOWN MAF! BLOWN MAF! i should know. the EXACT same thing happenned to me about a week ago. and i mean EXACT. you blew your MAF sensor. Arm yourself with the MAF TSB and proceed to your dealership to get the MAF replaced under warranty. make sure you put your stock intake back in (if you have changed it) to be safe.
Old Jun 27, 2002 | 09:24 PM
20 MAXIMA 02's Avatar
MAF sensor would be my guess as well...
it failing would send your car into "safe-mode" which is without a doubt wat ur car is in rite now.
Old Jun 27, 2002 | 09:25 PM
MaximaZero's Avatar
btw, is the blown MAF issue in the FAQ? if not it should be.
Old Jun 27, 2002 | 09:26 PM
KLOOGY's Avatar
L33t BMW Drivah
Say to your MAF !
Old Jun 27, 2002 | 09:34 PM
Maximam's Avatar
Originally posted by kloogy
Say to your MAF !
LMAO!
Old Jun 27, 2002 | 09:38 PM
ABS's Avatar
ABS
Re: Maxima won't rev past 2250???
Originally posted by Shaun Ladd
Hi guys,
Check out the TSB link at the top of the 5th Gen Forum and you should be able to find the actual TSB (Technical Service Bulletin) for this issue. Then, print that document and bring it with you to the dealer . . .
Old Jun 27, 2002 | 09:41 PM
2001SE's Avatar
Say to your MAF !
kloogy and his funny jokes lol
Old Jun 27, 2002 | 09:43 PM
2001SE's Avatar
Hi guys,
when did you install the intake....did you move the MAF sesnor?
Old Jun 27, 2002 | 09:46 PM
KLOOGY's Avatar
L33t BMW Drivah
Come on man, we have to lighten up the mood around here sometimes...
Old Jun 27, 2002 | 09:55 PM
asu174's Avatar
Clay Aiken has fancy genitals
Stupid question- Is it still under warranty at 44K miles? He's screwed, right?
Old Jun 27, 2002 | 09:56 PM
KLOOGY's Avatar
L33t BMW Drivah
He can always go rent a 2K2 and .....
Old Jun 27, 2002 | 09:57 PM
Maximam's Avatar
Yep! I was screwed, mine went out at right about the same mileage. $400.00 later I was back on the road.
Old Jun 27, 2002 | 10:06 PM
WILLSE's Avatar
gotta love extended warrenty!!! 10years or 100k miles!!!
will
Old Jun 27, 2002 | 10:26 PM
MaximaZero's Avatar
does the car have to be under warranty for TSBs to be honored?
Old Jun 27, 2002 | 10:31 PM
Maximam's Avatar
TSB is only a suggestion on how to fix the problem to the techs. It has no importance like a recall does. The part will not be covered if the warrantee is up.
Old Jun 27, 2002 | 10:32 PM
asu174's Avatar
If a TSB is the same thing as a recall, then I would guess not. I had a recall on my Ford Probe with 70K and they fixed it for free.......damn motorized seat belts.
Old Jun 27, 2002 | 11:37 PM
[maxi-overdose]'s Avatar
yes they are....y2kse has summed up everything in the FAQ. also search on MAF and intake...u will find alot.
Old Jun 28, 2002 | 06:09 AM
Shaun Ladd
Do you guys think my intake caused the MAF to fail? Is $400 the part from the dealer? Also, I read the TSB and I am a little confused. When replacing the MAF, is there more involved than just switching them out? I saw everyhting about programming some data in but is that necessary? If so, I should probably let the dealer do it right?
Thanks,
Shaun Ladd
Old Jun 28, 2002 | 06:18 AM
srbarnes4ever's Avatar
Is this another case of an aftermarket intake inducing a MAF failure? Has ANYONE with a stock intake had a MAF failure....I'm afraid....guess I'll get a y-pipe and no intake until someone clarifies this for me.
