Brake Upgrade Myths & Misconceptions
Old Jul 3, 2002 | 02:44 PM
MichaelAE's Avatar
I am primarily posting this here, since I posted it in a thread about a group deal on rotors that Dixit put together. I thought it would be of broader interest:
This is from a FAQ in the Baer Racing Catalog:
CROSS DRILLED ROTORS
Q: I understand crossdrilled rotors offer substantial benefits in cooling, but they crack and fail almost immediately, how can both be true.
A: Actually neither is true.
There are really only two reasons that rotors are crossdrilled;
1) To relieve the gasses emitted from the breakdown of the bonding agents used in the manufacture of some brake pads. This condition, known as "outgassing", can create a pneumatic barrier between pad and rotor which results in a ormal pedal feel but very little friction to stop the ehicle. Ironically, current race pads from Performance Friction and several others are pre-burnished and do not have any outgassing problem;
2) For COSMETIC reasons. The truth is today's ever larger and increasingly open wheel styles, the brake system has become instrumental in creating a "look". Porsche and Ferrari, as an example, certainly know the need for crossdrilled rotors has passed, yet they still deliver their top of the line cars with crossdrilled rotors. This is the same reason that Baer offers all systems with or without crossdrilled rotors.
Crossdrilled rotors do offer about 15% less service (life) in most serious to extreme street use. In actual track use this reduction can be upwards of 50%. However, most SPEs (Self Proclaimed Engineers) suffer from the mistaken conclusion that the small hairline fractures which migrate from gas relief holes indicate "a rotor which is terminal and must be replaced". This too is untrue. these surface fractures are normal with any crossdrilled, slotted, or "dimpled" rotor. the cracks which warrant rotor replacement are any which actually cause a pulsation in the pedal, or which are radial thru the edge of the rotor.
So if you encounter claims that crossdrilled rotors will measurably increase performance, improve cooling, or last as long as non drilled units, talk to someone else.
Another quote from their information:
In racing, crossdrilling was designed to alleviate a problem known as out-gassing. In some of the older pad compounds, when the pads reached elevated temperatures consistent with performance or racing use, the binder (that’s the material that holds the friction material in place) boiled off, producing a gas. This gas would build up between the rotor and the brake pad, effectively keeping the pad from directly contacting the rotor. The holes provide a relief path for these gasses, as do slots, so the pad can once again contact the rotor. Crossdrilling was NOT designed to facilitate cooling.
Baer themselves, actually only sell cross-drilled rotors as a "cosmetic" upgrade. I'm just posting all this to put the debate between dimpled or cross-drilled aside and make the group deal what it is...a cosmetic modification at a good price.
Old Jul 3, 2002 | 02:47 PM
Jeff92se's Avatar
I'm needing a caw
http://www.tubas.net/~drew/ner/brakebasics.htm
Old Jul 3, 2002 | 02:49 PM
MichaelAE's Avatar
Thanks...nice page.
Old Jul 3, 2002 | 02:51 PM
woreyah's Avatar
Re: Brake Upgrade Myths & Misconceptions
Baer themselves, actually only sell cross-drilled rotors as a "cosmetic" upgrade. I'm just posting all this to put the debate between dimpled or cross-drilled aside and make this what this is...a cosmetic modification at a good price.
Sounds good. I just want to know what will prevent brake fade during city driving. On a hot day like this (95+ degrees) it especially pronounced. Are they saying that most brake pads elliminate this? I had Performance Friction on my SHO and had the same problem.
Old Jul 3, 2002 | 03:02 PM
MichaelAE's Avatar
Re: Re: Brake Upgrade Myths & Misconceptions
I'll be honest my man...I'm not a self-proclaimed engineer...I'm a real one but, unfortunately, of the Electrical variety so I'm not the guy to ask. I understand the basic physical concepts of braking, but am merely doing my research as far as the physical benefits of cross-drilling and slotting rotors. My feeling, based on what I've read is that increasing the rotor diameter would both increase braking power and decrease brake fade as the larger diameter would increase brake friction and the larger mass would increase cooling ability. These stock-sized replacements are, really, just a cosmetic upgrade as far as I can tell.
Now, the brake PADS and the brake LINES I find are recognized as excellent brake performance upgrades.
Old Jul 3, 2002 | 04:26 PM
Max_5gen's Avatar
Re: Re: Re: Brake Upgrade Myths & Misconceptions
Some simple physics:
IMHO, brake friction doesn't depend on rotor's diameter, at least directly. If your car is moving at certain speed and you bring it to complete stop it causes all car's kinetic energy dissipated on rotors no matter what type of setup you're using. Yes, with larger rotors (with bigger surface, not necessarily mass) they will go to less temperatures and pads won't probably fade as much. But as you've said you could upgrade pads and leave rotors alone - some aftermarkets can go really high in temperature without fading. BTW, we don't need to increase braking power since anybody could lock their wheels completely with stock setup. Lines give you better "feeling" but don't change anything performance - wise.
