Suspension and Clutch
Old Jul 3, 2002 | 05:45 PM
Bulldawg's Avatar
One:
My Clutch pedal on my 2k2 is making a strange noise. Where I live, it takes me several times to park my car due to the tight space and the crappy turning radius of the car. Recently I noticed that my when my clutch pedal is in motion it makes a squeaking sound.(like a spring in Tension) It only does this when I am parking, and I am using the Clutch excessivly in a short period of time. Any Suggestions on what this might be.
Two:
If you don't lower your car more that two inches, then do you need a Camber kit?
Thanks in advance.
Old Jul 4, 2002 | 08:45 AM
Bulldawg's Avatar
Re: Suspension and Clutch
Originally posted by Bulldawg
One:
Two:
Thanks in advance.
Come on people
Old Jul 4, 2002 | 08:54 AM
SR20DEN's Avatar
VQ Wizard
The squeaking sound probably is the return spring or assembly. If you can spary some white lithium grease on the spring and fulcrum it will more thabn likely solve the problem.
As for the camber kit I would say no. I have the Eibach Pro Kit springs on my car and from what I can tell the camber hasn't been effected enough to make a difference.
So you're in Columbia eh? Why don't you go to Rockingham with us tomorrow.
http://forums.maxima.org/showthread....hreadid=132200
Old Jul 4, 2002 | 09:06 AM
Bulldawg's Avatar
Those are the springs that I was going to get. How do you like them? Can you tell a difference by looking at the car? How much did you lower it?
Old Jul 4, 2002 | 09:10 AM
SR20DEN's Avatar
VQ Wizard
Im very happy with them. But don't forget to cut the bump stops if you do install them. If you don't get Eibach I would recommend the H&Rs. Matts car (the blue one in my sig) has the H&Rs and when we installed them we didn't have to cut his bump stops at all. Both sets of springs have a nice smooth ride. The H&R are probbaly a little bit smoother and the Eibach are a little bit tighter.
Old Jul 5, 2002 | 07:04 AM
Bulldawg's Avatar
Why did you have to cut the bump stops for the Eibach and not the H&Rs
Old Jul 5, 2002 | 09:12 AM
SR20DEN's Avatar
VQ Wizard
Thats just what the manufacturers recommend. And they are 100% correct. Matts H&R springs don't hit the uncut bump stops. My Eibach springs hit the bump stops frequently. I suppose it's because the H&R are dual rate and the Eibachs are not.
Have you thought about going to Rockingham with us tonight?
Old Jul 5, 2002 | 03:17 PM
Bulldawg's Avatar
I am taking summer school here at Clemson and for some darn reason we have class tomorrow. I have a test at 8 in the morning, and if i go to rockingham then i won't make it back to clemson untill about 2 in the mornin. Maybe next time.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