Old Jun 28, 2002 | 07:06 AM
Shaun Ladd
Is it possible to buy an aftermarket MAF or am I stuck with Nissan OEM... Or do any other year models MAF work with this car? If it broke once it will break again if they haven't made a revision of it and I don't care to buy a new one again. Any ideas or opinions?
Thanks,
Shaun Ladd
Old Jun 28, 2002 | 07:09 AM
ToYLeT902's Avatar
JET Speed Lab
Thanks,
Shaun Ladd
there are no aftermarket MAF's. Your stuck with Nissans OEM MAF.
did you change the intake on your car?
go get ur new MAF.
Old Jun 28, 2002 | 07:47 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Renting a 2k2 Max just to see if it is the MAF isn't a bad idea.
Old Jun 28, 2002 | 07:53 AM
asu174's Avatar
Make sure you get that extra insurance....... Remind me to NEVER buy an ex-rental car.
Old Jun 28, 2002 | 07:55 AM
HulaMAX's Avatar
Shaun Ladd, let me know when you rent your 2K2 Max to "test" the MAF...and I'll "test" the HID's.
Old Jun 28, 2002 | 08:22 AM
Maximam's Avatar
Mine went out with a BONE stock car to the paper filter at 45k miles.
Oh ya the computer has to be re-programed according to Nissan, this is what alot of the cost is for.
Old Jun 28, 2002 | 08:26 AM
Shaun Ladd
not a bad idea, but bringing back a car with a constant SIL would probably trigger that I did something to it... Does the SIL light normally stay on when the MAF has failed? I reset my computer but the light came back on after I cranked it 10 seconds later, so whatever caused it is still there. I had a MAF fail on my MX6 also, but it was a lot cheaper to replace... let me start calling junkyards...
Old Jun 28, 2002 | 10:42 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
it's doesn't have to be programmed. the cel will jsut stay on for like 5 days then turn off.
Old Jun 28, 2002 | 10:45 AM
MaxSE2k's Avatar
Would a computer reset after changing the MAF also rid the SES?
Old Jun 28, 2002 | 12:24 PM
Maximam's Avatar
The TSB says to reprogram the comp to the properties of the new MAF....is that just bull?
Old Jun 28, 2002 | 12:58 PM
CO2kmax
My MAF went out at 65k on my stock 2k.
Old Jun 28, 2002 | 08:36 PM
mother's Avatar
Some car makers (probably not Nissan ) will either fix a TSB'd repair for free or reduced cost if you make a big enuff fuss, and the car is not a long time outa warranty. I'd call Nissan north america and complain. Probably won't do any good, but the call is free. Can't hurt.
Old Jun 28, 2002 | 09:11 PM
mdeal's Avatar
What intake did you have installed?
I would check junkyards first, myself, for I do not believe you'll have much luck at the dealer (with 40K+ miles) not to mention having to reinstall your stock intake.
Old Jun 28, 2002 | 09:58 PM
Shaun Ladd
Well, I started calling dealers today and I found one that said they sell the MAF for $110. I almost fell out of my chair when he said that so I got the part number and called another dealer to see if the part number matched and it did. So you better believe the check is in the mail tomorrow since the dealership is out of town. My local dealership wants $561 so I think this $451 discount will be good enough for me... I already switched back to my factory intake cause I just have one of those pop filters so it only took like 20 minutes or so. Didn't fix my problem though.
Old Jul 2, 2002 | 08:42 PM
Shaun Ladd
Originally posted by Altimat
What's the dealer name? I'll pick one up for a spare!
I am not trying to hide this, cause I ordered mine today. But I don't want to give this place up until I get mine in my hand just in case the price they have is wrong. I had them double check it even with another dealers part number. They said Nissan had issued a revised part and that may be why it is cheap. I paid by Mastercard so I should have it within a week. My luck I will get something other than a MAF sensor. I can tell you with shipping it was less than $100. If it is right, I'll take back everything I ever said bad about NIssan...
Old Jul 2, 2002 | 09:27 PM
could you please pm me with their info. with me taking mine apart all the time for testing and new fitlers i'm worried.
-steve
