Question on 2k2 hid's...
Old Jul 4, 2002 | 08:41 PM
big h's Avatar
Well...I bought these HID's last year fron Dave B and am planning to install them tomorrow morning...I have a 2001 Max Se and I am in Canada...for those that installed the HID's did your car not come with daytime running lamps? I thought all cars com with them...kinda like a safety feature? And on the light stalk inside the car...if you turn it all the way, will that activate your HID's OR are they on as soon as the car is on? I'm kinda confused...I jsut thought u would have to turn the HID's on separately..kinda like the Acura TL's...HElp me please! Oh and i am using BigDogJonx's write up...
Old Jul 4, 2002 | 10:07 PM
TimW's Avatar
The silent but deadly Moderator
whoa...
ok.. you need to verify this, but I think your DRLs are the high beams running at 1/2 voltage. If you put 1/2 voltage on the HIDs, you'll cook the ballasts (starve them for voltage and the amperage will rise, not good). Now you should be able to wire the old Highbeam lights directly to the new Highbeam lights. You shouldnt have a problem that I can see, but you are on some uncharted territory. Just remember to use a multitester/voltmeter, you'll need to double check the write up info as you do yours.
Old Jul 5, 2002 | 07:52 AM
big h's Avatar
Re: whoa...
Thanks Tim...but this really sux! do you have drl's?
Old Jul 5, 2002 | 07:56 AM
big h's Avatar
Oh and Tim...If I were to pull the fuse for the drl's, would my hook up work without cooking the HID's?
Old Jul 5, 2002 | 08:41 AM
TimW's Avatar
I do not have DRLs..
I've seen the schematic in the FSM, it shows the wiring for Canadian models as well as US models.
Only the ground is shared, not voltage, between your high and low beams. I'm thinking you'll just wire them just like the rest of us, as the new highbeams will work as your old one did. But I wouldnt risk $1000 lights without testing that first with a meter. Again, if its just highbeams, then you can pretty much do what the rest of us have done.
Old Jul 5, 2002 | 08:51 AM
NYC2SD's Avatar
Maybe you can just get away with driving with the running lights on. DRLs are the law in Canada..correct?
Old Jul 5, 2002 | 09:35 AM
MichaelAE's Avatar
Re: I do not have DRLs..
If you're right, his install should actually be easier...more intuitive.
Old Jul 5, 2002 | 09:51 AM
big h's Avatar
i dont think they are the law..but just for safety.
Old Jul 5, 2002 | 10:00 AM
big h's Avatar
tim, where can i find this FSM diagram? You guys have no idea how long it took me to finally understand the writeup on Bigdog's swap. My lights are sitting here with all the wires tagged to where and what they gotta hook up to...LOL! This meter that u are talking about, how the heck do you use it? GOD I must be dumb, eh?
Old Jul 6, 2002 | 12:03 AM
big h's Avatar
Nevermind, i figured it all out and these lights are truly awesome! WOO HOO! Thanks for all the help guys!
Old Jul 6, 2002 | 10:57 AM
TimW's Avatar
ooops
sorry I missed your question yesterday.
Voltage tester? Radio Shack? $10? actually, I would spring a few more dollars for a digital multitestor. That way you can test a wider range of circuits. The needle type actually acts as a load on the circuit, so if you test some circuits by error, like with the ECU, you could actually cause a problem. I digital multitestor will often save you from yourself
I sprung for a Fluke. was not cheap, but will last you most of *your* lifetime.
TallTom
57
Oct 14, 2025 05:16 PM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Socalstillen
Sep 26, 2015 12:01 PM
