hoses and wires
Old Jul 9, 2002 | 10:17 AM
jconway's Avatar
hoses and wires
I want to change as much as I can to red hoses and wire housing, is there a best brand to use (i.e. most durable) or will any brand work?
-JC
Old Jul 9, 2002 | 10:27 AM
mdeal's Avatar
Hose Techniques makes some good stuff. See http://www.hosetechniques.com
Old Jul 9, 2002 | 11:06 AM
MichaelAE's Avatar
Re: hoses and wires
-JC
Yeah, mdeal gave you a good spot to pick them up. Prices are good. They don't make a car-specific kit for either the '00-'01 or the '02-'03 Maxima, but you can buy the Universal starter kit and cut the tubing yourself. I have just done up my engine bay with their SuperBlue tubing and it looks pretty solid.
Old Jul 9, 2002 | 12:40 PM
jconway's Avatar
how easy was it to replace all of them? Also do you have any suggestions for the spark plug wires?
Old Jul 9, 2002 | 12:47 PM
mdeal's Avatar
When you say spark plug wires, are you referring to the swooping cables that loop around?
Old Jul 9, 2002 | 12:58 PM
jconway's Avatar
yeah, boot and all, i want to get them in red
Old Jul 9, 2002 | 01:01 PM
jconway's Avatar
its for a 2k2 by the way
Old Jul 9, 2002 | 01:26 PM
asu174's Avatar
Clay Aiken has fancy genitals
Re: hoses and wires
-JC
DO NOT buy the custom maxima stuff. It is crap. You MUST crack the big one to get it to open up, which leaves a crack running the ENTIRE lenght of the hose.
Also, the dye BLEEDS! It got all over my front bumper and interior. Paint thinner wouldn't even take it off. I had to use serious elbow grease with Dissolve It to get it off. There is a small mark on the interior of my door by the trunk popper that won't come out.
JC Whitney has a kit I wish I had bought for $15.
Old Jul 9, 2002 | 01:31 PM
djPlayboy's Avatar
there arent any plug wires in a 5th gen max, but i went to autozone and got some red APC tubing and wire ties looks perty clean but im about to order the HT kit.....good luck and keep it clean
Old Jul 9, 2002 | 01:33 PM
MichaelAE's Avatar
Just buy the silicon hoses and slit them down the sides and cover those wires and cables with a larger hose. You can replace, flat out, a lot of hoses...radiator overflow, all the little breather hoses around the intake, etc. The ones that are not carrying air or water (like the throttle cable), you can just cover those with another hose.
Old Jul 9, 2002 | 01:55 PM
jconway's Avatar
pics
If anyone has pics of the hoses replaced on a 2k2, that would be cool. Also, i have an Injen CAI coming and it comes with red hoses, does it match the FLOred or regular red hose techniques?
Old Jul 9, 2002 | 03:08 PM
MichaelAE's Avatar
Re: pics
I would guess you are closer to matching SuperRed and not FloRed. I'd order the sample pak if I were you. HT will send it priority mail to you and it will have a sample of each color for you to compare. They will refund the cost of the sample pak (no s&h refund) if you order a full package from them. It is $10 and worth getting to be sure.
Why worry about seeing the hoses replaced on a 2K2. The 2K1 and 2K2 are going to look about the same. Here is one of the favorites...Y2KevSE's hose job. Borrowing Kev's picture here.
Y2KevSE's Hose Job
Old Jul 9, 2002 | 03:56 PM
mdeal's Avatar
To answer the other part of the question, most hoses are easy to get to but a couple are a PITA. Overall, it just takes time and you need to ensure you don't forget to put any back on.
I, too, took some HT hose and slit it down the middle to loop over those swooping cables.
Old Jul 9, 2002 | 04:02 PM
Tanman's Avatar
Re: Re: hoses and wires
Wow, you get your Maxima in a lot of mess to find this stuff out. Thanks for it, it lets others know what to avoid .
This is the kit you're talking about, right?
JC Whitney hose kit
Looks nice, but limited color selection. I'm not sure what color to do for my super black SE. I was thinking chrome, but maybe red.
Old Jul 9, 2002 | 04:08 PM
asu174's Avatar
Re: Re: Re: hoses and wires
JC Whitney hose kit
RED! Red looks awesome on black. Check out the custommaxima.com link that says "see our customers". There's a sweet charcoal one in there with red. Actually, here it is.......
http://www.custommaxima.com/WireLoomCustomers.html
Yeah, I have crappy luck, usually caused by my own stupidity, but this time it was 100% the product's fault. There was red dye EVERYWHERE.
Old Jul 9, 2002 | 04:14 PM
MichaelAE's Avatar
Re: Re: Re: Re: hoses and wires
BLUE looks really nice on the Gray Lustre. Blue and Gray are a good combination. Man I have to get around to taking some pictures for everybody.
Old Jul 9, 2002 | 05:07 PM
jconway's Avatar
are those wheels the mille miglia evos? those are what i want to get, they're soooo sweet!
Old Jul 9, 2002 | 06:39 PM
Tanman's Avatar
Re: Re: Re: Re: Re: hoses and wires
Sweet looking, but heavy. If you're more interested in performance than style, they might not be for you.
Old Jul 9, 2002 | 06:53 PM
theMax's Avatar
are the colored headliners custom or painted? if so what are they painted with?
Old Jul 9, 2002 | 07:09 PM
asu174's Avatar
I almost did that but I want to keep it normal for resale. I believe it is painted. I would use a high heat engine enamel. You can get it for $4 at Pep Boys. That is what I used on my lids (washer fluid, etc).
Old Jul 9, 2002 | 09:51 PM
MyownNismo's Avatar
Future Camaro SS owner
I got the kit asu174 was talking about but in blue you get 10ft each of these sizes 5/8,1/2,1/4, and 3/8 diameter. here's a pic.
http://images.cardomain.com/installs...17_28_full.jpg
I want to get silicon hoses for the rest.
Old Jul 10, 2002 | 09:47 AM
MichaelAE's Avatar
Was that kit enough for the car? Did you find that you might have been better off buying specific diameters separately in larger quantities than 10 ft? Thanks...it looks good.
Old Jul 10, 2002 | 10:17 AM
mdeal's Avatar
I found it to be cheaper to just get it from NOPI by the foot, but I live local to NOPI so I didn't have to mess with shipping.
Old Jul 10, 2002 | 11:20 AM
MyownNismo's Avatar
It all depends on how much you do. I have no 5/8 left but about 4ft each of the 1/2 1/4 and 3/8.
Old Jul 16, 2002 | 09:40 PM
Maximum Velocity's Avatar
If this is for a 2k2, then there are a lot less hoses to deal with, thus a shorter installation time. For a 2k/2k1, it took about 5 hours to do. Here's a pic of my engine bay:
Hose Techinques hoses
The hoses don't appear milky looking in real life and everything matches perfectly.
Old Jul 16, 2002 | 09:51 PM
Tanman's Avatar
Nice-looking install. Why didn't you do any of the larger-diameter hoses?
Old Jul 16, 2002 | 10:01 PM
Thanks. I didn't do any of the larger hoses because the largest that hose techniques has is 10mm (internal dia.) and if I slit the hoses, the slit would show. The only real option is to loom them, but I haven't gotten around to looming them yet. One of these days.
Miket2006
Mar 1, 2021 03:55 AM
trsandrew
Oct 25, 2015 02:47 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
