Subframe connectors on 5th gen - who has them? Results?
Old Jul 6, 2002 | 05:13 AM
Max_Gator's Avatar
I haven't seen much about 5th gens with the sfcs.
Who has them and how much do they help handling?
Old Jul 9, 2002 | 05:02 AM
Max_Gator's Avatar
Re: Subframe connectors on 5th gen - who has them? Results?
anyone?
Old Jul 9, 2002 | 08:04 AM
HulaMAX's Avatar
Re: Re: Subframe connectors on 5th gen - who has them? Results?
Originally posted by Max_Gator
anyone?
Y2KevSE has them. Send him a PM or email.
Old Jul 9, 2002 | 09:00 AM
Spartan5's Avatar
Howdy.
I had them installed a few weeks ago with Dallas's brother up in Monticello, MN at a shop they know. It took two hours of shop time since it was a first SFC install on a 5th gen up here.
The results aren't overly dramatic, given my original set-up of sway bar and strut tower brace and Pilot Sport A/S. However, I do notice that when I am beating my car through some really hard turns, i.e. I've got the body leaned wayyyy over and the tires are screaming, the tail does not fly out and I do not lose control of the nose. The slide is now very predictable. You won't really need these unless you're autocrossing or pressing your car to the limits a lot, but I feel a whole lot safer driving fast through turns because so far I haven't lost control of the car. This speaks well for the subframes since I haven't installed my Eibach's and AGX's yet either. They do add weight to your car, keep that in mind. And if you have a stock resonator on the exhaust piping of your car, there was a metal bracket that I had to cut off because it was vibrating like mad against the stage 2 cross piece connector.
Good luck on your installs, and others should write up their comments too.
Old Jul 9, 2002 | 09:46 AM
Max_Gator's Avatar
Originally posted by Spartan5
Howdy.
Thanks!
I have the same setup as you - minus the rear sway bar but it's coming soon.
Sounds like it might be a good mod for me. I'm not overly anxious to go Eibachs and struts right now so I thought the sfb might be a good mid-step along with the sway bar.
How heavy are the sfbs?
Old Aug 20, 2002 | 08:43 AM
Axel's Avatar
Re: Re: Re: Subframe connectors on 5th gen - who has them? Results?
Thanks!
No one replied to Max_Gator's question so I figured I'd bring this thread back.
Anyone know how much weight the SFCs add?
Thanks.
Old Aug 20, 2002 | 09:19 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: Subframe connectors on 5th gen - who has them? Results?
Thanks.
I remember seeing in another thread that they were like 20+lbs.. That's a lotta weight
Old Aug 20, 2002 | 04:43 PM
mingo's Avatar
37lbs
Old Aug 20, 2002 | 06:07 PM
[maxi-overdose]'s Avatar
I dun remember that I saw one on his car.....
Old Aug 20, 2002 | 10:38 PM
mingo's Avatar
it's on there.
Old Aug 21, 2002 | 06:48 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
You have pictures of it. Look at side shots from underneath the car.
Old Sep 3, 2002 | 12:59 PM
Anachronism's Avatar
Originally posted by mingo
37lbs
Is that stage one and two?
The 5th gen is supposed to be stiffer than the fourth gen to begin with so I guess it follows that you will see less improvement.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