Mike.
Old Jul 3, 2002 | 04:30 PM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: Brake Upgrade Myths & Misconceptions
True but I think the Maxima is the largest Nissan to still use the smaller dia rotor and single piston calipers. For ONE panic stop from reasonable speeds, it's probably okay. But do the same from a 100mph and I think these brakes will start heat fading fairly quickly. Just IMHO, I think the maxima needs the rotors/calipers from the 300z or Q45 at least(size wise).
Mike.
Old Jul 3, 2002 | 08:23 PM
iwannabmw's Avatar
Mike.
I don't have ABS, so using stainless steel lines with their better "feeling" allow me to modulate brake pressure easier, resulting in shorter stopping distances.
Old Jul 3, 2002 | 08:34 PM
iwannabmw's Avatar
Re: Re: Re: Re: Re: Brake Upgrade Myths & Misconceptions
Jeff, let me take you through a lap at NHIS.
You come down the straight at roughly 100 mph, if your using the chicanes (turns 1 and 2)you are hard on the brakes to slow to 50, then it's back up to 90-95. Hard on the brakes to slow to 35 for turn 3, back up to about 80, on the brakes to 60 for the bowl turn, back up to 80 over the hill, brake to 60 again through turn 10, back to about 80. Hard on the brakes for turn 11, which is around 45 then it's down the front straight again. This sequence takes about a minute 20.
There's some very heavy repetitive braking going on with not much time to cool down between applications. I run cheapo Autozone rotors in the stock diameter, but I use Carbotech Panther + pads. I don't have any brake fade with this setup. While I agree the stock Nissan pads suck, I even melt Porterfield's doing this, the vast majority of the braking power comes from the pads. A good set of pads is way more important than upgrading the rotors. Bang for the buck wise, some nice pads and high temp fluid is a much better deal to increase braking performance than the time, effort and expense to swap to the Z brakes or a big brake kit.
Old Jul 3, 2002 | 08:49 PM
Donkey®'s Avatar
wat
Seeing is believing...
There are a lot of companies and individuals that say that upgrading your brakes is a 'cosmetic' mod. From my OWN experience...I formed my OWN opinion on the upgrade to my brake system. That opinion would be that it definitely IMPROVED the stopping ability of my 2002 Maxima. The results could vary from car to car and I have no clue WHICH piece of equipment that new found stopping power could be attributed to. But to say that these upgrades are purely cosmetic? I just don't see it from my experience. I swapped out the calipers, the rotors, pads and brake lines. I have been told my calipers were 'cosmetic' upgrades and then I was told my rotors were 'cosmetic' upgrades... Yes, they look sharp. But on top of that, they do have some effect on the stopping abilities of my vehicle. Again, these are MY opinions and can be ignored as far as I am concerned...but I have seen numerous posts on the .org on how useless new rotors or brakes are performance wise and I think people should hear both sides of the story. Thanks.
Old Jul 4, 2002 | 07:23 AM
iwannabmw's Avatar
Re: Seeing is believing...
I'm not saying they are purely cosmetic and they're not useless, expecially if you like them. The slotted rotors look very good, but they also deglaze the pad under high heat conditions(which is a good thing). Does this significantly effect the overall performance of the system? No.
I'd put money on the fact that you would have seen the majority of the performance increase if you had put your new pads on your old rotors, assuming the rotors were in good shape to begin with.
There's no denying that under certain circumstances, calipers and rotors can affect stopping distances, but biggest improvement comes from good pads. I think that's important for people to know who want better braking performance, but don't/can't necessarily spend the money to change everything over.
There's a lot more detailed info on brake upgrades here BTW:
http://forums.maxima.org/showthread.php?threadid=124860
Old Jul 4, 2002 | 09:42 AM
MichaelAE's Avatar
I don't think anybody would say that upgrading your brake system is a cosmetic mod. The cosmetic issue is soley related to the cross-drilled/slotted rotors vs. solid rotors. No question that stainless-steel brake lines, higher quality brake pads, and calipers are great upgrades.
Old Jul 4, 2002 | 10:16 AM
emax02's Avatar
Cross drilling was also originaly used to lighten the rotors.
Old Jul 4, 2002 | 02:08 PM
wdave's Avatar
I feel the ideal upgrade for my braking system would be some high temp fluid, performance friction (or equivalent) pads and a set of undrilled Brembo rotors. The problem is, where to get the rotors?
It is definitely true that the crux of brake performance and lifetime is in the pads. Drilling and slotting are small changes and not necessarily all good as pad and rotor wear are compromised for very little gain in performance. I found when forced to road race with stock rotors and calipers with a number of cars that pads, fluid and then cooling were key, and done right worked well. Since I ran enduros too, brake life was important - cooling and pad composition made the most difference.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
